This weekend coming back from L-cross i was towing a 36ft gooseneck with two trucks total weight was 23,500lb. The trip back home(miami) was about 1hr.50min. I was averaging about 73mph. When i got about 60 miles from home i started doing 80 to 84mph. At about 5 miles from home my flex plate was cracked. I know this is my stupidity. Can i Install a billet flywheel and eliminate the flex plate. Someone told me yes but, it is a pain to bolt up the T.C. and flywheel. I know banks makes a flywheel and ATS makes the flexplate. Can someone explain, because they look the same. THANKS
__________________ 04.5 LLY crew cab, PPE program, custom air box, 4in. turbo back exhaust, boost controller,AND A CUSTOM MADE fLYWHEEL/FLEX PLATE (ONE PIECE).
They are the same, Manuals use flywheels and autos use flex plates, thats the way i was always tought anyhow! The dmax uses a two peice type flex plate with a peice you could call a flywheel, it dose nothing more than balance the engine and provide the gear for the starter. The ATS bilit flex plate will cure your problem but i would want to know what is breaking them? What type of converter are you running?
Do not put a ats flexplate on your truck. The whole FLEX means it needs to flex ats is soild i have broken 2 flex plates also. On my 3rd one i tryed this
U have 6 allen heads holding your flex plate and fly wheel to the back of the crank take out ever other one i have done that and have not broken my flex plate yet. fingers are crossed though.
__________________ Snow flake 2004.5 D/A Efi live, PPE lift pump, 35inch mudders and a florida stack
13.20@115 mph
I would be kind of scared only using 3 bolts. Keep in mind im trying to achieve a goal people say is stupid of me. To me there is a rush towing heavy at a speed where you pass fords towing motorcycles. If i eliminate the flex part of it. What else can break? I'd rather have to replace a drive shaft or axle before dropping the tranny.
My idea of why it is breaking is: The plate or fly wheel was not balanced or maybe it wasnt installed correctly by the dealer in defuniak springs because i got a little woble on the T.C. At a high speed with so much weight there is constant pressure. Plus shiftting into gears transfers to much for that tin looking plate to hold. SORRY ABOUT THAT INFO. I'M RUNNING A SUNCOAST CONV. I WIIL UPDATE MY PROFILE SOON. THANKS GUYS.
If the fly wheel and flex pl. are the same why are they sold seperatly and not manufactured as one? If u go to the dealer and ask for a fly whl. thats what you get there is no flex plate. The flex plate to a dealer is an extra part.
say, when your flexplate cracked, how did you know? i have got a wierd vibration coming from my 2004.5 lly.
__________________ 2004 Chevy K2500HD Ext. Cab/LB w/ LLY Dmax
-EFI LIVE TUNING!
-Silverline 4" exhaust, lost the cat and muffler
-Autometer guages (egts and boost)
-4 front ends last year from deer
-B&W 30,0000lb GN hitch
-164,000 miles
He is right Flex plates are for autos and flywheel is for man.
__________________ 2006 GMC 2500HD LBZ Crew Cab 4x4, Snow Performance Boost Cooler, Silverline Turbo Back Dual Exhaust, PPE Hot Programmer, Egr Block Plate, PPE Air Box Mod, 2in. Plug, SES Light
Full Bore Exhaust Manifold compliments of BD Diesel.
I expirienced a very poor customer tech. edicacy. Since I was not 100% sure he made me feel like a complete idiot. No bad words but, sarcasm that you would use in a marital argument. This happened when i called to get a little more info about flex plates or fly wheels. THANKS GUYS. WILL LET YOU GUYS KNOW WHAT THE OUTCOME IS.
The first time it sounded like a really exagerated loud rod knock. Everything about the truck changes. When it shifts its more of a smooth non power shift, deceleration is diff. and etc... You can take off the inspection plate at the bottm of the trans. and with a med. screw driver you stick threw the little slotted hole about 4-5 inches toward the eng. if you work it side to side looking for the teeth you will be able to turn the fly-wheel and look at the plate.(carefully) sometimes their very small but under any load it will be noticed. Good luck.
