Turbo Vane Position Sensor - Chevy and GMC Duramax Diesel Forum
post #1 of 25 (permalink) Old 10-18-2010, 02:02 PM Thread Starter
Where are you guys finding them for $300? I keep seeing threads about guys buying them for that cheap but the local stealership here tells me $688!
Help me out if someone knows.
2007 Duramax Crew Cab LT LBZ
285/75/16 Toyo MT's
Edge Evolution Race CTS
Diamond Eye 4" Turbo Back
Coming soon...
Transgo Jr
PNW_Smoker is offline
post #2 of 25 (permalink) Old 10-18-2010, 02:13 PM
Stupid Has The Balls
Odyssey25013's Avatar
gmpartsdirect.com
Ben
2006 LLZ LT3 EC/LB
"Going for Broke"
Some Expensive Parts, Good Times, Busted Knuckles, Long Nights and Fancy Gauges So I Can Watch While I Blow Things Up
Special Thanks To Ben Tyler at BT DieselWorks, LLC. For All The Help and Hard Work
Odyssey25013 is offline
post #3 of 25 (permalink) Old 10-18-2010, 09:05 PM
DuramaxForum Guru
dukcaln's Avatar
yeap.....gmparts direct is where I got mine....... $400 and some change compared to the stealership
04.5 LLY ECSB 4WD Ram Air Hood & Tonneau, 3" Drop, Fox 2.0 Shocks, 285/55r20 Coopers & XD Grenades , Kryptonite Tie Rods, Kryptonite SS Center Link, Kryptonite Death Grip Idler & Xtreme Idler Support w/Weld In Gusset, Kryptonite T-Case Brace, HSP Intake, HSP Turbo Inlet, HSP Hot-Cold Pipes, FASS 150 w/Beans Sump, PPE Fuel Rail Mods, Built Trans w/Precision ML, Idaho Robs EFI Live - 1/4 @ 13.01 - 103.8mph
dukcaln is offline
post #4 of 25 (permalink) Old 10-19-2010, 07:50 AM Thread Starter
Can someone hook me up with a picture of the sensor and a part number? I looked un the turbo last night but saw multiple wiring connnectors.
285/75/16 Toyo MT's
Coming soon...
Transgo Jr
post #5 of 25 (permalink) Old 10-19-2010, 08:16 AM
Quicker Then Brian!
RedBowTies88's Avatar
damn you can usually get a whole used turbo complete with sensor for 3-400
Beech - 05 LLY CC/SB 4x4
12.31@108.57 On stock turbo and fuel system
Thanks to,
Big Dipper, Efilive, Calvert, Precession Converters, Nick@Duramaxtuner, Eaton, Pureflow, and Falken
RedBowTies88 is offline
post #6 of 25 (permalink) Old 10-19-2010, 08:25 AM Thread Starter
That would be nice. I'll have to check the local U Pull It.
285/75/16 Toyo MT's
Coming soon...
Transgo Jr
post #7 of 25 (permalink) Old 10-19-2010, 08:52 AM Thread Starter
OK found the part number on anohter thread here. It's Part #12635324 does anyone have a picture of where this sensor is located?
285/75/16 Toyo MT's
Coming soon...
Transgo Jr
post #8 of 25 (permalink) Old 10-19-2010, 09:06 AM Thread Starter
I found this on another forum. I found it helpful.
LBZ Turbo Vane Position Sensor Replacement
I recently had the vane position sensor go out on my 07. The symptoms were that there was hardly any boost between 1500-2500 RPM's. once you hit over 2500 RPM's it seemed to get full boost instantly. Another symptom was at idle, the vanes in the turbo would open and close all the time... This made it sound like engine would gain RPM's and then idle back down.
For an LBZ Duramax there are 3 options for vane position sensors:
1. GM# 98011739 - Vane Position Sensor for LBZ Duramax
2. GM# 98061570 - Vane Position Sensor for LMM Duramax
3. GM# 12635324 - Vane Position Sensor, Supersedes LBZ and LMM #'s
The prices vary for each of the parts:
1. GM# 98011739 - $230 up to $389
2. GM# 98061570 - $211 up to $357
3. GM# 12635324 - $400 up to $506
(These prices are from different online GM parts distributors and local dealers)
Currently GM# 98011739 (LBZ) is no longer available. As of late Oct- early Nov 09, GM# 12635324 (New Part #) is not yet available for sale. It is waiting to be approved by GM for the sale of that part.
I used GM# 98061570 (LMM) because it was available and cheaper than the new release part.
Removal of old Sensor:
1. Remove resonator from the top of the intake
2. Follow wire out of the top of the turbo down to the drivers side of the block
3. Unplug the sensor
4. Using a 1" Crows Foot, a 3/8" ratchet, and 6" extension; loosen and take out the sensor
Installation of new sensor:
1. Using a 1" Crows Foot, a 3/8" ratchet, and 6" extension; tighten sensor to 21.5-24.9 N.M of torque (15-18 Ft. Lbs)
2. Run wire down to the plug on the drivers side (place in a safe route so that the wire will not be harmed)
3. Plug sensor in
4. Re-install resonator on the intake
5. Start the vehicle and check to make sure everything is in working order
6. Enjoy
285/75/16 Toyo MT's
Coming soon...
Transgo Jr
post #9 of 25 (permalink) Old 10-19-2010, 09:21 AM
B Rack's Avatar
Use there anyway to test the sensor? I don't what to buy one if there is no need!
Bracken from Spudville
04.5 LLY
EFI'D
6" stack
Sleeves
33in cooper stt's
- EGR Blocked - AFE Turbo MP - PCV Re-routed
Originally Posted by Diesel Dan View Post
Get a speedometer with two marks: off, and Haulin' ass
B Rack is offline
post #10 of 25 (permalink) Old 10-19-2010, 10:21 AM Thread Starter
I'm going to take one off a buddies truck tonight and swap it out to see if my problem goes away.
285/75/16 Toyo MT's
Coming soon...
Transgo Jr
