| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | General Discussion General Diesel Discussion. |  |
04-03-2008, 05:40 PM
eBay Motors
#1 (permalink)
| | Junior Member
| deisel secret energy problem |
| Advertisement
04-03-2008, 05:46 PM
eBay Motors
#2 (permalink)
| | Complaint Dept.
| IMO. I would just run a few fresh tanks of fuel in it with a good additive like staydine ,or power service and see if it helps.
__________________ Craig2001 Chevy, 4 door, short bed,D-Max, 2 wd. Mods.. straight piped exhaust,  Custom dent and scratch in passenger side rear panel.. Spacial Thanks goes to the person in the WAL-MART parking lot for installing it for me,  NEW MEMBERS-PLEASE HELP US HELP YOU.. FILL OUT YOUR SIG. IN THE USER CP. Your Sig should have the Year, Make, Model and any Mods. |
04-03-2008, 06:11 PM
eBay Motors
#3 (permalink)
| | Senior Member
| Take it in, have service tech have look at it. Your truck is still covered by warranty...or is it not?
__________________ 08 Sierra WT CC SB
Steel Gray 4x4 PPE RACE
Modded OEM AirBox/PCV Reroute/4" MBRP into 5" MagnaFlow/ EGR BLOCKED
Isspro EGT/Boost gauges Cognito Leveling Kit/HD Tie Rods  Pitman/Idler Support Brackets/Bilsteins
Pirelli Scorpion ATR 265/75/16 Coated OEM Wheels
Factory Oval Steps/Rhino Lining
Klein Air Horns (4)/ViaAir 150 psi 2g compressor |
04-03-2008, 08:50 PM
eBay Motors
#4 (permalink)
| | Senior Member
| What is diesel secret?
__________________  2005 Chevy 2500 4X4 LLY,LT,CC Dean 285/75/R16
T-Bars Cranked to the MAX
MBRP 4" DownPipe Back
Bully Dog Power Pup
Auto Meter Ultra Lite II
Boost And Pyro on A Pillar
Plugged Resonator |
05-13-2008, 09:35 AM
eBay Motors
#5 (permalink)
| | Junior Member
| DSE is to blame for the problems. See DSE is snake oil. It gums everything up and it cant be remove unless you take it apart. You have to heat WVO, there is no magical chemicals to run WVO.
I would not mention it to the dealer and tell them your are only running diesel or they wont fix it for free.
I ran that stuff for a summer and in the fall I had a couple thousand dollar repair for all new injectors and an IP.
Good luck to you |
05-13-2008, 06:04 PM
eBay Motors
#6 (permalink)
| | Senior Member
| Diesel Secret is positively junk!!! I got caught up in it and had trouble also. Lucky for me I noticed it right a way and got it flushed out.
__________________ HAD - 94 Chevy Dually 4x4 - 6.5 Turbo
96 Chevy Ext.cab 4x4 - 6.5 Turbo
99 GMC Dually 4x4 - 6.5 Turbo
HAVE - 2005 GMC Sierra crew/6'box - 4X4 - Duramax w/Allison. Fully loaded - AiRaid intake - 4" Pinnicle Performance Exhaust (No Converter - Straight through muffler) - EGR blocker plate - Edge Juice w/attitude - 2" plug in Turbo Resinator - |
05-13-2008, 09:15 PM
eBay Motors
#7 (permalink)
| | Super Man Moderator
| Ehhh you probably screwed up the injectors. Did pull the dipstick and check the oil lately? If diesel fuel gets in your oil and can cause serious harm. IMO Id take it to the dealer and would NOT mention the diesel secret. If it did harm the injectors then they should be replaced under warranty
On Edit..... I just realized this thread was over a month old! What happend?
__________________ Jason 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 2 MTX 10in Subs & Punch 250amp in a custom box. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 265/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake |
05-14-2008, 06:56 PM
eBay Motors
#8 (permalink)
| | AIN'T SKEERED!!
Join Date: Mar 2008 Location: DIRTY SOUTH,YEAH DOWN THERE!!
__________________  2006 GMC 2500HD4x4 sb cc LBZ!!!  52k
MODS:Full straight pipe,res mod,Superchip tuner
2002 GMC 1500 2wd x-cab-sb 5.3l.
1987 89,000k 305H.O. 700-r4
1978 Malibu[2dr]350/350hp TH-350 trans |
05-15-2008, 04:06 PM
eBay Motors
#9 (permalink)
| | Junior Member
| response about DESIEL SECRET i just took my truck in today and they have called me and tell me the fuel filter needs changed and flush the fuel tank , I have changed the filter four times in the past three weeks and the last it took the truck a long time to crank even though i primed the fuel filter i think the fuel pump has been under a lot of stress running the snake oil even though i thinned it three times the recommend amount.Definitely don,t advise any body try this SECRET> |
05-15-2008, 05:41 PM
eBay Motors
#10 (permalink)
| | AIN'T SKEERED!!
| Yeah,nobody fool with this stuff,if you look into it they sell it out of a hole in the wall warehouse in Sunset,La. Actually a few miles from where I live.I've heard nothing good about em,definitly TRASH!!
| Advertisement
