Kennedey Diesel Performance vs. Duramileage - Chevy and GMC Duramax Diesel Forum
post #1 of 16 (permalink) Old 04-24-2008, 03:02 PM Thread Starter
bob213's Avatar
Kennedey remaps your ECM with up to 2 tunes for $695. if you send them your ECM or $300 more if you use their ECM. They seem to get great reviews.
Duramileage (Powerupdiesel.com) will remap your ECM with 1 tune for $699, if you use their ECM or $495 if they use yours. They get comments like "Smoke and Mirrors", "Fraud", "Doesn't really work".
Can someone explain to me what the difference is, if they are both remapping your ECM?
Does Steve Shelley at powerupdiesel have a bad rep?
Does anyone really know if this works?
Is higher EGT's still an issue?
bob213 is offline
post #2 of 16 (permalink) Old 04-24-2008, 06:56 PM
IdahoRob's Avatar
There are a few of us that tune ecm's. We are using either EFI Live or HP tuners. Custom tunes can be built for any power level needed, with increased economy as a bonus.
Kennedy has a good track record, I have not heard reports on the other company.
Give me a shout if you have questions on ecm tuning and/or the tools needed to do it yourself.
2007 LBZ tow rig/Daily driver, stock engine 11.70 @ 115mph on #2, 677 HP, MPI Twins
2002 LB7 Max'd Out 9.71@141+MPH on #2 fuel only, MPI Twins
EFI Live, Suncoast Dealer, Dmax Hotrod Parts
Adrenaline Truck Performance 208.484.3670
IdahoRob is offline
post #3 of 16 (permalink) Old 04-28-2008, 08:20 AM
Killerbee's Avatar
You can buy EFILive from Rob, then you are not locked out of your PCM. I would NEVER go for the options you have outlined because when you get the PCM back, you can't access it or change code. IOW, you have no freedom with your own vehicle...you are trapped into future down time, etc, unless you replace the PCM.
Pay money to limit my use? No thanks.
Michael
Killerbee is offline
post #4 of 16 (permalink) Old 04-29-2008, 06:59 AM
Diesel Addict
i agree with Killerbee on limiting yourself with tunes built into your ECM from somebody else so i would highly recommend doing the EFILive yourself or invest into the PPE tuners both will get you lots of power and a fuel economy increase..
Project, Rogue Budget(Workstock Puller)
2006 GMC 2500HD, Stock Motor, EFILive by me, Billet 63 VVT, Motorsport Stroker CP3, 20% Nzls, ProFab Manis n Uppipes, BD IC, Hot Pipe IC, ProFab Y-Bridge, lots of other goodies
TYREBOYZ_DEMAXIN is offline
post #5 of 16 (permalink) Old 04-29-2008, 07:06 AM
BoiseRob's Avatar
I bought EFILive from IdahoRob. Great guy and he takes care of his customers. I am currently running an IdahoRob tow tune. It dyno'd 421hp & 768tq. My mileage is 15-16 city and 20-21 highway. :rockin
Rob
2007 2500HD "Classic" 4x4, LBZ/Allison, CC/SB, Nerf Bars, Billet Grille & Emblem, Tinted Windows, Incubus Rims, 265/75R16 BFG A/T, AFE Filter, Bilstein Shocks, TransGo Jr. & Mike L. cooler installed by Mike L., MBRP T-409 4" Cat-Back, PPE Blocker Plate & EFILive tuned by IdahoRob...
473hp & 920ft/lbs
BoiseRob is offline
post #6 of 16 (permalink) Old 12-15-2008, 10:20 PM
kdh
Was looking @ steve shellys tune for lmm duramax.Does any one have or know someone that has run his tuner?He sugguested exhaust mod as well.Can you run straight through with out coding as there is lots of goodies on 2008 system?
kdh is offline
post #7 of 16 (permalink) Old 12-15-2008, 10:36 PM
Ask one to be one
usafracer's Avatar
I will be runing Idaho Robs LMM tunes when I get my DPF delete done. I have herd nothig but good about his tunes.
Marty
2010 GMC Sierra CC SB 4X4 Cognito 6" lift and 315/70/17 ATP Tuned!!
2008 GMC Sierra Crew Cab 4X4 (wifes) Zone lift set close to 4" 305/70/17's Hankook Dyna Pro RF-10 ATM
usafracer is offline
post #8 of 16 (permalink) Old 12-15-2008, 10:50 PM
Duramax-LML's Avatar
go to idahorob : )
Name: Jake Age:26 INSTAGRAM: @jakethomaspnw
2013 Duramax LML CCSB LTZ My Build Thread
SPORTSMAN CP3/ S369SXE/ 30% OVER EXXERGY INJECTORS, FASS 150, diamond eye 5" TB,6" Fabtech Lift no bolts, 35inch Toyo M/T, 20x12 Fuel Octanes,ISSPRO EV2 GM MATCH, BOSS grill,Fusion front and Iron Cross rear, Pioneer In dash, subs, ARB twin air compressor, Cognito UCAs
Duramax-LML is offline
post #9 of 16 (permalink) Old 12-16-2008, 07:29 AM
IdahoRob's Avatar
Why buy a locked ecm for the same price as the tools/tunes to do it yourself? You won't be able to change settings, tunes, tire size, etc. without sending the ecm back in. So you get some new tires and the size is different, your SOL. What about a new free flowing exhaust, again SOL. If you had EFI, then you are a couple clicks away from a perfect running truck.
I give two free tested tunes that I would match up to them anyday.
IdahoRob is offline
post #10 of 16 (permalink) Old 12-16-2008, 09:38 AM
Diesel Addict
i would highly recommend going with Rob on the tuning.
