How-To: Upgrade Allison Transmission Cooler - Chevy and GMC Duramax Diesel Forum
 5Likes
post #1 of 118 (permalink) Old 03-12-2013, 02:20 PM Thread Starter
mjonesjr's Avatar
I was looking for a way to upgrade my factory transmission cooler to one that cooled a little better. In my research, I found that the Earl's 82510ERL. There is a couple of threads on them installed, but nothing picture heavy and detailed on the installation.
Difficulty: 4 out of 10
I say a 4 out of 10 because it does take a little time fabricating the upper brackets.
Install Time: 1 hour
I did this by myself. There is no need for another set of hands unless you want to speed the process up and have someone to drink with.
Parts Needed:
- Earl's Cooler (Part #: 82510ERL)
- 2x Cooler to OEM Cooler Line Fitting Adapters (Parker/Air Hydro Power Part #: 10-1/2 F5OG-S)
- Some sort of steel/aluminum flat stock for making new mounting brackets
- 8x 1/4"x1" bolts and nuts
- 8x 1/4" rubber washers
I can't say for sure, but I believe if you are upgrading a '03-'04 LB7, you will not need the adapter fittings.
Tools Needed:
- Phillips Screw Driver
- Flat Screw Driver
- 1/4" Drive 10mm Socket
- 1/4" Drive Ratchet
- 1-1/4" Wrench
- 1-1/8" Wrench
- 1/4" Drill Bit
- Drill
Comparison of OEM Cooler and Earl's 82510ERL:
Here is a couple pictures comparing the OEM Cooler to the Earl's. You can see how much larger the Earl's cooler is than the OEM cooler.
Prior To Install:
Prior to the installation, you can install the adapter fittings into the new cooler. Be sure to coat the o-rings with oil prior to install.
Here is the fittings you will be using.
Installation:
Start by removing the upper grill cover by removing the plastic tabs that hold it in.
Once the upper grill cover is off, remove the 10mm bolt in the upper center of the grill. This is the only "bolt" that holds the grill in. Now use your Phillips Screw Driver to turn the 4 clips holding the grill in (on all 4 corners of the grill). Once these are loose, pull the cross bar of the grill loose from each fender.
Now using your 1-1/4" wrench, take the fittings loose from the OEM cooler. It is a good idea to wrap a rag around the lines to catch any fluid that comes out.
Now, take your flat screw driver and pop the plastic clips holding the lower portion of the cooler to the truck. Once these are out, use your 10mm socket to remove the 2 upper bolts. When you have all 4 of these out, you can take the cooler out of the truck and place it somewhere to collect the fluid inside it.
To make the lower brackets, I cut a 2.5" piece off my galvanized flat stock. I drilled a 1/4" hole in the one end. Mount these to the lower mounting holes and loosely with a bolt and nut. This will allow you to mark where the cooler mount holes need to be. Now place your cooler onto the lower mounting brackets and mark the holes. Be sure to have the cooler back as close to the cross bar you are mounting to. Mark the holes and drill them. Put the lower brackets back on the lower cross bar and go ahead and loosely mount the cooler to them.
Now is a good time to use our sealant tape on the OEM fittings. Once that is done, install the fittings into the adapters. Snug the fittings up as this is the final time they will be removed.
Now you are going to make your upper brackets. I took a 8" piece of my flat stock and bent a tab to mate up to the upper bolt hole that was used by the OEM cooler. I then bent it to where it would meet the upper bracket of the Earl's cooler. This will take some trial and error to get it correct.
Once you have it correct, mark the spot on the bracket to drill the hole for the cooler mount. When you have it drilled, install the upper bracket loosely.
Repeat this for the opposite side.
When you put the brackets on the cooler, it is a good idea to put some rubber washers between the brackets and the cooler.
Once you have both upper brackets made and mounted, go through and tighten all your bolts down.
Now start the truck and cycle through the gears, stopping in D and R for about a minute each. Put the truck back into P and check for leaks at your fittings. If there are no leaks, you can now you can re-install the grill.
When you install the upper grill cover, you will have to cut the tab that sticks down. It is there for no purpose.
Finished product:
Shov and The Dude1 like this.
~ 2001 Silverado 2500HD CCSB 4x4 Duramax ~
443 RWHP & 842 RWTQ
- S&B Intake - Diamond Eye 4" Stainless Exhaust - PPE Boost Valve - AirDog II 165 - EFI Live by Danville Performance - Edge CTS Insight - Longhorn Fab Traction Bars -
mjonesjr is offline
post #2 of 118 (permalink) Old 03-18-2013, 04:25 PM
flyboyracing002's Avatar
How big of a temp decrease did you see?
07.5 GMC 2500hd SLT 4x4 ccsb all stock awaiting install of
-Engine- 5" DE exhaust, LML ds exhaust manifold, Banks intake w/scoop, Banks ic pipe, Pcv reroute
-Suspension- leveling kit, PPE support kit, PPE diff cover
-Wheels- motometal Mo962 20x9 0offset 305/55r20 bfg a/t hoss spare.
-Exterior- hornblasters outlaw kit.
-Interior- led interior, autometer ultralite II double pillar pod,
-Awaiting install: magnaflow downpipe, Transgo jr
Sold 2007.5 lmm silverado lt 2wd ccsb
flyboyracing002 is offline
post #3 of 118 (permalink) Old 03-18-2013, 06:30 PM
How much is the cooler? Where did you get it from?
02 CC LB LB7, PPE Hot, PPE Boost Valve, PPE Pitman/Idler Arm Support Kit, Fabtech HD Tie Rods, BD Exhaust Manifold, Ready Lift Leveling Kit, 285-70-17 Toyo's AT II LR E on H2 Rims, Airaid Air Intake, Magnaflow 4" Exhaust, PIAA 580 Fog and Driving Lights, Modded Intake Horn, Kool Vue Mirrors, DDM HIDS 6K Low and 8K Highs, Firestone Airbags, Tekonsha P3, Nicktane with Cat
www.huskerdiesel.com 402-502-6961
www.madjacksynthetics.com
02 FL Duramax is offline
post #4 of 118 (permalink) Old 03-18-2013, 06:36 PM Thread Starter
mjonesjr's Avatar
I've seen anywhere from 70-80* above ambiant temperature since the install. Before the install I was seeing a constant 100* above ambiant temperature.
The cheapest place I found to get it was Summit.
Earl's Performance Temp-A-Cure Fluid Coolers 82510ERL - SummitRacing.com
443 RWHP & 842 RWTQ
mjonesjr is offline
post #5 of 118 (permalink) Old 03-18-2013, 07:22 PM
MaxLBZ's Avatar
Great write up!! Very clean and organized
Paul
2006 LBZ Silverado 2500HD LT CCSB 4x4
Suspension & Tires: 6" Superlift, 37" x 13.5" Toyo MT's, 17" AR Rims, Moog Pitman, Idler, & Tie Rod Ends, Custom Tie Rod Sleeves.
Engine, Performance & Drivetrain: EFI Live DSP5 by Rob, 4" Turbo back Exhaust, Banks Ram Air, Profab Downpipe, CTS, EGR blocked, MA Pump Rub Fix, PPE diff. Cover, Transgo Jr. Alligator Cooling Lines.
Body: Line-X, Dipped Bowties.
Parts Pending: Traction Bars.
ARIZONA DIESEL CLUB
ADC President
MaxLBZ is offline
post #6 of 118 (permalink) Old 04-24-2013, 11:28 AM Thread Starter
mjonesjr's Avatar
Thought I'd throw this up to show the temp differences since I upgraded the cooler.
I had the cruise set on 62 while running down the highway. I had been driving for about 30 minutes on the highway and 15 minutes before in town.
Ambiant Temperature:
Transmission Temp:
443 RWHP & 842 RWTQ
mjonesjr is offline
post #7 of 118 (permalink) Old 04-24-2013, 03:57 PM
stickynicky's Avatar
Nice, how is this cooler better than the stocker? I just flipped mine over and it seemed to help a bit.
2006 3500 DRW CC LT 4x4 LBZ
5" Straight Back, Blocked, ReRoute, Inglewood Trans, Goerend TDTC, Dual Kennedys, 2 Micron x2, DO H20 Inj, 5 Different Kinds of Nasty thanks to Rob! Dual 350c Viar, S4 Shockers, Valentine1, BigChevyHitch, Timbrens, DRW CLUB MEMBER #142
stickynicky is offline
post #8 of 118 (permalink) Old 04-24-2013, 03:59 PM Thread Starter
mjonesjr's Avatar
This one is larger and more efficient. The stock cooler is designed to keep temperatures at 100-120* above ambiant. I've not seen a temp closer than 80* above ambiant since I installed it.
443 RWHP & 842 RWTQ
mjonesjr is offline
post #9 of 118 (permalink) Old 07-19-2013, 12:30 PM
Subd
2016 LTZ, Stock (for now)
OLD - 2005 GMC CC/SB - LLY - aFe 4" Turbo Back - aFe MP - Engineer837 Secondary Cooling System - Earl's Tranny Cooler - ISSPro Boost & Pyro in a Triple pod with Insight CS controlling Tunes by IdahoRob - PCV re-route, EGR blocker plate, Clarion NX500 head unit - Hi, Lo, & Fog HID's wired for All on. LED's Everywhere!
2015 Coachman Chaparral X-lite 28bhs
2006 Yamaha Raptor 700
Cdn_Blair is offline
post #10 of 118 (permalink) Old 08-04-2013, 10:32 AM
Please excuse the dumb questions, but how much extra fluid did you add on account of the larger cooler, and when is the proper time to add it? Any fluid starvation or air bubble concerns in doing this?
Thanks.
Stock 2008 Chevy 2500HD, LMM w/Allison 6-speed auto transmission, short bed 4x4 w/crew cab and LTZ trim
74,000+ miles
Pullrite Superglide 16K 5th-wheel hitch w/3" lift kit
Nicktane OEM adapter w/Donaldson fuel filter
Planned mods:
1) Banks Speedbrake?
2) EGT gauge
I need all the I can get!
Rade is offline
