Lost comm. W/ECM & PCM (but no actual side effects) what the..?? - Chevy and GMC Duramax Diesel Forum
Old 04-16-2010, 06:00 PM   eBay Motors  #1 (permalink)
GeneralTJI's Avatar
Has happened twice probably 1000 miles apart.... Get the u0100 code for lost communication with the ECM / PCM which puts the tranny into a mode kinda of like tow haul where it shifts at a higher rpm. Both times it happened while just cruising along and I didn't even notice anything....
No issues with the truck at all, just this weird code popping up!!anybody seen this before? It's very annoying!!
Thanks!!
06 LBZ / 6spd Allison 4x4 ec/sb
Self built/tuned sideways s366 setup | DPC converter / Co-Pilot | 1792 / BD Filter| Black 5" Hood Stack | Homebuilt Trac Bars | Coil-overs | 250psi water/meth | Black MM951's | roll pan | Autometer/ISSpro/UltraGauge | sleeves | self Lowered | deep pan etc.
12.61 @ 105 - 5800ft elev (stock trans) 12.6 vid
02 WRX w/ STi 6spd
Self built/tuned stroked ej22t 2.35l s363 AEM EMS build in progress w/ a buttload of other goodies...
GeneralTJI is offline   Reply With Quote
Old 04-16-2010, 06:25 PM   eBay Motors  #2 (permalink)
delong_1's Avatar
might want to check the bale connecters on the ecm and tcm, make sure they havent partially come out.
built motor, big turbos, built trans, etc all by me, parts from Elite Diesel
1016 hp
7.1 1/8 @ 100
11.27 @ 105
Old 04-17-2010, 05:36 AM   eBay Motors  #3 (permalink)
GeneralTJI's Avatar
I'll look but it's strange because the truck never misses a beat...when this happens it gets codes for tcu malfunction, fuel temp sensor, water temp sensor etc.... It thinks it's loosing connection to a bunch of stuff yet the truck is fine... Only thing that gives it away is the tranny changing shift points...
Thanks...
02 WRX w/ STi 6spd
Old 04-17-2010, 08:46 AM   eBay Motors  #4 (permalink)
VAGITARIAN :)
daddysLBZ's Avatar
Batteries are probably weak..Any moisture on the ECM underhood lately?It's right under the driver's side battery on driver fender....
2006 GMC 4x4 CC/SB/sle1/LBZ**312,000 miles!!** PPE HOT+2 225 TUNE beeeyotch:-)AutoMeter egt/boost Suncoast 5 trans w/1056TC!,billet in/out shafts/MagHytec pan!!,M/A built T-Case,4 in.str8piped,5%tint all around
2007 Chevrolet 4x4 CC/SB [LS]LBZ! 72k [this one stays STOCK!]
Also, I speed and don't come to complete stops at stop signs.
''don't sweat the petty things,pet the sweaty things''
Click below/pictures of my junk!!
http://www.duramaxforum.com/forum/vb...do=hall&u=8415
Old 04-17-2010, 06:37 PM   eBay Motors  #5 (permalink)
GeneralTJI's Avatar
I pulled the connectors on the ecu and tcu.. Cleaned them with contact cleaner etc. Haven't driven it yet.... I guess it's good that the truck itself isn't acting up, but kinda odd that these codes keep coming up. I wish GM wouldn't put the ecu's under the hood never been a fan of that idea....
We'll see
02 WRX w/ STi 6spd
Old 05-01-2010, 08:09 AM   eBay Motors  #6 (permalink)
GeneralTJI's Avatar
Still having issues
I had hopes that I would be able to just disable these codes when I tuned my truck w/ HP. But the U0100 code doesn't show up in the DTC list
I disabled some of the others, but when this happens it still puts the trans into tow/haul mode (basically).
This is pissing me off.
I can clear it while driving with my Edge monitor, but they sometimes come back right away.. sometimes not for a while.. truck still never misses a beat.
There is nothing wrong with any connections etc. Everything is clean and been checked to see that it's seated..
Looking around a see several other threads of people with the same problem, but no one has ever posted a real solution yet??!?!
02 WRX w/ STi 6spd
Old 05-01-2010, 08:49 AM   eBay Motors  #7 (permalink)
iridebikes's Avatar
Change your fuel filter:Smack
I keed I keed
I gots gas
iridebikes is offline   Reply With Quote
