Painting Pillar Pod - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 03-28-2008, 10:46 PM Thread Starter
wildturkey_hunter's Avatar
Painting Pillar Pod
I just got a 2 gauge pod to install only problem is its black and my interior is dark gray. I found a can of Dupla Color paint at Oriellys. It says its works on trim accessories. Do I need to prep the plastic piece any special way? Any tips for painting this part.
2005 Chevy 2500 4X4 LLY,LT,CC Dean 285/75/R16
T-Bars Cranked to the MAX
MBRP 4" DownPipe Back
Bully Dog Power Pup
Auto Meter Ultra Lite II
Boost And Pyro on A Pillar
Plugged Resonator:ar15
wildturkey_hunter is offline
post #2 of 7 (permalink) Old 03-28-2008, 10:56 PM
Tow Master's Avatar
They make special paint for doing interior peaces and id use that.
If they dont have it in your color id scuff it down with a 3M scuff bad, primer it, then paint!
Jason
Tow Master is offline
post #3 of 7 (permalink) Old 03-29-2008, 07:18 AM
[QUOTE=wildturkey_hunter;36492]I just got a 2 gauge pod to install only problem is its black and my interior is dark gray. I found a can of Dupla Color paint at Oriellys. It says its works on trim accessories. Do I need to prep the plastic piece any special way? Any tips for painting this part.[/QUOTE
I found the cheapest way was to take it to the body shop and let them paint it. By the time I bought the prep and paint the time to do it all just wasnt worth it. I droped it off and with in 1/2 hour they called to come pick it up. A good shop will have a mixing rack and with the code off the truck can match the paint perfectly.
2015 chevy 2500 duramax
5" lift all stock
f419sr1 is offline
post #4 of 7 (permalink) Old 03-29-2008, 08:35 AM
duramax-rob's Avatar
You might try a auto trim shop, usually the specialize in repairing and painting parts from leather to vinyl to plastic. The shops in St. louis are very good at matching color and the paint last for years. There should be something in your area. Also, Mar-hyde makes a interior semi flat that will work and you can get that at auto paint stores. Some stores can put it in a spray can for you if you are a do-it-yourselfer.
Good luck.
Duramax-rob
duramax-rob is offline
post #5 of 7 (permalink) Old 03-29-2008, 11:34 AM
Hammer 4's Avatar
I just cleaned mine with brake cleaner, wipe it off fast..a light scuff with 600 grit sand paper and painted. I also used dupli color.
03 LB7 4X4, xtra cab, long bed...
4X4 LS Summit White
Custom 4" catback, PPE boost Valve PPE Xcellerator Hot
315 BFG Ko's on H2 Rimz..
Kennedy Airbox Mod w/ custom 4" intake SD Manifold...ISSPRO Gauges
Hammer 4 is offline
post #6 of 7 (permalink) Old 03-29-2008, 12:39 PM
NVMYLLY's Avatar
I just did a basic prep clean and scuff pad, then used a GM interior paint and gave it 3 coats. It looks great!!
--SOLD 04.5 GMC 4x4--
HOG 4" SS w/6" SS Tip, AFE Stg. II &Turbo Inlet, EGR Block-Fingered, Res Plug, Fuel Shim, LP, TR Sleeves, QuadS2
Pioneer In Dash DVD/NAV, Boston S60 Internals, 10" JL W3 Sub, JL 500/1 Amp, 3 Pillar S/Comp. II's, 15% Tint, Viper 2 Way
305/55R20 Nittos, 20x9 Devino Kraken Black, RCD Lev Kit with Zink Billsteins, ArmorThane Bedliner, Truxedo Tonneau, Black Step Tubes, LED Big Rig Kit w/Red Wheelwell ExpansionLEDs, Smoked/Black LED EVERYTHING, 4x8000K's, Cowl w/Dmax Emblems
NVMYLLY is offline
post #7 of 7 (permalink) Old 03-29-2008, 11:53 PM
Maverick684's Avatar
Same here, I just cleaned and used some interior paint in the spray can and went to work, took me about a half an hour to do. I sprayed it with about 3-4 coats.
John
05' Dmax LLY CC SB, 6in.Fabtech, 20x12 Fuel Krank's, 35in Trail Grapplers and some other stuff
2012 Jeep Grand Cherokee SRT8
2003 Cummins SC LB
Maverick684 is offline
