Power Steering Pump Replacement - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 11-03-2011, 09:22 PM Thread Starter
So I had a leaky seal and was informed by the parts shop that they rarely work well. So here is my write up of how I removed the power steering pump, then removed the pulley and tank then put it all back in again. Let me know what you think!
-Austin-
File Type: pdf Power steering replacement how to 1-3.pdf (373.5 KB, 798 views)
File Type: pdf Power steering replacement how to 4-7.pdf (461.5 KB, 573 views)
'06 Silverado LBZ CCSB
Sweet Ass Walker Evans 2.5" Bore shocks(AWESEOME) - EFI Live DSP 5 (Idaho Rob Style) - 4" MBRP - Transgo Jr. - MA Pump Rub Kit - HID's all around - Nathan Air Chime K5LA - 6 Gallon Onboard 150 PSI - Turbo Down Pipe - ARP Studs - 27" LED Light Bar - AutoMeter Cobalt Gauges
Britax Child Seat
alhouko is offline
post #2 of 9 (permalink) Old 01-26-2014, 05:11 PM
stevewaclo's Avatar
Location: Carson City, NV Proud Participant, Federal Witness Protection Program
Excellent write-up!
alhouko,
Don't know why no one never said thanks for this, but I suppose it's never to late!
Muchas gracias.
I suspect a dirty/jammed pressure relief valve on my pump, but it looks it can only be accessed with the pump out:-(. I'm able to see the nut, but it looks to be >20mm and no way to get a tool on it.
2003 GMC Sierra 2500HD SLE ExtCab CA Emissions; 143k; Allison 1000; 8' bed; AFE/CAI; MBRP 4" Exhaust; Side Tint, 33% VLT, rear, Limo; Smittybilt Stainless Side Nerf Bars; Sprayed-in Bed Liner; MadJack Fuel Filter Access Door; Regular Used Oil Analysis (latest available on request), Blackstone Labs; EGT/Boost Gauges; Dual Chrome Dipsticks, JC Whitney; Stainless Steel fuel filter head bleeder screw; Billet Aluminum Fuel Filter Housing Spacer; Does anybody ever read this s%#t?; Injectors under warranty @ 70k; Smokin' again but mitigated with massive infusions of AC Delco injector cleaner, SeaFoam, Stanadyne and Luqi Moly.
stevewaclo is offline
post #3 of 9 (permalink) Old 01-26-2014, 07:42 PM
franks71vw's Avatar
Ironic I was looking for a write up and find this in power steering yet can't see it on the app... Pictures seem to be a broken link...
From the DF mobile informer-
LB7 Dually 3500 CCLB with Lincoln Diesel Injectors, Ready Lift leveling keys, ProFabTurbo Horn, Bilstein 5100 Front Shocks, BD Performance Manifold, Banks 4" Exhaust, Banks Big Head Waste Gate, PPE boost valve, 235/75/16 stock wheels 1.5" spacers all around, Ghost Fuel pressure gauge 0-60psi, EGT, Boost, DSP5 Key Switch, Moonshine EFI tunes, High Idle MoD, Nictane Adapter with 1r0750 filter, ATP Sleeves, COGNITO Braces
DF DRW CLUB MEMBER #177
My Build/Info Thread
http://www.duramaxforum.com/forum/01...b7-engine.html
franks71vw is offline
post #4 of 9 (permalink) Old 01-26-2014, 07:44 PM
stevewaclo's Avatar
Hmmmm.
Pics open fine on iPad.
post #5 of 9 (permalink) Old 01-26-2014, 07:45 PM Thread Starter
They are .pdf's with writing and pictures. Might need a mobile pdf viewer.
alhouko is offline
post #6 of 9 (permalink) Old 01-26-2014, 07:45 PM
franks71vw's Avatar
This is what pops on my iPhone
post #7 of 9 (permalink) Old 01-26-2014, 07:46 PM Thread Starter
And Steve thanks for the Thanks I wrote this a long time ago!
Britax Child Seat
alhouko is offline
post #8 of 9 (permalink) Old 01-26-2014, 07:53 PM
rms
rms's Avatar
2007 LBZ 4x4 regular cab
S & B Intake - Diablo Predator
285/70/17 Michelin AT's on H2's - 8' Bedslide
Amp Steps - short KYB's - Fumoto
The Arizona Diesel Club
rms is offline
post #9 of 9 (permalink) Old 01-26-2014, 07:58 PM
Dmaxlovr's Avatar
Attachment 301441
Mine too bro. Same as you.
03 CC/ SB
Thanks to all the folks at Lincoln Diesel!!
Brent, Lauren, Aaron and all those behind
the scenes
Mods:
EFI LIVE by Stellar Diesel
Cat filter adapter from Lincoln
PPE Boost valve
Future mods:
Center link brace by Sun coast, Moog pitman/idler
Air Dog 165
Pump rub fix
Noob...no matter how many posts.
This is my Facebook..at least as social as I want to get on the net!http://performancetruckproducts.com/
Dmaxlovr is offline
