I am looking to buy gauges since I am using a Quadzilla 2 programmer and putting on a turbo back MBRP. Does anyone here use the Quadzilla Commander Control System? Is it worth the money if I already need to fork out money on guages?
TyreBoyzdmaxin has the commander i am sure he will let you know if he likes it, i have had a couple local guys running it on fords and they really like it.
__________________ 07.5 Chevy Summit White Reg cab LMM, Quadzilla steath 2, 5" MBRP straight pipe, 5" turn-down DPF Deleted, Cobalt boost & pyrometer, line of fire and ice. 5% tint. Banks Ram air intake.
Meyer Performance & Fabrication, LLC Home of your diesel performance needs. www.meyerperformance.com (812)-344-4421 Tyler Fass Sale for November pm for details.
its not a programmer, and it will not adjust fuel delievery but it will defuel the truck if you have the defuel option on and it reaches the limit you set.
i thought it wa suppose to also but since it reprograms i dont believe it does
I just read the description for it and they make it sound like once you load a program you can make changes with the Commander. Maybe it is just bad wording if it really does not do that.
i just called quadzilla, and they said it will not change the levels becuase it has to reprogram for each tune
my buddy has the commander and it is awesome. i recomend it to everyone. there are certain programers it is compatible with. but overall is def the best monitor on the market. money=commander
__________________ 2002 DURAMAX 6.6 CC LB 4X4 245,000 MILES- PPE XCELERATOR LEVEL 4- 5"TURBO BACK W/ 6" TIP- INTAKE W/ 2" RESONATOR PLUG- 285'S PPE BOOST VALVE W/ BANKS BIG HEAD WASTEGATE!!! TRANNY=UNBREAKABLE (OK MAYBE IT IS BUT ITS STILL BAAAAD A$$$$$!!!)
Ya its huge display is great and can monitor alot of parameters.
