How To's, DIY and Write ups DuramaxForum How To's, Do it Yourself Guides, and other write ups.
Old 10-08-2009, 08:51 AM   eBay Motors   #1 (permalink)
03WhiteZ71
03WhiteZ71's Avatar
Front Bumper Adjustment???/
My front bumper has a larger gap on the passenger side than the driver side that I would like to correct....can't stand the way it looks. Can anybody explain to me what I am getting into fixing this myself??? How hard is it?? How long will it take, etc...???
Thanks.
2006 White Chevrolet Silverado 2500HD, LT3, LBZ. CC/SB.
- 285/75/16 Wild Country Radial RVT's
- Aries Automotive Side Steps
- Stock 3.5" straight pipe
- EGR Blocker Plate
- Quad Stealth 2 @ 90
- 15% tint on front windows
03WhiteZ71 is offline   Reply With Quote
Old 10-08-2009, 08:55 AM   eBay Motors   #2 (permalink)
scottdomine
scottdomine's Avatar
There are a number of brackets that hold the bumper in place. Crawl under there, loosen up some bolts and use a floor jack to get the bumper where you want it, then tighten them down real good.
2002 Silverado 2500HD LBZ FE9 Ext Cab 4x4 LT, 133k miles (08/12/09), American Racing Chrome Nitro's, Goodyear Wrangler MT/R 285/75R16, Resonator plugged, B&W Turnover ball, Amsoil Synthetics throughout truck, Bilstein 5100 shocks, Westin Chrome Bars, Adrian Double Lid Box, Line-X sprayed liner, PPE Economy Tuner Running Level 2(Thanks Husker Diesel)! 4" MBRP Turbo Back w/ chrome tip (Thanks again to Husker Diesel), Pillar Mounted Autometer Cobalt Boost and Pyro gauges
"Contact All in One Logistics or http://www.syntheticmotorsports.org for all your AMSOIL needs!"
scottdomine is offline   Reply With Quote
Old 10-08-2009, 09:00 AM   eBay Motors   #3 (permalink)
RedBowTies88
RedBowTies88's Avatar
that wont necessarily do the trick...if its just loose tighten and you'll be good..if it got bent somehow (mine did) you'll need to use a handfull of washers to space it out and play with it till its corrected
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
Old 10-08-2009, 09:03 AM   eBay Motors   #4 (permalink)
scottdomine
Correct, I guess I was just assuming that the bumper was in good condition.
Old 10-08-2009, 09:12 AM   eBay Motors   #5 (permalink)
RedBowTies88
yea those brackets bend surprisingly easy
LLY Cc/sb 4x4 RED
Old 10-08-2009, 09:16 AM   eBay Motors   #6 (permalink)
maxthis
maxthis's Avatar
Porta Power baby!!!! Works like a charm....especially after smashing a deer at 60mph!! Can't even tell any more!
04.5 LLY 68,000 miles and not a problem one!
-6" superlift
-35x12.50 Toyo MT's on 18" Ultra Predators
-PPE standard, shim kit, egr and resonator blocked
-4" banks turbo back and 5" MBRP miter cut stack
-AFE mouthpiece, K&N Stainless intake
-full Transgo shift kit
-weld in gooseneck plate
-Cowl hood, spray in bed liner
-Suncoast, DSP5, lift pump an possibly a turbo after harvest!
maxthis is offline   Reply With Quote
Old 10-08-2009, 07:15 PM   eBay Motors   #7 (permalink)
Pushrod21
I agree!!!!!
Pushrod21 is offline   Reply With Quote
Old 10-08-2009, 07:17 PM   eBay Motors   #8 (permalink)
seth999
Duramax Forum Moderator
seth999's Avatar
Bfh.........
DD
08" chevy 2500HD cc short bed LTZ
9" fabtech lift/AMP steps
burnt orange paint job
Transgo jr.--Ali is Burnt
5" MBRP Turbo Back--MBRP Downpipe
EFIlive by IdahoRob--DSP 5
Snow Stage 3 Water/Meth
Banks Intake
PPE Lift Pump--Rail Shim--Ported Rail Fitting
seth999 is offline   Reply With Quote
Old 10-08-2009, 07:25 PM   eBay Motors   #9 (permalink)
la77chevy
la77chevy's Avatar
My front bumper was crooked, I thought it was bent, turns out the clips on the top plastic piece were broke on one side and the plastic was just sagging a little.
04 LLY CCSB
LBZ mouthpiece,resonator plug
33x12.50 Toyo MT's on 18'' Eagles
Gooseneck Hitch
Spray in bed liner
Straight pipe with 4''tip
AFE stage 2, EGR blocker
PPE Xcelerator
N-Fab step bars
Tool box, bed rails
la77chevy is offline   Reply With Quote
Old 10-08-2009, 07:50 PM   eBay Motors   #10 (permalink)
blott22
blott22's Avatar
mine were bent so i took the bumper off and bent them all back and put on an still was crooked. so had to put washers in it.
Brent
2006 Chevy LBZ Crew Cab W/T
PPE Standard
Resonator Plug, Transgo Jr.
Banks Ram Air Intake, Glowshift Gauges, Diamond Eye 4" Turbo Back, Limo Tint, 18" Moto Metal 955, Dual Flip Deck, 1200 watt amp, 2 Eclipse 10" subs.
FOR SALE
Diablosport Predator
blott22 is offline   Reply With Quote
