Holly Fuel pump and cat filter DIY - Chevy and GMC Duramax Diesel Forum
Old 11-21-2012, 01:06 PM   eBay Motors  #1 (permalink)
This is my first DIY so bear with me.
I am going to show ya all how I installed my Holly pump and added pre and post filters.
<a href="http://s1283.beta.photobucket.com/user/hvactech08/library/" target="_blank"><img src="http://i1283.photobucket.com/albums/a550/hvactech08/DSCN2486.jpg" border="0" alt="Photobucket"/></a>
Here is the parts list. I may have forgotten a few small parts but should be a complte list
Summit racing parts
1. HLY-12-150 FUEL PUMP The actual pump
2. 2- SUM-2200078B ½” compression fitting -8an male
3. 2-SUM-220847B ½” npt male to -8an male
4. 2- SUM-220890B -8an female to -8an hose
5. SUM-230806S.S. 6’of -8an hose (stainless steel braided)
6. SUM-890023 Fuel pump relay kit, comes with circuit breaker and small piece one might need
Napa Parts
2- FIL 4770 filter head
Filters needed
1 - Cat 1r-0750
1 - Cat 175-2949 or fs1212(fleet guard)
Lowes
2- ½” 90
4- ½” barb to ½” npt
2- 3/8”90* to ½”
2’ ½” fuel hose
4 hose clamps
1.
<a href="http://s1283.beta.photobucket.com/user/hvactech08/library/" target="_blank"><img src="http://i1283.photobucket.com/albums/a550/hvactech08/DSCN2480.jpg" border="0" alt="Photobucket"/></a>
I started off and mounted the filter heads and pump on a bracket I fab’d up. Then I used brass 90* to a barb fitting to hook up the pump and the two filter heads. I have a pre and post filter head because the water separation filter works better on a vacumm side. I mounted this all on the drivers side under the door, only place I could mount since I am a reg cab. The left filter in on the pressure side of the pump and right is coming from the tank.
2.
<a href="http://s1283.beta.photobucket.com/user/hvactech08/library/" target="_blank"><img src="http://i1283.photobucket.com/albums/a550/hvactech08/DSCN2481.jpg" border="0" alt="Photobucket"/></a>
Next I installed the regulator on the outlet of the filter housing mounted parrell to the ground.
3.
<a href="http://s1283.beta.photobucket.com/user/hvactech08/library/" target="_blank"><img src="http://i1283.photobucket.com/albums/a550/hvactech08/DSCN2483.jpg" border="0" alt="Photobucket"/></a>
Now you can run the pressure side hose to a convient spot, I believe each cab confiuration has a litle bit differt fuel line routing. Any way I cut the ½” line and used the compresion fitting to female -8an piece. I made the cut close to the tranny(zf6). I had to remoze a few brackets to get my tubbing cutter in there.
Just find a place that will work good for your exact set up.
4.
<a href="http://s1283.beta.photobucket.com/user/hvactech08/library/" target="_blank"><img src="http://i1283.photobucket.com/albums/a550/hvactech08/DSCN2484.jpg" border="0" alt="Photobucket"/></a>
This is where I was able to instal the other compression fitting. This is the line coming from the tank to the right filter housing. Like stated above just find a convient place to install. Make certin also that the compression fitting is very tight! I had to redo that fitting cause it was dripping slowly.
I don’t have any pics of me makin the hoses and installing the an fitting to the hose, it can be a pain but if you havent done it before just look it up on youtube and it will walk you through the process.
2001 RC/lb lb7 zf6 EFI 120hp tune.
5" exhaust, Custom Boost Valve
Holly Lift pump, Dual Filtration system,Custom Traction Bars
16" method race wheels w/ BFG allterrains
Blad tires and clutch slippage thanks to sheid Diesel extravaganza 2012
hvactech is offline   Reply With Quote
Old 11-21-2012, 01:09 PM   eBay Motors  #2 (permalink)
Just make sure you use Teflon paste on all fittings and that all the AN fittings are super tight!!
Old 11-21-2012, 03:17 PM   eBay Motors  #3 (permalink)
Trimmy's Avatar
None of your pictures are showing up for me
2003 Jetta TDI, 5spd, TDTuning Stage 3 Tune, EGR delete, OMI Intake
Sold: 1999 Quad Cab Short Bed Cummins 4x4 653HP/1412Ftlbs
Billet 47RE, Edge Drag Comp/Smarty, 6x16's, Fass 150, 62/S476 Twins, Spearco Intercooler, o'ringed/ARPs, Ect Ect Ect...
Trimmy is offline   Reply With Quote
Old 11-22-2012, 07:57 AM   eBay Motors  #4 (permalink)
73impala's Avatar
Summit racing parts
Napa Parts
Filters needed
1 - Cat 1r-0750
Lowes
2- ½” 90
2- 3/8”90* to ½”
2’ ½” fuel hose
4 hose clamps
1.
2.
3.
4.
[James - 22]
2003 Chevrolet Silverado-2500hd Duramax 6.6l lb7 allison transmission | 7-9 inch Cognito Lift | EFI live tuned | 5 inch MBRP Turbo Back | 4.5 inch Bills Custom Intake S&B Filter | Pro Fab 3 inch Downpipe | 3.5 inch Profab Turbo Horn | 38/13.5/R20 Toyo Open Country MTs | 20x14 American Force Independence SS |
73impala is offline   Reply With Quote
Old 11-22-2012, 08:21 AM   eBay Motors  #5 (permalink)
How did you get the pics to worj?
Old 11-22-2012, 08:42 AM   eBay Motors  #6 (permalink)
mike diesel's Avatar
You gotta use the image code, not the link.
05 lly
EFI Live
4094 vvt
Built Trans
BT Lockup Box
Supporting Mods
mike diesel is offline   Reply With Quote
Old 11-22-2012, 08:42 AM   eBay Motors  #7 (permalink)
73impala's Avatar
Have to use
[img]url[[/img]
Not <img src="">
[James - 22]
Old 11-22-2012, 08:49 AM   eBay Motors  #8 (permalink)
Subscribed! Ill be looking into this option. Is it quiet?
2006 CCSB
Big Dipper - SkyJacker - EFI Live - Mickey Thompson - HID - Amsoil. http://www.trollperformance.com/
SwitchBack is offline   Reply With Quote
Old 11-22-2012, 09:07 AM   eBay Motors  #9 (permalink)
poosniffer's Avatar
Thanks man for the write-up.This is a great inexpensive way to add filtration/water separation without spending the big bucks on an Airdog.Thumbs up for including all the part #s as well.
2008 LMM Silverado 2500 LTZ ECSB 4X4.
Aftermarket calibration,Nicktane with Baldwin BF7587,PPE lift pump with Baldwin BF1212 water separator,285/75/17 Dura Grapplers on H2s,CTS Insight with pyro,Large fender mod.
Proud Member U/A Local 693 Plumbers/Pipefitters.
poosniffer is offline   Reply With Quote
Old 11-22-2012, 05:26 PM   eBay Motors  #10 (permalink)
Yes the pump is quite. only canhear it run if the door is open and waiting to start.
