| Premium Membership | |
| | | General Discussion General Diesel Discussion. |  | |
06-17-2008, 01:17 PM
eBay Motors
#1 (permalink)
| | Junior Member
| Oil out blow by tube 2002 Chevy Silverado/2500HD 6.6 diesel. 90,000 miles. I Have read other post of same problem no fix. Oil is coming out of the blow by tube. No loss of power, or any codes. Pressure dropped to under 20. Now its low on oil. Started happening about 100 miles, or 2 weeks after last oil change. I have several diesels and all run Rotella Syn. No there is no PCV valve on this motor. Dealerships around here have no clue and want 75 dollars an hour to find the problem. Please help. Thank you. |
| Advertisement
06-17-2008, 10:55 PM
eBay Motors
#2 (permalink)
| | Super Man Moderator Points: 10,639, Level: 44 |
| Welcome to the forum!
Hmm that is strange. I thought all trucks have a PVC valve? Thats the only thing It could be. Just to try something try taking the oil cap off and see if it still happens.
__________________ Jason 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 4 Kicker 10in Subs & Punch 250amp in 2 custom boxs. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 285/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake |
07-04-2008, 04:36 AM
eBay Motors
#3 (permalink)
| | Junior Member
| Sorry long time since post. 6.6 truck dumped several quarts very thin oil out onto the ground, saturated with diesel. Mileage went down, oil pressure dropped and truck running rough. Several chevy mechanics advised known injector issue take in to dealer. Truck is now sitting in Service center waiting. Will update on findings. Thanks for the help. |
07-04-2008, 04:53 AM
eBay Motors
#4 (permalink)
| | DuramaxForum Fanatic
| Sounds like the injectors...
__________________ "No good decision was ever made in a swivel chair"
06 Silverado 2500 cc/sb Silver
6.6 Duramax LBZ BABY!
H2 Wheels w/BFG A/T 33'S
Edge Evolution  //Missing Kitty...  !
Cobra 29 CB Radio//PPE Air Box Mod Coming soon!
EGR block plate and tie rod sleeves sitting in package at home waiting for me!
Transgo Jr soon to come! |
07-04-2008, 09:02 AM
eBay Motors
#5 (permalink)
| | Junior Member
| It's low on oil because the crank is full of fuel from leaking injectors. |
07-04-2008, 09:31 AM
eBay Motors
#6 (permalink)
| | Gear Jammer...
| Sounds like bad injectors, They do have a type of pvc valve on the front of the engine but not like the lly's do!
__________________ 05 Chevy 2500HD dark blue reg cab ZF-6 speed/W South Bend Clutch ,Power by EFI Live W/Dsp2 , PPE GT4094R, ATS CP3x2, Modified Volant intake, MBRP front pipe, 4" side pipe, Holley Blue lift pump, Isspro gauges,Cognito Braces, SD Centerlink, Caltracs, ATS Tie Rod Sleeves Best ET 12.53@ 109 mph 04.5 Chevy 2500HD, silverbirch, D/A, CC/SB , EFI live, SCIV w/ATS 5Star converter,McRat shim mod, Wicked Diesels modded FPR, Kennedy dual lift pump, Modified Volant intake, Cognito Braces,CUD tie rod Sleeves, EGR BLocker,Diamond eye Down pipe, 4" dual exhaust, Elocker, MA Tcase Fix, B&W GN Hitch Best ET 13.53 @ 101mph |
07-04-2008, 09:59 PM
eBay Motors
#7 (permalink)
| Ya I agree with everyone for the injectors!
How many miles are on yours? I wonder if its still under warranty
07-05-2008, 06:04 AM
eBay Motors
#8 (permalink)
| | Junior Member
| 90,887 miles. I have seen reading thru the postings, they have extended that warranty to 200,000 miles on the injectors. |
07-07-2008, 09:28 AM
eBay Motors
#9 (permalink)
| | DuramaxForum Veteran
| Yeah, you'll be happy once the new injectors get put in. It'll run like a top, and no leaky oil anymore. It was probably oil overflow, from having fuel in the oil due to bad injectors. |
07-07-2008, 01:20 PM
eBay Motors
#10 (permalink)
| | Junior Member
| Chevy called, injectors bad, replacing under warranty, have to pay for fuel filter and oil change. I work on diesel's all day long, and this one had me baffled. At first truck was not lossing mileage or horse power, oil felt and smelled fine, and just heavy dripping out of blow bye tube. 100 miles later, oil over filled, and oil/diesel on the ground time for the shop. I have Ford 7.3, Chevy 6.6, and smaller 4 and 3 cyl Diesels at the house.. Plus work 3rd shop for Uncle Sam. (63B) Thanks for every ones post an help. |
| Advertisement
