Hey everyone new to the forums and I wanted to say hello. Unfortunately my introduction comes with a problem I am having and hopefully someone has had the same issue and knows of the fix.
I have a 2005 3500 Dually CC LB about 45k miles.
Banks 6 gun tuner with air filter and cat back exhaust
When ever I hit a decent size puddle of water my AC goes out.
Anyone have any ideas? or experieinced this issue before?
do you think it might have to do with the 6 gun module getting wet?
first off welcome to the forum...
first things first uninstall the banks and see what happens.
__________________ James
never heard of this probklem before but i have heard of the banks causing wierd problems.
sevaral of the more popular ones are,truck starting hard or not starting at all and i know of 2 cases where it destroyed the ECM completely,mostly just eletronical problems or causing the gauges to act wierd.i'm not all of the problems that i hear of are caused by the Banks but it makes you wonder when you unistall the Banks and no more problems..Banks isn't the only one that has caused problems like this either.
for the most part Banks has a very good reputation so take this for what it's worth.
If it is not the banks then check out the pressure switch on the condenser and then the one on the evaporator. You could have a loose connection on one of the two sensors causing the system to quit cooling. Or I could ask if its just the fan that quits or if it quits cooling.
__________________ 06 2500 CREW CAB 4X4 LBZ
4" DIAMOND EYE EXHAUST, KITTY RAN OFF!!!
DIABLO @ 120HP. 285/75 BFG's RUNNIN ON ULTRA 16's
PIONEER HEAD UNIT RUNNIN SCOSCHE AMP W MTX TWINS
AIR BOX IMPELLER REMOVED!! RESONATOR PLUGGED !!!
AUTOMETER ULTRALITE GAUGES IN POD. TRANSGO JR WORK RIG
O7.5 3500 CREW, LMM, ROYAL UTILITY BED
4" DIAMOND EYE EXHAUST.DPF???KITTY?? QUADZILLA PROGRAMMER. MTX AMP AND 10" TWINS IN THE BACK. STEPS,VISORS,BUG SHEILD. AIRBOX IMPELLER REMOVED,RESONATOR PLUGGED,LOTS OF PRETTY DIAMOND PLATE EVERYWHERE
