| How To's, DIY and Write ups DuramaxForum How To's, Do it Yourself Guides, and other write ups. Only How TO post belong in this forum!!! If your NOT showing/telling us HOW TO then DO NOT post it here. |
| | eBay Motors #41 (permalink) |
| Junior Member Join Date: Jan 2013 Location: Chicago, Illinois
| Hmmm. Will i run into problems overdrawing power blowing fuses ?
__________________ 02 GMC Sierra LB7 | Dana 60 | 4.10s | Lifted | 37's |Single Stack | K&N Intake | 90hp Injectors | Edge Juice | HIDS |200k on the clock To Do: ADII | EFI Live | Head Studs | Built Trans | LED Cab Roof Lights | |
| | eBay Motors #42 (permalink) |
| Junior Member Join Date: May 2012 Location: West WI
| i wouldnt think so because there are 5 lights total in the 3 piece set up being that the center has 3 leds with the two on the sides
__________________ '04.5 LLY EFI Live Tuned by Rob EGR Blocked AFE Mouthpiece PCV Reroute/Resonator Blocked Diamond Eye 3" Down Pipe MBRP 5" Straight Exhaust Stock Trans |
| | eBay Motors #43 (permalink) |
| Senior Member Join Date: Aug 2012 Location: New Hampsha'
| I like the look of the 5 lights more myself and had considered doing this. But I also want something thats gonna have quality like oem stuff, which would mean Id have to get Ford or Dodge lights, eww
__________________ Chad 04.5 4x4 ~123k miles DE 4", LBZ MP, KoryWillis Go-go Juice, Insight CTS, ADII, 8' Fisher 'If 40 is the new 20, smoke stacks are the new red car syndrome' Dirtymax this, Dirtymax that... ![]() I like my max's clean |
| | eBay Motors #44 (permalink) |
| **UPDATE** Everyone, so far so good! NO LEAKS!!! I followed the instructions in this post to the "T" ![]() One thing i noticed, i see more of the OEM style lights and i think i may switch over eventually but for now the Recon Tinted are working fine. Thanks again for the write up!
__________________ -Sal 2007 LBZ CC/SB, Allison, and a few mods... |
| | eBay Motors #45 (permalink) |
| good to hear there are no leaks sal. ford,... can suck it. dodge isnt to bad.. besides didnt one of the dodge brothers break off and make chevy? cummins are good. but im chevy for life. anyways. i love the look of the 5pc recon smoked led's. ill probably order them and the wiring harnesss they recommened on the site, and once i get to drilling and plugging ill figure out what exactly needs to be done. but since there are 5 leds in the 3pc already i would be suprised if there are electrical issues... ill just get some tape and start pluggin and chuggin.
| | eBay Motors #46 (permalink) | |
| Senior Member Join Date: Aug 2010 Location: Barrie, Ontario
| Quote:
__________________ Jeff-04.5 CCSB LS,Kory Willis tuned, Edge CTS, EGT and Boost guages, Afe MP, SDP EGR delete, PCV Reroute, AD 165, Fuelrail/cp3 fittings, FPRV shimmed, DHD Boost tubes and Downpipe, MBRP 4" w/6" stack, Cognito UCA's ,pitman/idlerarm braces, Bilstiens, Kryptonite centerlink/tie-rods, Trac bars by me, MA T-case brace, Kool-vue tow mirrors, Line-x everywhere, Amsoil synthetics, All light mod, 20" XD Hoss +18 305-55 TrailGraps. 2 Kicker 8" L7's NathanAirchime K3la Hornair 548 kit with GW manual valve ![]() BIG WISH LIST! ![]() SYNTHETIC MOTORSPORTS AND KORY WILLIS FTW | |
| | eBay Motors #47 (permalink) |
| Junior Member Join Date: Dec 2007 Location: Findlay, OH
| i put the recon lights on my 03. instead of drilling a 5/8 hole in the cab, i took a dremel and cut off the large plastic tab that fits in the hole. since i wasn't using a factory harness (made my own) I just cut the quick connector off. then i only had to have a hole big enough for a pair of wires to go through.
__________________ Ryan 2011 Chevrolet 2500HD CCLB LML |
| | eBay Motors #48 (permalink) | |
| Junior Member Join Date: Aug 2010
| Quote:
and just want to ask two things.1.Where yours straight oem lights for 07.5+ trucks? if not what brand and where did you get them? 2.which harness did you use to do it? recon for 02-07.5? i appreciate the help!! awesome writeup btw
__________________ ![]() 01 chevy Lb7 dirty D Ext cab sbfull 4" exhaust to 6" tip afe stage 2 cold air ported turbo inlet ppe boost valve dual auto meter ultra lite gauges | |
| | eBay Motors #49 (permalink) | |
| Senior Member Join Date: Sep 2012 Location: Salem, IN
| Quote:
__________________ ~ 2001 Silverado 2500HD CCSB Duramax ~ - S&B Intake - Diamond Eye 4" Stainless Exhaust - PPE Boost Valve - AirDog II 165 - EFI Live by Danville Performance - Edge CTS Insight - | |
| | eBay Motors #50 (permalink) |
| what harness did you use? and where did you get your lights? im wanting to do the exact same thing but dont know how/where to start
