Does anyone know of a website or even the bulb numbers for the running lights on my 04 Sierra? i.e the bumper running lights specifically.
I would like to convert them to LED bulbs but need the part numbers to swap them out!
Thanks!
__________________ 2004.5 GMC 2500HD -9 DZL NV- Hog 4" SS Turboback w/6" SS Polished Tip, AFE Stage II Intake, EGR Block and Finger Stick, Resonator Plugged, PPE Fuel Release Valve Shim Kit, TTS Dual Lift Pumps, Quadzilla Stealth2
Pioneer In Dash DVD, CD, MP3, and NAV, Boston S60 Internals all around, 10" JL W3 Sub, JL 500/1 Amp, Custom Under-Seat Non-Ported Box, Triple Pillar w/Autometer Sport Comp II (EGT, Oil Temp, BOOST), 15% Tint Up Front
285's BFG A/T, ArmorThane Spray-in Bedliner, Extang R/T Tonneau Cover, Black Step Tubes, Allison 5500 Badges, Recon LED Big Rig Kit, Red Varad Expansion LEDs, Recon LED Smoked Cab Lights, Black LED Third Brake Light, LED Line of Fire Under Tailgate
No just the ambers and the two running lights in bottom bumper lights.
The DRL lights and the amber blinker bulbs are 3157's the little wedge bulbs at the side of the housing are 194's. Just a word of caution since I did this and feel like passin on the info, The LED replacement bulbs will work fine in the DRL spot but if you plan to put LED bulbs in place of the amber blinkers you will need to get an LED load equilizer for each bulb. I think they are around $5.00 at autozone etc. If you don't the LED bulbs will make your blinkers blink really fast like when you have a bulb out.
__________________ 05' Dmax LLY CC SB, 6in. Fabtech with Heavy duty tie rods,
6000K HID headlights & fogs,
Upcoming mods: Lift pumps, Fully built tranny
On the Way: PPE intake manifold w/EGR delete
I was planning on just putting an electronic flasher in place in my fuse box. Wont this correct the "Fast blink" problem?
I would think that would take care of it since, you doing it at the the fuse rather than right by the bulb. I can't tell you for sure but that ought to take care of it. As to Mtnbke question about the dash lights I am still lookin cause mine have the same problem.
I could not find an electronic flasher for my truck. I bough my LED's form this place www.autolumination.com Tail Light Brake Light Turn Signal LED Bulbs I also bought the load equalizers from him. I put LED bulds everywhere in the truck exept the Dash. you have to solder all the lights out and back in and have not had time yet. Just a warning I have burnt out 3 sets of LED driving lights. On his site he says LED's are not ment for DRL.
__________________ John
EFI LIVE with McRat tune, DPS5, PPE Lift Pump, 4inch Turbo Back Strait Piped MBRP Duals, EGR block off, AFE stage 2 intake, Turbo resonator blocked off, 6000k HID kit, 305/75/16Super Swampers on stock rims, Auto Meter boost and pyro gauges, Killer sound system, Limo tint all the way around, Suncoast Stage IV built by me. NO TALKING JUST LINE IT UP
I have the LED ambers, but I don't think I would do DRL with L.E.D.'s. They would look cool, but like Psycho66 said, you will burn them more than you like.
__________________ RIDE: 07 Chevy CC LBZ / 6 Speed LIFT: Ready Lift Leveling Kit STARTER: VIPER 2 Way w/ Turbo Timer ADD ONS: H1 Halo Projector headlights, Back up Camera, Dee Zee running boards, Chrome Billet Grill, ExTang Solid Fold Tonneau Cover, Line of Fire w/reverse, custom bug shield/vent shades, TomTom GPS TIRES/WHEELS: 265/75-16 Grabber AT2 Tires on 16x8 ATX series Teflon Coated Wheels EXHAUSTS: BANKS Monster Dual Exhaust, EGR blocked & CAT removed with MBRP replacment pipe. CAI: BANKS Ram Air PROGRAMMERS: BANKS 6 Gun PDA w/Speed Loader --STACKED-- with Quadzilla Stealth 2
Really, I thought that they would last longer... I have LED clearance lights and they have been trucking successfully since I put them on in Nov. of 07.' Thanks for the the help boys!!
