Front end clunking noise when turning?? - Chevy and GMC Duramax Diesel Forum
post #1 of 4 (permalink) Old 05-22-2010, 07:38 AM Thread Starter
I have an 07 LMM with 6" pro comp lift. Within the last couple weeks, the truck started making a clunking noise in the front end when turning the wheel (mostly happens when im turning the wheel to the right). I greased every alamite I could find and no change. I got under the truck and had someone turn the wheel and I cant pinpoint where it is coming from. Its almost like a popping sound while turning to the right. I also jacked the front wheels off the ground and tried it and nothing. It only clunks when on flat ground. Any ideas??
Thanks
Nick07 is offline
post #2 of 4 (permalink) Old 05-22-2010, 07:41 AM
floridamax's Avatar
It's a body mount. Dealership has a bulletin on that. go to the dealershit and ask them to to it and look at the bulletin. they put a shim between the body and mount. I had a link on that i think it was called front end clunk or front end issue.
08 GMC Crew cab long bed 4x4 with 20'' xd spy and terra grappler 305/55/20. airaid filter and box, Full 4'' mbrp turbo back with 6'' tip. Quadzilla stealth 2 on 90hp tune, EGR block off plate and PCV reroute. I t does smoke like a mofo too. Staying off the pedal cause I don't like to piss tree Huggers off.
floridamax is offline
post #3 of 4 (permalink) Old 05-22-2010, 07:43 AM
floridamax's Avatar
Here is the link. good luck
http://www.duramaxforum.com/forum/ex...end-clunk.html
post #4 of 4 (permalink) Old 05-22-2010, 08:19 AM Thread Starter
Thanks for the link! I read through the entire thread and it seems as if I have a different noise than the one you described. Mine is more towards the passenger side and ONLY clunks when im turning the wheel. It sound like its coming from somewhere around the passenger side of the steering stabalizer. It mostly does it when im turning the wheel to the right. No noise at all when im on the road. It is loudest when im sitting still and turn the wheel to the right.
Nick07 is offline
