How to: Glow plug LMM - Chevy and GMC Duramax Diesel Forum
post #1 of 32 (permalink) Old 03-01-2012, 01:58 PM Thread Starter
lmmduramax's Avatar
I had the No. 7 glow plug go bad after 114,000 miles so I decided to show how to swap it out. It took me 40 mins total (getting tools out and putting them away and taking pictures). If you have ever changed a spark plug then you can change a glow plug. Tools needed = 8mm socket and 12mm socket. The glow plugs are numbered 1,3,5,7 down the passanger side and 2,4,6,8 down the driver side (1 and 2 are the ones closest to the grille). First remove the inner fender and locate the glow plug, its right above the manifold with a small wire running to the top. Unhook the wire using the 8mm socket. Then remove the glow plug using the 12mm socket, then reverse the process using the new plow plug. clear the code, replace inner fender and your done! Very easy to do so no reason to pay the dealer to do it.
Hope this helps!
Brant:
Built & Tuned by Blackout Performance
Black 2008 GMC ccsb
Built tranny, 1058 suncoast
45% injectors
Double batmo s472
Dual pumps
11.80 @ 114mph
lmmduramax is offline
post #2 of 32 (permalink) Old 03-01-2012, 02:15 PM
Word Up
cainer70's Avatar
Send a message via MSN to cainer70
Nice!
LMM Twinz N sum shyt ATP Tuned
02 LB7 to be EFI'd this week.
cainer70 is offline
post #3 of 32 (permalink) Old 05-23-2012, 11:09 PM
wow tht looks alot easier then i thought thanks for the post
m1000snopro is offline
post #4 of 32 (permalink) Old 05-23-2012, 11:35 PM
shaunsteezy's Avatar
how much was the new plug?
2007.5 CCSB Dark Grey Metallic, PPE Hot+2, PPE Guages w/ pillar pod, PPE diff cover, Transgo installed by Ingelwood Trans Mike L, AFE intake, cranked torsions to fit the 33x18 Toyo MT on KMC XDs, Pro Fab DP, 4inch straight pipe w/ 6inch RBP tip exiting in front of rear tire, N-Fab steps powdercoated satin to match the wheels, mesh grill w/ plasti dip bumpers
saving money for the trans!
shaunsteezy is offline
post #5 of 32 (permalink) Old 05-24-2012, 03:35 PM Thread Starter
lmmduramax's Avatar
It's been a little while but I know it was under $30 from my local dealer because no one else had them in stock
Brant:
Black 2008 GMC ccsb
45% injectors
Double batmo s472
Dual pumps
11.80 @ 114mph
post #6 of 32 (permalink) Old 05-31-2012, 11:46 AM
kbar59's Avatar
O'Reilly's has it for $19.99 PART # 61g AC Delco. Pictures for #6 replacement to follow.
kbar59 is offline
post #7 of 32 (permalink) Old 05-31-2012, 12:19 PM
gregking's Avatar
This is really awesome. I have #4 out and I've been putting it off for awhile now. Any pics on how to remove the inner fender?
06 LBZ 2500 LS CC/SB, Insite CTS w/ pyro, Banks Cold air, 4" MBRP, LED rev & dome lights, line-X, Ranch hand bumper, EFI live Idaho Rob, PCV reroute, HID
gregking is offline
post #8 of 32 (permalink) Old 05-31-2012, 12:41 PM
kbar59's Avatar
Use a pair of side cutters to get underneath the plastic plugs just don't cut thru. They should pop out fairly easy. Then it's a 10 MM socket for the bolts as there may be a couple. you will also have to push the plugs up and out of the top for the harness connections. Comes out pretty easy.
2007.5 LMM Chevy 2500HD 6.6l DURAMAX 4x4 Crew
BDS 4.5 lift kit
Dick Cepek DC2's
315x70x17 Dynapro RT03
Banks Ram Air
kbar59 is offline
post #9 of 32 (permalink) Old 05-31-2012, 02:28 PM
kbar59's Avatar
Job completed in less than 1 hour as it had to cool down first. Went back to the parts store and they cleared the code. Life is good. Hope #4 worked out Greg as it was not too bad as long as you are careful not to break the tip inside the motor. Then it's another ballgame all together. Good Luck!
BDS 4.5 lift kit
Dick Cepek DC2's
Banks Ram Air
kbar59 is offline
post #10 of 32 (permalink) Old 06-01-2012, 08:10 AM
gregking's Avatar
I am going to pick up one today and try it this weekend. I got some cheap driving lights for the ranch hand bumper I have that I'm going to install this weekend also. Plus I want to install some LED lights for the boat. I guess I probably better do some land scraping for the wife also.
gregking is offline
