How To's, DIY and Write ups DuramaxForum How To's, Do it Yourself Guides, and other write ups.
Old 09-17-2009, 12:01 AM   eBay Motors   #11 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
on a lifted truck IMO, their pretty much worthless. too much angle, not enough caltrac.
Hondarider552 is online now   Reply With Quote
Old 09-17-2009, 12:40 AM   eBay Motors   #12 (permalink)
03Dmax90
May be a dumb question to some but what is the purpose of traction bars
2003 GMC EC/SB SLT 5" Straight pipe 6" tip/ EFI Live with Dsp5/ PPE Boost increase valve/ PPE Tie rod sleeves/ 285 Dunlop M/T on 17" Ultra pro's/ Resonator plugged/8000k HID Hi/Lo/Fog
1/4-14.5 @ 90.21mph with a limped tranny and no boost launch
To do list: Suncoast IV, autometer cobalt gauges, S&B intake, FASS or Air Dog, MPI twins, Cognito tie rods/ pitman and idler braces
BFXenon.com
03Dmax90 is offline   Reply With Quote
Old 09-17-2009, 12:54 AM   eBay Motors   #13 (permalink)
Hondarider552
i have no clue man, i bought them because mcrat had some so i have to be cool too.
Old 09-17-2009, 01:39 AM   eBay Motors   #14 (permalink)
MMLMM
Tuning, Tuning, Tuning...
MMLMM's Avatar
Traction bars help prevent axle wrap. Which can lead to wheel hop. Also when launching on the track energy used to forward motion the truck will be lost in teh twisting of the axle. And its reversed energy will be released slower rate then which it initially applied (another words, you wont gain the energy back going down the track).
However with a traction bar pushing the load toward the front of truck it may stop axle wrap, but it could cause axle to 'roll" back with the axle rotation. On 99% of street driven/weekend race trucks, a set of cal tracks or traction bars will be just fine. Your ultimate would be a 4 link preventing any axle wrap or add a reversed biscuit bar over the center of the axle along with traction bars.....
here is a pic of my bars.
EFI Live Sales/Support and Custom Duramax Tuning
MMLMM is offline   Reply With Quote
Old 09-17-2009, 07:15 AM   eBay Motors   #15 (permalink)
Iceman56
Iceman56's Avatar
Originally Posted by IdahoRob View Post
For racing the traction bars should be pointing up higher than the centerline of the truck to push the rear up and the front down(anti-squat) This helps plant the front tires(4x4 only).
The way shown above may be good for pulling(I'm not a puller), but not for the drag strip. That way the rear is trying to lift the front, not press it down.
Look into some software describing centerline/anti-squat/suspension. This will show you the way Mike.
What exactly does that mean Rob? What is the centerline of the truck you talk about?
Thanks for the help
08 LMM,
MPI Twins
40% over injectors
SC4 with 1054
EFI LIVE TUNED BY ROB
MBRP 5" Turboback, Shim Kit, BD Manifold, AirDog 150, Edge Insight Monitor.
Leveling kit, 20" Ultra Lighting Wheels, 285/55/20 Terra Grapplers, Air Lift air bags and pump, ATP Sleeves and Braces.
Iceman56 is offline   Reply With Quote
Old 09-17-2009, 07:16 AM   eBay Motors   #16 (permalink)
Iceman56
Iceman56's Avatar
Mike you wouldn't happen to have a good pic of where it connects to your frame up front would ya?? Trying to decide exactly how the make the bracket up there?
Thanks
08 LMM,
MPI Twins
40% over injectors
SC4 with 1054
Old 09-17-2009, 07:21 AM   eBay Motors   #17 (permalink)
Six-Gun-Todd
Turkey day awaits...
Six-Gun-Todd's Avatar
Location: Second star to the right and straight on till morning
Let me demonstrate why you need traction bars/cal tracs.......20 psi launch at the track last night in 4x4.....truck wheel hopped so hard it broke something in the system and wala no 4x4.
My life in times is complicated, more complicated than most will ever comprehend. Going fast was the only thing that ever made me feel better about being me.
-Six Gun Todd
MPF
www.meyerperformance.com
812.344.4421
Six-Gun-Todd is offline   Reply With Quote
Old 09-17-2009, 08:05 AM   eBay Motors   #18 (permalink)
IdahoRob
IdahoRob's Avatar
Again the pic of above is not right either for track use. The bars are pointed way below centerline thus lifting the front. Good for 2x4 though. They will help with axle wrap though. A set of spring clamps helps without bars.
Think guys. The front tires on a 4x4 do a great deal of the work pulling the truck down the track. Do you want to help unload the front tires, or do you want to plant the front tires? You may not think that helps much on a high 12 second truck, but it does. Then get to setting up a 9 sec truck and it makes a world of difference.
Centerline is the point where you can balance the truck like a teeter-tauter verticely and then draw a line at crankshaft height. Where those two points meet is your centerline. The bars need to be pointing at or above this(either with the back lower, or the front higher, or both). Here is a basic pic from a 4 link software program, but you can use the bottom bar for reference. With this software, I can change different settings on the trucks and find the best setup for each application.
2007 LBZ Daily driver, single stock cp3, stock engine 11.70 @ 115mph on #2, 677 HP
2002 LB7 Fun truck 9.801 @ 139+MPH on #2 fuel only
EFI Live, Suncoast Dealer, Dmax Hotrod Parts
Adrenaline Truck Performance 208.484.3670
IdahoRob is offline   Reply With Quote
Old 09-17-2009, 08:11 AM   eBay Motors   #19 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
Centerline is the point where you can balance the truck like a teeter-tauter verticely and then draw a line at crankshaft height. Where those two points meet is you centerline. The bars need to be pointing at or above this. Here is a basic pic from a 4 link software program, but you can use the bottom bar for reference. With this software, I can change different settings on the trucks and find the best setup for each application.
that does make sense and i myself was curious on how that works so thankyou for the exclamation!
does anybody build traction bars for RC trucks?i bought a set of procomp ladder bars that would have done what your suggesting but i need them a lil longer or shorter to make it work,prefer shorter! they are a 72" ladder bar!
James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Old 09-17-2009, 08:13 AM   eBay Motors   #20 (permalink)
Six-Gun-Todd
I've seen that software before......very useful stuff when it comes to setting up suspension.
-Six Gun Todd
MPF
812.344.4421
