I have an 04 duramax crew/dually/4x4 - I put on an aftermarket exhaust from banks and a K&N aur filter. I have had no problems so far, but I have recently noticed more soot coming from my exhaust that had not been there before. The exhaust has been on from about 30,000 miles and it now has 135,000 miles.
Any ideas on what would start this to happen ? and what I can do to fix it ?
i woulde clean your airfilter or get a new one dirty air filter, would let if have as much air to help burn the fuel
__________________ 07.5 Chevy Summit White Reg cab LMM, Quadzilla steath 2, 5" MBRP straight pipe, 5" turn-down DPF Deleted, Cobalt boost & pyrometer, line of fire and ice. 5% tint. Banks Ram air intake.
Meyer Performance & Fabrication, LLC Home of your diesel performance needs. www.meyerperformance.com (812)-344-4421 Tyler Fass Sale for November pm for details.
__________________ John
EFI LIVE with McRat tune, DPS5, PPE Lift Pump, 4inch Turbo Back Strait Piped MBRP Duals, EGR block off, AFE stage 2 intake, Turbo resonator blocked off, 6000k HID kit, 305/75/16Super Swampers on stock rims, Auto Meter boost and pyro gauges, Killer sound system, Limo tint all the way around, Suncoast Stage IV built by me. NO TALKING JUST LINE IT UP
x3 on the air filter. Also while your in there messin around change the fuel filter if you haven't lately.
__________________ 05' Dmax LLY CC SB, 6in. Fabtech with Heavy duty tie rods,
6000K HID headlights & fogs,
Upcoming mods: Lift pumps, Fully built tranny
On the Way: PPE intake manifold w/EGR delete
Thanks for the info guys - the air filter is fine - I'm goin with the fuel filter change, it has a few miles on it and maybe I picked up a bad batch of diesel - I'll let ya know.
Hmm ya the fuel filter and a fuel additive might help as well.
Might also be time for some spark plugs and wires
__________________ Jason 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 4 Kicker 10in Subs & Punch 250amp in 2 custom boxs. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 285/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake
Why didn't you recommend any brand wires,or plugs.He will need the correct ones!!
__________________ MINE2006 GMC 2500HD4x4 sb cc LBZ!Got a couple lil mods,more to follow
[color="Blue"]02 GMC 1/2 ton,2wd,5.3 power{Mama's ride}
87 SS Monte Carlo 77k[orig!]
78 Malibe [2dr.]350/350 WORK RIG:03 YukonXLHypertech tuned!!310k miles! The left lane is used to pass,so get over,or we'll run over ya asssss!!1996 Impala SS on the way!!!
Its usually best to pick them up at the autoparts store. They have different varietys depending on wher you go. You'd think by now someone would of come up with some high performance plugs n wires
The person who comes up with a good set of plug and wires that will give a meaningful boost to a Dmax will be a wealthy person indeed. Pretty inventive as well.
__________________ 2001 Club Cab 2500HD 4x4 D/A
Banks 6 Gun with speed loader, Diablosport Predator for speedo correction, PPE boost valve, PPE lift pump (soon to be installed), Grille guard, Moon visor, Leveling kit, 285-75-16 A/T TA's, Grand Rock stacks, spray in bed liner
1993 Z28 M6
Lloyd Elliot ported heads and intake, LE 1.6 cam, 1.6 RR, 52MM BBK TB, 30lb/hr injectors, PCMforless tune, K&N FIPK, Pacesetter longtubes, Pacesetter ORY, Magnaflow catback -the cat Dynaspark billet optispark, RAM kevlar clutch, 275-45-17 pirellis on 17x9.5 ZR1's up front, 315-35-17 on 17x11 ZR1 rears
