hydroboost leaking - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 11-01-2010, 07:50 PM Thread Starter
ajs2379's Avatar
hydroboost leaking
hey guys, I have a leak that I think is coming from the hydroboost. master and hydroboost are oily and inside the wheel well on the drivers side is also oily. Is the hydro a common problem on these trucks? Do i just need to replace it or is there any parts to fix them? also ive noticed lately that when Im turning the wheel quickly the p.s. pump whines like it is low on fluid. I did a H.B. flush recently hoping that would help the prob but it didnt. I guess im leaning toward the HB, just looking for anyone who has had a similar problem before i go replacing parts! Thanks!
2011 2500 HD CC LB 4x4 Bone stock
ajs2379 is offline
post #2 of 8 (permalink) Old 11-01-2010, 10:05 PM
Killerbee's Avatar
Please post back if you solve your whining issue. It sounds like your flow control valve needs a spring shim. Whining usually comes from resonance stemming from pressure bypass. Increase the pressure with a spring mod, and the whining should stop.
Is it the same kind of whine you hear at the steering limit?
Michael
Killerbee is offline
post #3 of 8 (permalink) Old 11-03-2010, 03:02 PM Thread Starter
ajs2379's Avatar
I dont really have much of a whine at the steering limit...mine sounds like when you do the HB flush on your last turn of the wheel when you first start to get low on fluid. dont really know how else to describe it.
ajs2379 is offline
post #4 of 8 (permalink) Old 11-03-2010, 03:23 PM
LHN...We ARE the Joneses
Itís whining because you have a leak and itís low on fluid in the pump reservoir. Flushing regularly will extend the life, you may have waited too long to start. The unit swap only takes about 30 minutes total and itís easy to do.
The GM part number is 15854059 for a new one.
GMpartsdirect.comís price:
GM PART # 15854059
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $598.90
OUR PRICE: $305.44
Remans can be had for cheaper, but Iíve never tried those.
Hook'em_Horns! is online now
post #5 of 8 (permalink) Old 11-03-2010, 03:24 PM Thread Starter
ajs2379's Avatar
KB, where do I get a spring shim? Also, I checked the steering limit and could hear the slight whine that you mentioned...not the same whine that I have. Dont know If the pump could be going bad also? First thing Im trying to fix is my fluid leak near the the HB...havnt pinpointed it yet.
Thanks!
ajs2379 is offline
post #6 of 8 (permalink) Old 11-03-2010, 03:30 PM Thread Starter
ajs2379's Avatar
Hook'em, It actually kept doing it even after my last hb flush when it was topped off...I thought the flush would take care of it but no luck. wondering if the pump is getting weak or if the shim would help it out?? BTW...how bout that Iowa State football team!?? Sorry!, not very often I get to say that about ISU!!
ajs2379 is offline
post #7 of 8 (permalink) Old 11-03-2010, 04:04 PM
1st thing is to correct the HB prob. If it's leaking where it joins the Master, the seals on the rod are worn and leaking by...you have to replace the unit. When you do, most likely everything else will behave and run normal again.
Football? What's that?
At least we're better than the Cowboys (and I don't mean OSU).
post #8 of 8 (permalink) Old 11-03-2010, 04:31 PM
Firefighter/EMT-B
Firefighter02's Avatar
while you are working on the hb make sure your pressure lines aren't leaking. I just replaced both of my lines, i had the same problem with trying to find a leak, turns out the lines were only half the problem. hb is next.
04 3500 Silverado CC Dually 4x4
Banks Six Gun
Banks Ram Air Intake With Scoop
Banks Monster Exhaust/Turbo Back/Black Tip
All Lights Blacked Out
Moto Metal Black Wheels
Firefighter02 is offline
