Old 07-21-2008, 12:57 PM   eBay Motors   #1 (permalink)
jwilson7
Points: 108, Level: 2
Points: 108, Level: 2 Points: 108, Level: 2 Points: 108, Level: 2
Activity: 0%
vibration
Anyone had any probs with ats torque convertors vibrating at idle. I have had several diesel mechanics look at my duramax but everyone says the motor is jam up. The flexplate is in perfect condition, not sure exactly what to do at this point it almost has to be the convertor i think. can anybody help?
jwilson7 is offline   Reply With Quote
Old 07-21-2008, 03:49 PM   eBay Motors   #2 (permalink)
r.laz
Points: 3,004, Level: 22
Points: 3,004, Level: 22 Points: 3,004, Level: 22 Points: 3,004, Level: 22
Activity: 2%
Activity: 2% Activity: 2% Activity: 2%
r.laz's Avatar
I read where, a famous and well respected tranny man, sugested to remove every other bolt on the flex plate....Perhaps he can jump in and provide some real advice.
08 Sierra WT CC SB
Steel Gray 4x4
PPE RACE
Modded OEM AirBox/PCV Reroute/4" MBRP into 5" MagnaFlow/ EGR BLOCKED
Isspro EGT/Boost gauges Cognito Leveling Kit/HD Tie Rods Pitman/Idler Support Brackets/Bilsteins
Pirelli Scorpion ATR 265/75/16 Coated OEM Wheels
Factory Oval Steps/Rhino Lining
Klein Air Horns (4)/ViaAir 150 psi 2g compressor
r.laz is offline   Reply With Quote
Old 07-22-2008, 10:58 AM   eBay Motors   #3 (permalink)
jwilson7
Activity: 0%
what does that do for me, is that safe? Im almost afraid its gonna mess something else up internally. The trucks down right now due to other tranny issues, yea its been a nightmare!!
Old 07-23-2008, 06:30 AM   eBay Motors   #4 (permalink)
rock04max
Points: 1,098, Level: 12
Points: 1,098, Level: 12 Points: 1,098, Level: 12 Points: 1,098, Level: 12
Activity: 0%
you need to check really good. I've replaced three flexplates. Theres either a crack that you cant see or the bolts are coming loose and soon start rubbing on the block. Does the truck shift any different?
Does it sound like you have an exhaust leak? I finally got a flex plate that was 90% hand made. What a difference. Shifting, towing, HP transfer, etc....
04.5 LLY crew cab, PPE program, custom air box, 4in. turbo back exhaust, and boost controller.
rock04max is offline   Reply With Quote
Old 07-23-2008, 01:35 PM   eBay Motors   #5 (permalink)
jwilson7
Activity: 0%
will the flexplate give you problems even if your not adding much power? all i have is an edge module and theats unit.werecan i get one of these handmade flexplates or something similar. thanks for all the help guys i really appriciate it.
Old 07-25-2008, 05:49 AM   eBay Motors   #6 (permalink)
rock04max
Activity: 0%
You would have to go to a good machine shop and see if they will work with you. It takes lots of hours. Check your driveshaft it may be bolted on unbalanced.
Old 07-25-2008, 06:21 AM   eBay Motors   #7 (permalink)
gr8shot
Points: 1,817, Level: 17
Points: 1,817, Level: 17 Points: 1,817, Level: 17 Points: 1,817, Level: 17
Activity: 43%
Activity: 43% Activity: 43% Activity: 43%
gr8shot's Avatar
the driveshaft shouldn't be moving when he's idling. unless its in gear, but even then it shouldn't be spinning fast enough to vibrate.
