I have an 03 and have been having problems with my battery going dead. Yesterday i was cleaning the inside and had the doors open for about an hour. went to start and battery was dead. Two weeks ago had radio on with key on acc for 30 min and same thing happened. Batteries where tested and came out fine. does anyone know what could be going on?http://www.mysmiley.net/imgs/smile/sign/sign0085.gif
Did you check the alternator. You may not be charging properly
__________________ 06 2500 CREW CAB 4X4 LBZ
4" DIAMOND EYE EXHAUST, KITTY RAN OFF!!!
DIABLO @ 120HP. 285/75 BFG's RUNNIN ON ULTRA 16's
PIONEER HEAD UNIT RUNNIN SCOSCHE AMP W MTX TWINS
AIR BOX IMPELLER REMOVED!! RESONATOR PLUGGED !!!
AUTOMETER ULTRALITE GAUGES IN POD. TRANSGO JR WORK RIG
O7.5 3500 CREW, LMM, ROYAL UTILITY BED
4" DIAMOND EYE EXHAUST.DPF???KITTY?? QUADZILLA PROGRAMMER. MTX AMP AND 10" TWINS IN THE BACK. STEPS,VISORS,BUG SHEILD. AIRBOX IMPELLER REMOVED,RESONATOR PLUGGED,LOTS OF PRETTY DIAMOND PLATE EVERYWHERE
Your alternator should be running between 13.5 and 18 volts you can put a meter on the battery while the truck is running and check the voltage. If it is not charging properly your batteries will not charge completely. So when you let it set with Acessories running you kill the batteries.You can also check the gauge on the dash make sure it is a Little after the center mark. If it is I would start looking at the wiring between the alternator and the battery.
Were the batteries tested seperate (disconnected and tested with meter)? Had a similiar problem and found out that they were testing "each one", however never disconnected them to actually "test them seperate" and see the condition of them individually.
__________________ '05 CC/SB, Stock with the exception of KN Cold Air Intake, now added PPE Tuner (more to come......), damn cat finally fell off, finally finished off the rest with 4" SS Magnaflow
Hmm Its probably your batteries just getting old. Like stated above where they tested seperatly?
Usally when they test the battery they put a load on it for a few seconds and see if the batterys volts drop below 12 volts. Yours might be holding for a few seconds and dropping over time. Id say replace them especially if there the OEM batteries.
__________________ Jason 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 4 Kicker 10in Subs & Punch 250amp in 2 custom boxs. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 285/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake
My 92 began doing the same last month. I had Interstate check both OEM batteries, the guy said both tested good.
Two weeks later-dead again. I returned to Interstate, this time watching the guy test batteries. He never disconnected both batteries, only one gnd at a time, same procedure when replacing each. He stated this was normal procedure and completely accurate. Anyway, both OEM batteries were shorted.
That's when he told me buying higher CCA batteries than OEM size was a waste of money. Stopped by my local Chevy service dept. and asked service manager (who BTW recommended Interstate batteries) about battery CCA. He verified the OEM size comment by Interstate guy this way:
"Larger CCA batteries, in the same size case always have thinner components packed into that same size case, which can mean premature battery failure or shorter lifespan".
__________________ 2002 K3500 D/A LB, CC, black W/ blacked out lighting, stock. Tows a 40' fifth wheel RV (15.5K#) effortlessly.
