low idle speed - Chevy and GMC Duramax Diesel Forum
post #1 of 25 (permalink) Old 04-01-2010, 07:38 PM Thread Starter
low idle speed
so my truck is idling at 500 to 550 rpms now, used to idle at 650 or more, why is is idling so low? is it bad and what can i do to adjust it?
2001 LB7 Ex. Cab Short Box 4x4
Quadzilla Stealth II
PPE High Idle
Intake Horn Mod
Banks Ram Air Intake
Stock Exhaust with Muffler Cut Out
Dying Allison Tranny-Limp count-4
www.AlligatorPerformance.com
duramaxthis is offline
post #2 of 25 (permalink) Old 04-01-2010, 07:40 PM
Kroggs's Avatar
Place brick on skinny pedal... Sorry had to. My brother inlaw's truck is doing the same...
2005 LLY Gmc 3500 CC/LB not bone stock I have a brake controller!!!
Thanks to Tyler @ www.meyerperformance.com
Thanks to Chad @ http://www.alligatorperformance.com/
http://www.facebook.com/group.php?gi...?id=1210592953
Originally Posted by MNDiesel View Post
I hate to derail, but how do you get a quote in your sig?
Like this^^^^^^^
Kroggs is offline
post #3 of 25 (permalink) Old 04-01-2010, 07:48 PM
delong_1's Avatar
idle speed is controlled by engine temp but you are right that is a bit low, im not sure what would cause that.
built motor, big turbos, built trans, etc all by me, parts from Elite Diesel
1016 hp
7.1 1/8 @ 100
11.27 @ 105
delong_1 is offline
post #4 of 25 (permalink) Old 04-01-2010, 07:51 PM Thread Starter
engine temp was around 200, is that normal? all winter when it was cold it ran 160 but now that its hot it gets to 200 and the idle gets lower
PPE High Idle
Intake Horn Mod
post #5 of 25 (permalink) Old 04-01-2010, 07:59 PM
delong_1's Avatar
at 200 it should idle between 680-690, i just checked a stock tune. 160* idle should be 680.
1016 hp
7.1 1/8 @ 100
11.27 @ 105
delong_1 is offline
post #6 of 25 (permalink) Old 04-01-2010, 08:01 PM Thread Starter
well what the hell
PPE High Idle
Intake Horn Mod
post #7 of 25 (permalink) Old 04-01-2010, 09:34 PM
Killerbee's Avatar
Your tach is probably broken.
Michael
Killerbee is offline
post #8 of 25 (permalink) Old 06-02-2010, 09:38 PM Thread Starter
my tach is not broken and you know it i dont appreciate your all to often i'm smarter than you answers, now i know you have spent thousands of hours in your lab coat looking through a microscope and your theory is that the molecular hydrocarbons in my diesel fuel has atomically bonded with the nuclear atoms in my fuel rails raising the lower atmopsheric pressure by .0000000039 degrees thus causing the world to spin backwards and my truck to idle lower. go away
PPE High Idle
Intake Horn Mod
post #9 of 25 (permalink) Old 06-02-2010, 09:40 PM
ATPTRUCKS
sickdiesel's Avatar
got emm
2017 GMC Denali CC/LB L5P
06 GMC lbz 4x4 Built motor, HSP twins, DDP Injectors, Self built trans 11.68@118.5 SOLD
07 Chevy lbz 4x4 Caged and built 10.42@134 SOLD
Special thanks to: Mike L, Gtrippin, IdahoRob, Dmaxstore, HSP, ISSPRO, Yukon, Airdog
LIKE US ON FACEBOOK!
Adrenaline Truck Performance IDAHO ROB 208.685.1000
sickdiesel is offline
post #10 of 25 (permalink) Old 06-02-2010, 09:45 PM
DuraTitus's Avatar
I cannot understand why you are so sure that your tach is not broken.....the stepper motors in the guage cluster are known to go bad sometimes.
Have you looked at the idle RPM's with a scanner?
DuraTitus is offline
