How To's, DIY and Write ups DuramaxForum How To's, Do it Yourself Guides, and other write ups.
Closed Thread
Old 04-06-2009, 04:45 AM   eBay Motors   #1 (permalink)
Nemo
Wants Brians Rod!
Nemo's Avatar
CP3 Modifications You Can Do Yourself!
Brought this from a Differant site...
To all DMAX owners who are reading this thread:
The metering valve shown in this write-up is from a Cummins CP3 and has the triangle ports. The DMAX doesnt have triangle ports, it has rectangle ports.
WARNING...DO NO SCREW UP THOSE RECTANGLE PORTS!!! There are no replacement parts to be had over the counter so if you make a mistake you will either be buying a new CP3 or begging a shop to find you a plunger without raping you.
CP3 Modifications you can do yourself!
Many thanks to Relentless Diesel
This should help some of you understand how to modify your own CP3 injector pump. We'll get into more detail of CP3's in another article, but for now understand that all you can do is completely fill the plungers with fuel. The CP3 has three plungers and each plunger intakes a certain amount of fuel and expels it into the fuel rail with each injector pump revolution.
Each plunger makes the same length downward and upward stroke on each revolution regardless of how much fuel is commanded. If the plungers were full of fuel the pump would always move the same amount of fuel per revolution and we know that's not true. At light throttle/low power the pump moves very little fuel into the rail. At high power levels the pump moves all the fuel it can.
It's easy to see that the plungers are not always full of fuel on the intake stroke. Our goal as pump modifiers is to make sure the plungers are more full of fuel (therefore moving more fuel into the rail) during high power levels than the stock pump.
There are several restrictions from the time the fuel enters to the CP3 until it gets sucked into the plunger/barrel chamber. As we eliminate each restriction the plunger chamber can fill more completely with fuel.
This article will cover two simple modifications that most anyone can do to increase the fuel delivery from their CP3 pump.
Take a look at the picture below. You'll notice two easily removable pieces bolted to the back of the CP3.
On the lower right you'll see the fuel control actuator (FCA) which has the black colored electrical connector attached to it. You'll also notice the aluminum housing of the gear pump on the very back. Both of these items are easily removed with the pump still in the truck and cause major restriction to fuel flow.
Remove the FCA first. It will look something like this.
Start with an extremely clean work place.
Using an allen wrench or a cutoff screwdriver pry out the endcap. (We used a torx bit for the pictures, but it deforms the i.d. of the endcap too excessively.)
Carefully remove the spring and lightly tap the fca on the table to help slide the metering valve out. (Use extreme caution when handling the metering valve. If it is bent or even scratched it can stick will be useless.)
All the fuel that is allowed to enter the plungers must first make it through these two tiny triangular holes in this valve.
Each triangle is 0.110" high
and 0.068" wide
for a total area of 0.00748 square inches between the two. This is equivalvent to a single hole with a diameter of 0.097".
By enlarging these triangles more fuel will be able to get to the plungers. This is the smallest restriction from the inlet of the CP3 all the way into the plunger chamber.
We've tried various shapes which allow more or less flow at each duty cycle (position) of the valve and the one that works the best also happens to be the easiest to machine.
A simple dremel tool cutoff wheel can be used to perform a simple slice into the triangle.
**It is extremely important that you do not modify the tip of the triangle. The tip is crucial to the valves ability to stop and regulate fuel at small flowrates (idling, cruising, etc.)**
04.5 LLY 4x4 lifted CC S/B - EFI Live
Nemo is offline
Old 04-06-2009, 05:01 PM   eBay Motors   #2 (permalink)
Nemo
Wants Brians Rod!
Nemo's Avatar
Use some gloves or something soft for protection. I don't want to hear complaints that you cut your finger. Don't chuck it up in a vise because you'll damage the valve. BE CAREFUL!!!
Here's an example of a cut valve.
You'll need to spend a LOT of time polishing the cut edges both inside and outside with some very fine sand paper. The valve will need to freely slide in and out of the housing without force. If you get in a hurry and force a valve into the housing with a burr of any kind it will scratch the housing and be JUNK. Throw it away and start over.
Now take a look at the spring and endcap that you pryed out. Remember they stack like this:
You can enlarge the center hole in the endcap, but there's really no use going bigger than 0.130" since that is the I.D. of the spring. Fuel has to travel down the center of the spring on its way out of the FCA.
Again, I cannot stress deburring all edges with sandpaper and cleanliness enough. You don't have the luxury of a filter to catch your mistakes. What you leave behind goes directly into the pump plungers and then into your $350 a piece injectors.
Insert the valve, spring and press the endcap back into place and you're finished modifying your FCA.
For those of you that want to understand the FCA a little better before modifying it, we have included some cross sectional views to simply it.
Here is the housing cut open.
Here is a closer view. Look at the first darkened region (left to right). You'll notice two holes. There are four holes total and this is where the fuel enters this valve.
Here is a picture with the valve in place positioned to delver NO FUEL!
Nemo is offline
Old 04-06-2009, 05:02 PM   eBay Motors   #3 (permalink)
Nemo
Wants Brians Rod!
Nemo's Avatar
__________________________________________________
Here is a picture with the valve in place to deliver FULL FUEL FLOW!
This final picture shows all three parts in place!
For those of you thinkers out there who think the inlet holes might be a restriction themselves. Here's the math.
Each hole is only 0.100" but since there are four of them the equivalent hole size is 0.200". MUCH larger than the 0.130" endcap on the other end.
The next restriction we will tackle is the orifices in the gear pump housing.
The gear pump looks like this once it's removed.
The red arrows are pointing to where two aluminum rivets will be. Flip the pump over to have the front side facing upwards and drill out both rivets.
Nemo is offline
Old 04-06-2009, 05:03 PM   eBay Motors   #4 (permalink)
Nemo
Wants Brians Rod!
Nemo's Avatar
Once you've removed the rivets, you can separate the front pump cover from the gears and rear housing.
The two red arrows here are inlet and outlet ports which can be enlarged. The outlet port is around 0.110" if memory serves me correctly. You can easily enlarge both holes to the 0.140"-0.160" range.
Flow will still be restricted by the 0.130" endcap in the FCA so there's no reason to go overboard here.
Obviously, you'll need to deburr the holes and clean everything up. You can use a 6-32 machine screw from any hardware store to bolt the pump back together if you don't have a rivet gun.
That should do it. Sit back and enjoy the fact that in under an hour you were able to perform the same modifications that some shops charge over $1100 to do.
I think I got it all...
Enjoy: Nemo
Nemo is offline
Old 04-06-2009, 06:23 PM   eBay Motors   #5 (permalink)
Nemo
Wants Brians Rod!
Nemo's Avatar
Originally Posted by DMAXchris View Post
Good post. One ?. Us DMAX owners need not worry about the first part? Or do we mod the rectangle?
I have heard that some are rectangle and some are triangular, so honostly Im not sure, I saw this on another board and figured it should be posted here as well...
-Nemo
Nemo is offline
Old 04-06-2009, 06:45 PM   eBay Motors   #6 (permalink)
Dmax15
Dmax15's Avatar
The ports on the LBZ/LMM duramax CP3s are rectangle.
2002 GMC LB7
EFI live tuning from IdahoRob
http://www.atptrucks.com
12.34 @ 108.7mph
Dmax15 is offline
Old 04-06-2009, 06:48 PM   eBay Motors   #7 (permalink)
Dmax15
Dmax15's Avatar
The LBZ/LMM duramax regulators have rectangle ports. You can use a dremel to widen it out, I was going to with mine but I'm holding rail pressure just fine so there is no need.
Nice writeup Nemo.
2002 GMC LB7
12.34 @ 108.7mph
Dmax15 is offline
Old 04-06-2009, 06:59 PM   eBay Motors   #8 (permalink)
techinny
techinny's Avatar
A stupid question is one that is not asked, so, where is the CP3 pump located on my truck?
Thank you to all of those who have served or continue to serve our country to keep our country free!
'05 GMC 2500HD, CCSB, LBZ mouth piece, A.R.E. cap, N-FAB nerf bars.
Winter truck- '98 GMC K1500 ECSB Z71, 123,000 one owner miles, custom buckshot dents in driver's side cab extension and front of box compliments of 2am drive by.
techinny is offline
Old 04-06-2009, 07:28 PM   eBay Motors   #9 (permalink)
Dmax15
Dmax15's Avatar
Its in the valley, here is some pics from when I put a LBZ pump in.
2002 GMC LB7
12.34 @ 108.7mph
Dmax15 is offline
Old 04-06-2009, 07:35 PM   eBay Motors   #10 (permalink)
techinny
techinny's Avatar
I kinda figured that was where it was seeing as my truck is at the stealer right now (warrenty work) for the second time in less than a year for a fuel leak. Valley gets wet, and smell fuel when I park it. They are supposed to call me when thet get to the "point of failure", so I can see what the problem is. I am more interested in what I have to remove to fix it myself if it happens again. Your pictures helped, thank you.
techinny is offline
Closed Thread
