Old 06-25-2008, 07:40 PM   eBay Motors   #1 (permalink)
bajafishing
Points: 216, Level: 4
Points: 216, Level: 4 Points: 216, Level: 4 Points: 216, Level: 4
Activity: 0%
bajafishing's Avatar
couple more ?'s for you guys...
After hitting up the 911 forum and getting some proper battery advice, i was able to get my truck started and running today. I also cleaned and the intake and the car seems to have a a bit more response.
Next step is doing the fuel filter. I checked out jpt's fuel filter write up which was really well done. I plan to tackle that next. Thanks jpt. Anyways I noticed that jpt's truck had something my truck is missing...
Notice the 2 black plastic caps on the plumbing (nothing to do with the fuel filter). Anyways i am missing one of those caps and have noticed that i am leaking fluid when i run the ac. Any clues on where to find a replacement? Or is it missing for a reason? I just purchased this modified 03 duramax and am trying to learn about it. Thanks.
Ill be posting pictures soon!
bajafishing is offline   Reply With Quote
Old 06-25-2008, 07:45 PM   eBay Motors   #2 (permalink)
daddysLBZ
Highway travler!!
Points: 6,278, Level: 33
Points: 6,278, Level: 33 Points: 6,278, Level: 33 Points: 6,278, Level: 33
Activity: 63%
Activity: 63% Activity: 63% Activity: 63%
daddysLBZ's Avatar
The valves are not supposed to leak,when in workin order,is the a/c cooling good??
MINE2006 GMC 2500HD4x4 sb cc LBZ!Got a couple lil mods,more to follow
[color="Blue"]02 GMC 1/2 ton,2wd,5.3 power{Mama's ride}
87 SS Monte Carlo 77k[orig!]
78 Malibe [2dr.]350/350
WORK RIG:03 YukonXLHypertech tuned!!310k miles!
The left lane is used to pass,so get over,or we'll run over ya asssss!!1996 Impala SS on the way!!!
Old 06-25-2008, 07:50 PM   eBay Motors   #3 (permalink)
corjc
Points: 1,066, Level: 12
Points: 1,066, Level: 12 Points: 1,066, Level: 12 Points: 1,066, Level: 12
Activity: 0%
corjc's Avatar
you can get them from any parts store they have o rings in them to stop small leaks there should be nothing coming out of them
2007 LMM
6 inch pro comp lift
dick cepek dc-1s
halo projector headlights
l.e.d tail lights
billet grill
billet bowtie
corjc is offline   Reply With Quote
Old 06-25-2008, 07:51 PM   eBay Motors   #4 (permalink)
dmax500
Points: 1,753, Level: 17
Points: 1,753, Level: 17 Points: 1,753, Level: 17 Points: 1,753, Level: 17
Activity: 2%
Activity: 2% Activity: 2% Activity: 2%
dmax500's Avatar
is it the big fitting or little fitting on your ac system?
2002 Crewcab short box 3/4 tonHD lb7 W/Allison stock, ATS DIESEL E-POWER programmer, 5" Jeg's Subway tunnel exhaust straight piped, cranked up torsion bars. PPE pyro and boost gauges coming next month TTS Lift pump and filter and water seperator in the future
dmax500 is offline   Reply With Quote
Old 06-25-2008, 08:07 PM   eBay Motors   #5 (permalink)
bajafishing
Activity: 0%
this is the problem area, just appears to be a missing cap... I believe that is what is causing the fluid leak?
Old 06-25-2008, 08:10 PM   eBay Motors   #6 (permalink)
daddysLBZ
Highway travler!!
Activity: 63%
daddysLBZ's Avatar
As mentioned above,the o-rings retain pressure in the system..Not havin the cap on will not cause it to leak,the o-ring prob is shot
Old 06-26-2008, 12:08 AM   eBay Motors   #7 (permalink)
Tow Master
Late Night Post Whore
Points: 12,368, Level: 48
Points: 12,368, Level: 48 Points: 12,368, Level: 48 Points: 12,368, Level: 48
Activity: 89%
Activity: 89% Activity: 89% Activity: 89%
Tow Master's Avatar
There is a core inside the fitting exactly like the valve core on a tire. The core could be loose. The cap is probably missing from a garage charging the a/c and forgetting to put the cap on. There is alot of pressure in there so the cap wouldnt stop the leak though. If you want just remove the oter cap that you have and put it on that fitting to see if it doesnt leak.
Jason
2006 Silverado Shortbed Crew Cab LBZ
Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights
4 Kicker 10in Subs & Punch 250amp in 2 custom boxs. Autometer Ultralite II Pyro & EGT gauges with pillar pod
MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2
Lost Kitty Reward if found!!
1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake
Old 06-26-2008, 07:51 AM   eBay Motors   #8 (permalink)
gr8shot
Points: 2,301, Level: 19
Points: 2,301, Level: 19 Points: 2,301, Level: 19 Points: 2,301, Level: 19
Activity: 8%
Activity: 8% Activity: 8% Activity: 8%
gr8shot's Avatar
I don't want to sound like a moron here, but are you sure its not just the condensation/water dripping down to the ground that your thinking is the leak? If your a/c is blowing cold air then I wouldn't worry about it. But then again I'm no GM tech either.
Old 06-26-2008, 08:53 AM   eBay Motors   #9 (permalink)
K9Duramax
Points: 831, Level: 11
Points: 831, Level: 11 Points: 831, Level: 11 Points: 831, Level: 11
Activity: 1%
^^^^Was wondering the same thing- Can still get a cap from a parts store (will help keep crap out of the AC port anyway). No signs of any oil leaking from the port, so don't believe that it is leaking from there.
'05 CC/SB, Stock with the exception of KN Cold Air Intake, now added PPE Tuner (more to come......), damn cat finally fell off, finally finished off the rest with 4" SS Magnaflow
K9Duramax is offline   Reply With Quote
Old 06-26-2008, 09:18 AM   eBay Motors   #10 (permalink)
n0useforaname
Knows your Mom
Points: 6,643, Level: 34
Points: 6,643, Level: 34 Points: 6,643, Level: 34 Points: 6,643, Level: 34
Activity: 100%
n0useforaname's Avatar
haha..funny. My wife freaked out last weekend because we were 5 hours away from home and it was 91 degrees out. We were in a parking lot and the condensation was pouring off mine, and she thought my truck was shot. Haha....I acted like we were stranded and I thought she was going to cry. Then I told her the truth, she punched me and we went home. Next time it does that....put your fingers in it and smell them...see if it's water.
RIDE: 07 Chevy CC LBZ / 6 Speed
LIFT: Ready Lift Leveling Kit
STARTER: VIPER 2 Way w/ Turbo Timer
ADD ONS: H1 Halo Projector headlights, Back up Camera, Dee Zee running boards, Chrome Billet Grill, ExTang Solid Fold Tonneau Cover, Line of Fire w/reverse, custom bug shield/vent shades, TomTom GPS
TIRES/WHEELS: 265/75-16 Grabber AT2 Tires on 16x8 ATX series Teflon Coated Wheels
EXHAUSTS: BANKS Monster Dual Exhaust, EGR blocked & CAT removed with MBRP replacment pipe.
CAI: BANKS Ram Air
n0useforaname is online now   Reply With Quote
