How-To: Install '07.5+ Cab Lights on '01-'07 Silverado - Chevy and GMC Duramax Diesel Forum
Old 12-14-2012, 12:00 PM   eBay Motors  #1 (permalink)
mjonesjr's Avatar
I couldn't find a good how-to to install cab lights on my '01 so I decided to write a in-depth one for anyone else who is looking. I had to use multiple threads, pictures, and dimensions to get them right. Hopefully this helps someone in the future.
This will work on all '01+ Silverado trucks. The dimensions used here are specific for the '01-'07 trucks. I'd assume the '07.5+ trucks will be a little different on the dimensions, but the theory is still the same.
Difficulty: 7 out of 10.
I give it a 7 out of 10 because of the drilling of a perfectly good cab roof is a little nerve racking.
Install Time: 3 hours
I did the install by myself, including all the measuring. The only help I got was a second person to measure to make sure the templates I made were taped in the correct location.
Tools Needed:
- #2 Phillips Screw Driver
- 1/4" Drive Ratchet
- 1/4" Drive Extension, 6"
- 1/4" Drive T15 Socket
- 1/4" Drive T20 Socket
- Drill (corded or cordless with a low speed setting)
- 7/64" Drill Bit (for metal)
- 5/8" Drill Bit (for metal)
- Touch-up Paint (to match truck color)
- Black Automotive Silicone
- 2" Painters Tape
Parts Needed:
- '07.5+ Driver Side Cab Light (GM Part #: 20966091)
- '07.5+ Passenger Side Cab Light (GM Part #: 20966092)
- '07.5+ Center Cab Light (GM Part #: 20966093)
- '02-'07 Cab Light Wiring Harness (GM Part #: 15846970)
Prior to Install:
Prior to starting the install there is a couple things you can do to get ready.
First thing is fairly simple. The cab light wiring harness needs the wires swapped. The LED cab lights for the '07.5+ trucks are polarity sensitive. That means the positive and negative must be on the correct pins for them to work. The '03-'07 cab light wiring harness has them backwards to work with the '02-'07 lights. To do this, remove the blue keeper with a small flat screw driver. Once it is removed, you can pry the clip up that is holding the wire pin in and pull the pin out; do this for both pins. Once both pins are out, swap their locations with each other.
Next, you will want to cut the ring off from around the plug on the outer lights. This ring serves no purpose and will just cause you to have to drill a larger hole on the outer lights. I used a hack saw to cut the rings off with.
Next what you want to do is to make a set of templates for the cab lights. Since the cab lights do not come with a removable gasket to use as a marking point, making your own template is the only way to go.
Cut a 11/16" square hole in a section of card board. Now center the wiring portion of a light in that hole. Once it is centered, press the light down and trace the outline of the light on the cardboard. Use a sharp box cutter or a good pair of scissors to cut the outline out. Once it is cut out. Place the cutout under the light and screw the OEM screws into the card board. They should suck the cardboard up tight against the light.
Repeat the above for each light until you have 3 templates; one for each light.
Prepping the Interior for Cab Light Installation:
Now you can get the interior of the truck read for the cab light install. To do this you will need to take the sun visors, overhead console, and A-pillar trim pieces off.
To remove the sun visors (this will be the same for both visors), pop them out of the hold and pivot them towards the door. Use the T20 socket to remove the screw holding the clip to the cab. Now use the T15 socket to remove the 3x screws holding the actual sun visor to the cab. Repeat this for the opposite side.
Now, take the #2 Phillips Screwdriver and remove the single screw in the overhead console. This screw is located towards the windshield. Once that screw is removed, pop the console clips from the cab. Unplug the wiring going to the console and set the console out of the way.
Grab the top of each A-pillar trim and gently pull out. Once it is pulled out, you will be able to slide the A-pillar trim up out of the dash and lay it out of the way.
Remove the passenger side portion of the dash (same spot as the fuse box, only on the passenger side) to revel the distribution block the wiring harness will plug into.
Feed the dash end of the wiring down from the top of the dash by the A-pillar. You can follow the wires once it is down from the dash and wrap it into the distribution block. You can plug the wiring harness into the only open slot.
Feed the other portion of the wiring up the passenger A-pillar and across the roof to the driver side light area.
Cab Light Layout:
Now let's prep for the cab light install on the cab.
Take your 2" Painters Tape and cover the cab area. You will want to cover an area from the windshield up to about 10". This will give you plenty of room for the template layout and to keep from scratching the cab. The painters tape is there to help keep the paint from chipping around the area you are drilling and to make it easier to layout the templates.
Now you can start laying out your templates in their area. We will layout the outside lights first as the center light will be measured off each of the outer lights.
The driver side template goes 3.5" from the first ridge near the door to the outside portion of the light. The front of the driver side light goes 5" from the top of the black windshield trim. Make sure you measure the front of the light on both sides as the light needs to be curved to flow with the window. Use some of the painters tape to secure the template in its location once you have the measurements correct.
The passenger side template goes 3.5" from the first ridge near the door to the outside portion of the light. The front of the passenger side light goes 5" from the top of the black windshield trim. Make sure you measure the front of the light on both sides as the light needs to be curved to flow with the window. Use some of the painters tape to secure the template in its location once you have the measurements correct.
The center light goes 11" from the inside edge of each outer light to the outer edge of the center light. The center light also goes 5" from the top of the black windshield trim. Make sure to measure the center light to windshield trim in 2 places to make sure it is square with the windshield. Use some of the painters tape to secure the template in its location once you have the measurements correct.
In the picture below, you will see the ridge the outer lights are measured too.
In the picture below, you will see the dimensions as they pertain to the templates/lights.
Now is the spot where you start double, triple, and quadruple checking your measurements. It is a good idea to have someone else check the measurements. Tell them where to measure to and have them tell you what they measured. If they get the same as you, then your ready to start drilling.
Drilling the Cab:
Now you are ready to drill the cab.
I started by drilling the largest hole for each light. Start with a smaller, pilot bit and work your way up to the 5/8" bit. When drilling the cab, make sure your drill is on the lowest speed. Doing the step up and the low speed drill will ensure that your drill bit doesn't catch and distort the cab. Center the smaller drill bit in the square you cut out of the template. It is best to step your way up 5-6 times.
Once your are done with the larger hole, use the 7/64" drill bit to drill the mounting screw holes. With your template in place, you should be able to go through where the screws went through the cardboard. Again, make sure your drill is on its slowest speed.
Once your are done drilling all the holes (there should be 10 holes), remove the painters tape from the roof. Once the tape is removed, double check to make sure your plugs on the lights will fit in the large holes; make any adjustments to the hole as needed to make the light fit.
Once you know the plug fits, use your touch up paint to cover the bare metal. This will help prevent the bare metal from rusting.
Allow the touch up paint to dry for about 30 minutes.
Installing the Cab Lights:
Now you are ready to install the cab lights.
Start by taking the black automotive silicone and running a 1/8" bead around the large hole and putting a good dab on the screw holes.
~ 2001 Silverado 2500HD CCSB Duramax ~
- S&B Intake - Diamond Eye 4" Stainless Exhaust - PPE Boost Valve - AirDog II 165 - EFI Live by Danville Performance - Edge CTS Insight -
mjonesjr is offline   Reply With Quote
Old 12-14-2012, 12:01 PM   eBay Motors  #2 (permalink)
mjonesjr's Avatar
Now take and put the light down on top of where it will go. Use your #2 Phillips Screwdriver to screw the screws. You will want to screw the screws in until the rubber gasket under the screws starts to compress. This should pull the lights down flush with the cab.
Do this for each cab light until all 3 are installed.
Plugging the Cab Lights In:
Now go back into the truck and plug each cab light in. There should only be 3 plugs on the wiring harness you already stretched across the inside of the headliner.
Once they are all plugged in, turn the parking lights on and make sure the cab lights come on.
Reassembly of the Interior:
Now re-install the interior trim pieces in reverse order as you removed them.
Finished Product:
Now other than the color of the truck, your should look like this when done.
Enjoy!
Old 12-14-2012, 12:30 PM   eBay Motors  #3 (permalink)
RobsDmax's Avatar
this is amazing, exactly what ive been looking for!! no leaks yet??
2003 Chevy LB7 RC/LB Red
EFI By Kory - MBRP Duals - Bills Intake - Amsoil and John Deere Synthetics Throughout
2003 Chevy LB7 CC/SB Black
Bone Stock - Currently Getting Body Work - Work Stock Puller
Plans : EFI, Intake, Exhaust
RobsDmax is offline   Reply With Quote
Old 12-14-2012, 12:35 PM   eBay Motors  #4 (permalink)
Bowtie Bandit Jones's Avatar
Great write up! Thanks
2007.5 Chevrolet Silverado 2500HD
EFI Live by Idaho Rob
K&N cold air intake
MBRP dp back 4" exhaust
Air Dog 2 165
Edge CS Insight
Dick Cepek 17x9 GM8 Wheels
Bowtie Bandit Jones is offline   Reply With Quote
Old 12-14-2012, 12:46 PM   eBay Motors  #5 (permalink)
mjonesjr's Avatar
No leaks yet. I just did the install today. I'd assume that with the silicone and OEM lights I will not have any leaks.
Old 12-14-2012, 12:56 PM   eBay Motors  #6 (permalink)
IHFarmer07's Avatar
Awesome!
Sent from my MB865 using AutoGuide App
Eric
Red Classic CC SB Duramax
Profab down pipe and DE down pipe back exhaust, auto-meter phantom boost & pyro gauge, raceline wheels, PCV reroute, EGR blocked, PPE air box mod, Hot side CAC tube, high and low all on mod, trans-go shift kit, Autran syn 295 ATF, EFI LIVE via AUTOCAL from ATP, air bags, ported fuel rail fitting, FPRV shim kit, FASS titanium 150
IHFarmer07 is online now   Reply With Quote
Old 12-18-2012, 09:45 AM   eBay Motors  #7 (permalink)
Sal 2500's Avatar
THANKS for taking the time to post this write up! I am in the process of ordering Cab lights for my LBZ and i am so glad i now have this information!!!!
THANKS!!!!!
Sal 2500 is offline   Reply With Quote
Old 12-18-2012, 10:03 AM   eBay Motors  #8 (permalink)
The Vigilante MEME Maker
jwcgmc1985's Avatar
bravo man
that was a very detailed write up!!!! now do one on an LML with sunroof and write it up again pppleeeaaasssseeeee!
Jeff -Proud Member of the "Pup Bro's"- 28
White 2012 LML CCSB LTZ 4x4, all the Options. + NAV/Sunroof/Rear Sliding Glass
-Dropped 7.5" RCX, Sulastics, Cognito UCA's/Supports, DUAL Stabilizer's, Nicktane Cat
-S&B Dry + Scoop, Edge CTS, 5" Flo Pro, XRT PRO on Hot, Nfabs, Debadged, 22x9.5 Throttles on 35x12.50
Gray 2008 ECSB LT Silverado "Texas Edition", OEM 20's, 2.5" TGC leveling kit, 2x JL 10"s, RF Amps- Daily Driver
Body Dropped Build Thread - 2001 Sierra / 2000 S10
- Lowering A Lifted Truck - Cognito Support Kit- Cognito UCA kit - How To LML Cat Adapter -Modified Dual Stabilizer Kit-
jwcgmc1985 is online now   Reply With Quote
Old 12-18-2012, 04:16 PM   eBay Motors  #9 (permalink)
mjonesjr's Avatar
Originally Posted by jwcgmc1985 View Post
bravo man
Thanks.
I'm trying to talk my brother into doing these on his '08 LMM, but he is hesitant to doing it. Maybe I can talk him into it.
You could go to a dealership and get the dimensions. Everything else should be the same other than the dimensions.
Old 12-18-2012, 05:01 PM   eBay Motors  #10 (permalink)
jwcgmc1985's Avatar
Maybe!
I got quoted 400 out the door with the recons
Before I was quoted 280 by the guy that did my lift but when he jumped off into it he said it wouldn't be right since the sunroof motor is there!?!? Idk. And every other shop I call where I live don't want to do it due to warranty
So I have to drive like 40 miles to a well known shop that boss had his lift and cab lights done on a new super duty sooooo I might just go that route
I'd chop a half ton to bits but cut my own roof ummmmmm idk!!
