| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | Transmission Shop Discuss the Allison OEM, After Market, And the ZF-6 speed. |  | |
07-23-2008, 06:18 PM
eBay Motors
#1 (permalink)
| | Member
| replacing the external tranny filter When you replace the external tranny filter is as simple as removing the old one, filling the new one with the proper tranny fliud and screwing it back on. What tranny fluid should I ues? Is it like when changing the oil and filling the filter before you fill the oil pan so there is oil right there at start up????
__________________ 04 Crew Cab 4X4 Short bed, LB7, LS trim, Window tint, PRIME chrome five spoke wheels, K&N air filter, no other performance add ons. |
| Advertisement
07-23-2008, 06:31 PM
eBay Motors
#2 (permalink)
| | Senior Member
| If you are leaving all the original fluid in than just use Dexron III approved for H specification. DON'T FORGET the magnet on the top of the old filter!!!
__________________ bob213
2005 GMC Crew Cab SLT 4X4
4" MBRP turbo back
Kennedey air box mod. (ala Hook'em Horns mod)
Diablo Sport Predator/EGR Blocked
BD Exhaust Manifold/PCV Reroute
AutoMeter UltraLiteII Pyro Gauge
Induction Overhaul Kit by "Killer Bee" |
07-23-2008, 06:32 PM
eBay Motors
#3 (permalink)
| | BLOWIN SMOKE 24/7!
Join Date: Mar 2008 Location: Louisiana,60 miles from Gulf!!
| Quote:
Originally Posted by Texas Red DMAX When you replace the external tranny filter is as simple as removing the old one, filling the new one with the proper tranny fliud and screwing it back on. What tranny fluid should I ues? Is it like when changing the oil and filling the filter before you fill the oil pan so there is oil right there at start up???? | You right on the money,that is really all there is to it,don't forget ya magnet,this is on top of ol filter when ya remove..Just replace mag on new filter,fill,spin and check fluid level..Dex 6 is fine to top it off...
__________________ 2006 GMC 2500HD4x4 sb cc LBZ!!!  52k
2002 GMC 1500 2wd x-cab-sb 5.3l.. Wife drives
1987 89,000k 305H.O. 700-r4
1978 Malibu[2dr]350/350hp TH-350 trans
Mods w/LBZ... Full straight piped [no cat,no muff!!]
Superchip Flaspq,res mod/,285M/T tires
: Edge GONE,Bullydog SOLD,thank God!!EFI soooooonnnn!!  [SIGPIC] |
07-23-2008, 07:00 PM
eBay Motors
#4 (permalink)
| | Senior Member
| What Magnet I Changed Mine A Couple Weeks Ago Im Lost On The Magnet Deal.
__________________ 2004 CHEVY LB7 2500HD, CREW CAB, SB. EDGE JUICE WITH ATTITUDE, AFE STG. 2, PPE BOOST VALVE, FASS 95, 4 INCH SILVERLINE, PPE SLEEVES, TOYO MT`S |
07-23-2008, 07:07 PM
eBay Motors
#5 (permalink)
| | BLOWIN SMOKE 24/7!
| Yes I lost mine the 1st time also,they are cheap and just fit on top of the oil filter itself,it is to trap the shavings in the oil...
07-23-2008, 07:17 PM
eBay Motors
#6 (permalink)
| | Senior Member
| I Changed Mine About 1000 Miles Ago, Is It Ok. Also The Old Filter Is Still In The Bucket Of Old Fluid I Will Try And Find The Magent In The Morin, Can I Just Unscrew The Filter On There Put On The Magnet And Just Top Off The Fluid. I Hope The Tranny Is Ok!
07-23-2008, 07:19 PM
eBay Motors
#7 (permalink)
| | BLOWIN SMOKE 24/7!
| Quote:
Originally Posted by catman_05 I Changed Mine About 1000 Miles Ago, Is It Ok. Also The Old Filter Is Still In The Bucket Of Old Fluid I Will Try And Find The Magent In The Morin, Can I Just Unscrew The Filter On There Put On The Magnet And Just Top Off The Fluid. I Hope The Tranny Is Ok! | That is how I found mine,I think the trans will be just fine,get a magnet asap,they are cheap insurance for an exp unit
07-23-2008, 07:24 PM
eBay Motors
#8 (permalink)
| | Senior Member
| I Have Noticed Over The Last Few Days It Sounds Like I Have Something Rattln Around In My Tranny Pan, But It Seems To Be Workn Fine?
07-23-2008, 07:35 PM
eBay Motors
#9 (permalink)
| | BLOWIN SMOKE 24/7!
| Try this while ya wait fer parts to arrive... I don't think it's possible to lose that magnet in the pan,what you could do in the meantime till ya get the magnet,is put a small[3-4 inch]speaker magnet on bottom of filter,but when ya get the magnet,you need to rechange the filter once again as it may have shaving in bottom of filter case,I would use new filter and magnet,jus so everything goes smooth,oh,don't wait too long to resolve the prob,the sooner ya get back in proper form the better off ya are..IMO
07-23-2008, 07:43 PM
eBay Motors
#10 (permalink)
| | Senior Member
| If I Cant Find The Magnet In The Bucket Were Do I Get A New One At, But If I Find The Old One I Can Use It Right.
| Advertisement
