i am installing turbo back MBRP on my 07 LMM. I see the two sensors before and after the DPF, but what is the probe looking sensor bofore those? Is tht the EGT temp probe (I'm a newb)? If so I assume I need to drill a hole in my MBRP to keep that working?
No completely remove the sensors and follow the lines to the source and disconnect the harness and remove completely from truck, and do that will all the lines on the exhaust, and make sure you have your quadzilla downloaded with the dpf delete tunes, and proceed with putting the exhaust on and tune the truck with no dpf tune and you will be set.
Tyler
__________________ 07.5 Chevy Summit White Reg cab LMM, Quadzilla steath 2, 5" MBRP straight pipe, 5" turn-down DPF Deleted, Cobalt boost & pyrometer, line of fire and ice. 5% tint. Banks Ram air intake.
Meyer Performance & Fabrication, LLC Home of your diesel performance needs. www.meyerperformance.com (812)-344-4421 Tyler Fass Sale for November pm for details.
Actually I just looked again. I have 2 pieces of tubing and 2 probes one of each on each end of the DPF. I assume I can remove all of these since I am doing a dpf delete. Can anybody confirm this for me?
not a problem and just remove all of them and you will be fine, and if need help give me a call.
Help.....For the life of me I cannot get the front down pipe Cat piece off of the truck. It is like a puzzle that will not end. I have taken the band clamp off, removed the transmission hanging bracket, but I cannot find a way to wiggle that piece out from under the truck. Any advice.............
take a flow jack and raise the front end up and then slide out from the front
