Originally Posted by Hook'em_Horns!
You’re not blocking the rear of your trailer when loading? Working in the Delta, you won’t encounter it but, working in the hills, I think everyone should experience the feeling just once of being half on the rear of the trailer, lifting the rear wheels of the truck off the ground and having her just start rolling away downhill!!!   | Your talking about something that is not fun. We were loading a Cat D5M dozer on a single axle Mack tractor and single axle lowboy when this happened. The truck driver didin't set the trailer brakes, just the tractor brakes and boy did it take off. No fun at all.
__________________ KYLE
