a finger stick is a eltronic device that blocks the code thrown we you remove the cat on some of the LLY's and LBZ engines not all need them, blocked is when you use a block plate to block the egr valve which stops the exhaust recirculation
__________________ 07.5 Chevy Summit White Reg cab LMM, Quadzilla steath 2, 5" MBRP straight pipe, 5" turn-down DPF Deleted, Cobalt boost & pyrometer, line of fire and ice. 5% tint. Banks Ram air intake.
Meyer Performance & Fabrication, LLC Home of your diesel performance needs. www.meyerperformance.com (812)-344-4421 Tyler Fass Sale for November pm for details.
yes you can tune it out ppe also does to and quadzilla
Does the EGR block plate cause any codes to be thrown? Are there any performance increases to this, or just a healthier motor? How much do the block plates cost?
__________________ 2004 K2500HD, LB7, Ext. cab, short box, 285/75/R16, stock (as far as I know)
The plate makes for a WAY claener intake system on the truck, ive seen as mush as 1/2-3/4 of an inch of soot build up inside the intake on trucks with less than 50,000miles on them! The plate will throw egr codes just the same as the exhaust will on the llys and lbz's. Also it has been seen in some trucks when running boost over stock levels the EGR will push open causing some performance issues, so a plate is needed for this as well!!!
__________________ Caleb
05 D/ZF Reg. Cab
Under the knife to attach a second turbo 04.5 D/A CC/SB- SCIV w ATS 5star converter,Mike L cooler
Waiting install of GT4094R
