help?? nasty noise frome serp belt - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 12-14-2012, 09:09 AM Thread Starter
Ry Dogg's Avatar
hi. i have 2002 lb7, just hit 100k miles. im getting a nasty noise from the serpentine belt. same noise as if it had something spilt on it. ive heard this noise pretty regularily when i first start but tends to go away when its warmed up. i replaced my belt with napa s finest less then 15k miles ago. i just noticed that after we had been driving awhile was still very noisy. im thinkin tensioner pulley, or idler pulleys. could be the pulleys on any of the accessories though. how do i decifer which?? i see these pulleys are cheap and inexpensive, should i just do anyways?
Ry Dogg is offline
post #2 of 10 (permalink) Old 12-14-2012, 09:42 AM
RobsDmax's Avatar
well take belt off and spin each separately will tell you what you need. probably tensioner because they are fairly normal too go
2003 Chevy LB7 RC/LB Red
EFI By Kory - MBRP Duals - Bills Intake - Amsoil and John Deere Synthetics Throughout
2003 Chevy LB7 CC/SB Black - Cheap Hooker
EFI By Kory - Stacked Stacks - AFE Intake - Work Stock Puller
2002 GMC 4.8L RC/LB Beige - Cheap Stripper
EFI By Me - Soon To Be Single Turbo
RobsDmax is offline
post #3 of 10 (permalink) Old 12-14-2012, 10:33 AM
brolla's Avatar
I would probably just go ahead and replace the all the pulleys. That's exactly what I decided to do after one of my pulleys literally fell apart and destroyed my belt. Almost left me stranded. I was hearing more of a whining noise though.
2004.5 LLY
Mouthpiece, CAI Mod, PCV Rerouted, Edge Insight CTS with Pyro, MBRP Exhaust.
"It is not always the d.o.p.e. on the weapon, sometimes it is the dope behind the weapon!"
brolla is offline
post #4 of 10 (permalink) Old 12-17-2012, 11:26 PM
izcain's Avatar
Just did this last weekend myself. Ended up just replacing all the pulleys and tensioner pulley as well as a good heavy duty belt. No sense messing with tensioners that only cost like 18 a piece anyways. I was hearing the same noises in the morning.
06 GMC CC DRW LLY
EFI LIVE, Danville GT3794va stg 2, Ported Rail, Profab egr delete, MBRP cold side Intercooler pipe, PCV reroute, Diamond Eye DP, Max Flow Manifolds and up pipes, S&B intake, Transgo Jr, Mag Hytec,
izcain is offline
post #5 of 10 (permalink) Old 12-18-2012, 03:11 AM
duramxlove03's Avatar
I was just gonna post a similar question as mine just started making this noise last week. It went a way for a few days but it came back yesterday. I was trying to think of a comparison noise. It doesn't do it all the time mabe two to three seconds at a time.
2003, CCSB, PPE Xcelerator hot +2, PPE boost valve, green diamond mud terrains, custome built back rack.
duramxlove03 is offline
post #6 of 10 (permalink) Old 12-18-2012, 03:31 AM
LHN...We ARE the Joneses
Originally Posted by Ry Dogg View Post
....i see these pulleys are cheap and inexpensive, should i just do anyways?
At around 100k lifespan for the belt, always include a new tensioner and idlers with the new belt. Chances are slim they'll last another 100k and then you'll be in there with another new belt when they fail.
Hook'em_Horns! is offline
post #7 of 10 (permalink) Old 12-18-2012, 04:42 AM
LsUtIGeRs's Avatar
Where is a good place to purchase these?
Mike
LBZ|6"|Toyo MT|Fuel Mavericks
Custom Pearl Paint
S&B CAI|5" MBRP Exhaust|BD Power Pup|PPE Shim Kit|Profab EGR Delete|Profab DP|LML Manifold|PCV Re-route|Cobalt Boost & Pyro
Bilstein 5100 & Stabilizer|Krypto Tie Rods|Moog Pitman|Idler Arms|Krypto UCA
Mag Hytec Diff Cover
LsUtIGeRs is offline
post #8 of 10 (permalink) Old 12-18-2012, 07:08 AM
LsUtIGeRs's Avatar
Willie has a complete kit
Mike
Custom Pearl Paint
post #9 of 10 (permalink) Old 12-25-2012, 04:17 PM
What is a good heavy duty belt. I was going to get it all off GM Parts Direct, but if I could get a HD belt that would probably be a good idea.
My belt started only squeaking when it was wet out but it has been getting progressively worse, gonna get parts now and try to hold off till spring to do it when its warm.
2003 Silverado 2500HD LB7 Ext. Cab SB. Straight Pipe Banks Exhaust, EFI Live DSP5 switched with EDGE Insight CTS, PPE Boost Valve, Hi-Idle Mod, De-badged,Banks Wastegate,S&B Intake, Blacked out Bumpers.
Backrack with brake lights and Rigid Duallys.
No Farms No Food
ACDiesel345 is offline
post #10 of 10 (permalink) Old 01-25-2013, 03:33 AM
Well i dont know about a heavy duty belt. I do know once the noise starts it wont be long and the pully and bolt comes right off. I changed one because it was dry, didnt notice anything wrong with the second idler until i started the truck and the noise was still there. The next day it sounded like a cage of pissed off squirrels. The pulley seized and then removed itself from the engine bay. Now for some reason i have been avoiding the tentioner pully. Probably should do that soon. Good luck
