Old 07-06-2008, 11:40 AM   eBay Motors   #1 (permalink)
arendj26
Points: 629, Level: 9
Points: 629, Level: 9 Points: 629, Level: 9 Points: 629, Level: 9
Activity: 0%
Injector pump
Where is the injector pump located on the truck any help would be appreciated.
2006 D-Max LBZ crew cab short bed
K&N Air filter Kit
4" Exuast
Egde juice with Attitude
Front end leveling Kit
arendj26 is offline   Reply With Quote
Old 07-06-2008, 11:49 AM   eBay Motors   #2 (permalink)
deeretracks
Complaint Dept.
Points: 5,188, Level: 30
Points: 5,188, Level: 30 Points: 5,188, Level: 30 Points: 5,188, Level: 30
Activity: 41%
Activity: 41% Activity: 41% Activity: 41%
deeretracks's Avatar
On the front of the motor.
Craig
2001 Chevy, 4 door, short bed,D-Max, 2 wd.
Spacial Thanks goes to the person in the WAL-MART parking lot for installing it for me,
Old 07-06-2008, 11:56 AM   eBay Motors   #3 (permalink)
arendj26
Activity: 0%
Any idea what would be leaking fuel in the back of the motor
K&N Air filter Kit
4" Exuast
Old 07-06-2008, 03:52 PM   eBay Motors   #4 (permalink)
daddysLBZ
BLOWIN SMOKE 24/7!
Points: 4,087, Level: 26
Points: 4,087, Level: 26 Points: 4,087, Level: 26 Points: 4,087, Level: 26
Activity: 100%
daddysLBZ's Avatar
I tried to let him know that.He has a bad leak at the rear of motr.Is it the FFH leaking???
2006 GMC 2500HD4x4 sb cc LBZ!!!52k
2002 GMC 1500 2wd x-cab-sb 5.3l..Wife drives
1987 89,000k 305H.O. 700-r4
1978 Malibu[2dr]350/350hp TH-350 trans
Mods w/LBZ... Full straight piped [no cat,no muff!!]
Superchip Flaspq,res mod/,285M/T tires
:Edge GONE,Bullydog SOLD,thank God!!EFI soooooonnnn!![SIGPIC]
Old 07-06-2008, 04:30 PM   eBay Motors   #5 (permalink)
daddysLBZ
BLOWIN SMOKE 24/7!
Activity: 100%
daddysLBZ's Avatar
I looked for ya in the fuek leak thread,did you get a flashlight and get under the truck?The IP is in the front as I mentioned,if you def know it's a leak at rear of engine,then run the thing,and inspect,sometimes the only way to find a leak is to really look closely at the fuel lines,also I would say if you can pump out half a tank in 10 mins,,Then something has to be pumping it,ya think??You prob have a snagged line or a failed fitting.I bet if ya inspect it throughly,you will find a leak that is that bad.The fuel filter housing comes to mind because the lines run in the place ya describing,if the FFH is leaking down on the bottom and trailing somewhere,how else would you find the leak other than look??Hope ya get it fixed,fuel is exp enough...
Old 07-06-2008, 06:52 PM   eBay Motors   #6 (permalink)
arendj26
Activity: 0%
I looked i pulled off the plastic wheel well so i could get a good look at the FFH and its not there. Then i pulled of my down pipe to see if i could see anything else. And with the flashlight i can see that it comes from above the starter. I have a guy tell me just today that the injection pump is in the back of the engine. I want to know if that is true or not. He siad his friend had the same thing go out and it was the injection pump but you tell me its in front of the engine. So i am not sure.
K&N Air filter Kit
4" Exuast
Old 07-07-2008, 01:49 AM   eBay Motors   #7 (permalink)
DuramaxBoy
Points: 175, Level: 3
Points: 175, Level: 3 Points: 175, Level: 3 Points: 175, Level: 3
Activity: 2%
Activity: 2% Activity: 2% Activity: 2%
The injection pump is forward of the turbo.
DuramaxBoy is offline   Reply With Quote
Old 07-07-2008, 05:10 PM   eBay Motors   #8 (permalink)
arendj26
Activity: 0%
injection pump
If i have to get a new injection pump is there any recomendations.
K&N Air filter Kit
4" Exuast
Old 07-07-2008, 06:05 PM   eBay Motors   #9 (permalink)
Maverick684
Points: 3,230, Level: 23
Points: 3,230, Level: 23 Points: 3,230, Level: 23 Points: 3,230, Level: 23
Activity: 5%
Activity: 5% Activity: 5% Activity: 5%
Maverick684's Avatar
You might take a look at industrial injection. While your replacing it you might as well get one that flows a little more.
05' Dmax LLY CC SB, 6in. Fabtech with Heavy duty tie rods,
6000K HID headlights & fogs,
Upcoming mods: Lift pumps, Fully built tranny
Maverick684 is offline   Reply With Quote
Old 07-07-2008, 06:16 PM   eBay Motors   #10 (permalink)
Maverick684
Activity: 5%
Yeah injection pump is most defintely at the front of the engine. Just keep checkin you'll find the leak.
