right way to jumpstart the truck - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 04-12-2011, 09:58 PM Thread Starter
07-Dmax's Avatar
Okay, searched forums, read what I could find. seems jumpstarting the truck the wrong way can blow some expensive electronics. so....... what is the best failsafe way to jumpstart our trucks. thats vehicle to vehicle. while we are at it. any special way to charge batterys. dont want to blow ecms or any other electronic part on my truck. too many horror stories on here. just askin for that oh chit moment when it dont start and for others to know just in case. thanks guys. if jumpin thru the battery posts, which battery is best.
2007 chev 3/4 ton ccsb ltz
6" rcd lift, amp research elec steps, mag hitec diff cover, amsoil dual bypass oil filter, bushwacker flares, 295/70/17 toyo m/t, a bunch of go-fast parts I cant name for the time being.
You didnt see me
you cant prove it
I didnt do it
07-Dmax is offline
post #2 of 8 (permalink) Old 04-12-2011, 10:08 PM
ramonday's Avatar
Just make sure you ground black. I don't care what anyone says. I've always done it this way and never failed. Jumped probably a thousand vehicles. Just ground the negative. Always. Never negative it either end. If you must, negative the giving vehicle, but ground the other vehicle.
Batteries are gonna be like good Scotch. Everyone will have their favorite. I use standard cheapass Wally World nEverstarts in mine. Work fine and warrantied for 3 years, no questions asked. I don't expect a mass-manufactured battery to last longer than 3 years. Not my experience.
2004.5 GMC Sierra SLT EC 2500HD 4x4 LLY w/LBZ MP, PCV reroute, EGR blocked, 4" exhaust, PacBrake TR sleeves, DSP5 & EFI-Live w/Idaho Rob tunes
ramonday is offline
post #3 of 8 (permalink) Old 04-13-2011, 01:21 AM
Vanned this place
TheStepChild's Avatar
Read owners manual.
Iirc the book says + to the battery closest to starter, - to frame
Originally Posted by Jeremy Clarkson View Post
Some say he was conceived in a cargo van
TheStepChild is offline
post #4 of 8 (permalink) Old 04-13-2011, 02:56 AM
Mine has a little red box on the drivers side toward the front that has places to connect jumper cables. Open the red box to reveal a nut on a red cable for positive; there is a little flange below that for the negative cable. Black to black negative first, then do the red to red positives. Haven't cooked anything, YET.............
2007 2500 HD Classic LBZ/Allison, standard cab, stone stock, rollup windows, manual door locks, towing and plowing packages with Western plow.
btilghman is offline
post #5 of 8 (permalink) Old 04-13-2011, 03:20 AM
lugnut's Avatar
Jump start - Attach the red lead of the jumper cable to the red post of the battery on the passenger side of the vehicle (closest to the starter). Place the black lead on the engine block (do not attach to the alternator). Attach the other end of the cables to the vehicle providing the assistance. Make sure the engine is running on this vehicle. Attempt to start the vehicle.
Charging w/ battery charger - If equipped, open the red cover on the driver side of the engine near the power steering pump. If charging door is not present, attach charger to battery closest to the starter. 2 charger would be preferable, one for each battery. Attach the red cable of the battery charger here. Attach the black cable of the battery charger to the engine block. Turn the charger on and monitor the progress. When finished, turn the charger off and attempt to start the vehicle. NEVER TRY TO START THE VEHICLE WITH THE BATTERY CHARGER ON! This is most critical on LLY vintage and up. The glow plug control module is sensitive to AC ripple, and can get easily confused. It may cause all the glow plugs to stay on continually and burn them out.
Never arc battery cables near a discharged battery or freshly charged battery. The gases produced in the battery are explosive and you could blow the top of the battery off.
2006 2500HD LBZ 4X4 CC/SB LT3, 265/75R16, Rhino Liner, PCV Reroute, Resonator Plugged, 35w 6K HID Low Beam & Fog Lights, LED Interior Lights, ISSPro Pyro, Boost, & Rail Pressure Gauges in A-Pillar, Cognito Idler/Pitman supports, more to come soon.
1996 K2500 Suburban 7.4L, 265/75R16, Brush Guard, Nerf Bars
lugnut is offline
post #6 of 8 (permalink) Old 04-13-2011, 08:48 AM
jcbDuramax's Avatar
Never arc battery cables near a discharged battery or freshly charged battery. The gases produced in the battery are explosive and you could blow the top of the battery off.[/QUOTE]
holy chit! i didnt know that
2007 chevy lmm LTZ
Z71 midnight blue
4" mbrp dsp5 egr block bf al terrains .
RIP - 05 LLY and Allison 5spd
[/B]
Originally Posted by RedBowTies88;6Z28261
efilive is the easy way out...diehard smokers break out the butt connectors and get shit done
Z
jcbDuramax is offline
post #7 of 8 (permalink) Old 04-13-2011, 09:00 AM
chrisuns's Avatar
Ground to alternator(Considered grounding center for a running vehicle) and positive battery.
chrisuns is offline
post #8 of 8 (permalink) Old 04-14-2011, 03:15 AM
lugnut's Avatar
If you read the fine print on top of your batteries, it says the same thing. Got to be careful around then, or you might be sorry one day.
lugnut is offline
