How To's, DIY and Write ups DuramaxForum How To's, Do it Yourself Guides, and other write ups.
Old 11-01-2009, 06:27 PM   eBay Motors   #1 (permalink)
Bama_Cwby
Bama_Cwby's Avatar
Wheel hub
I just found out that both of my wheel hubs need to be replaced on my 04 Silverado. How hard is it do do myself and is there any site that can show me a breakdown on how to do it?
'04 2500HD Duramax LB7, Crewcab, Long Bed, K&N Cold air Intake, 4" exhaust
Bama_Cwby is offline   Reply With Quote
Old 11-01-2009, 06:41 PM   eBay Motors   #2 (permalink)
tpb1976
you can buy them on dmaxstore.com cheapest i have seen them anywhere,the good ones too!
2001 2500hd lb7 a/t. ex cab sb.leather,straight pipe,westin steps,intake horn mod,billet grille emblem,mldgs removed,partially debadged,Quadzilla stealth 2 perfomancetruckproducts.com
tpb1976 is offline   Reply With Quote
Old 11-01-2009, 06:43 PM   eBay Motors   #3 (permalink)
Bama_Cwby
Bama_Cwby's Avatar
I already have the parts. I am planning on doing it tomorrow. I just wondered how hard it is to do. And if there is a site with pics or a breakdown.
Old 11-01-2009, 06:49 PM   eBay Motors   #4 (permalink)
tpb1976
go to diesel place,i think you have to register but they tell you alot of info.
Old 11-01-2009, 06:59 PM   eBay Motors   #5 (permalink)
tpb1976
here you go...got this from DP for you.
Preface: If you are running oversized tires, high hp, or subjecting your truck to extreme shocks on the front, like drag racing or sled pulling, your front wheel bearings will not last much past the 36k mi warranty.
You can tell if the wheel bearing is shot by jacking the truck up til the wheel is off the ground, grabbing the top and bottom of the tire and try to pry it in and out. ANY movement is wear. A stocker will not move. Ours were worn to the point of more than 2" slop at the tire with 50,000mi on the truck. You can drive pretty far worn bearings without fear of the wheel departing the truck due to the captive design of the unit.
This is a sealed bearing assy that includes the hub, lug bolts, bearings, axle spline, wheel speed sensor, and cable. GM has recently updated the part number to #15225770 or AC Delco #FW289. Retail for the unit can be as high as $450 ea, to a low of $150 ea, so it pays to shop around.
Let's Begin/
What you will need:
This image has been resized. Click this bar to view the full image. The original image is 531x405 pixels and 56KB in size.
You will need:
Floor jack
Jack stand
15mm socket and ratchet, wrench will work if you are strong.
21mm socket and BIG ASS breaker bar. Cutting torch will have better luck than a wrench on this *****.
36mm socket and breaker bar. Nut is actually 35.5mm, so a 1 3/8" socket can be beaten on it.
Sharp flat blade screwdriver.
Hammer.
Pliers.
Large C-Clamp.
Grease.
Loctite - Blue. Unless you're selling it, then use red. Blue allows for removal in the future, red is REALLY aggressive.
In picture, not absolutely necessary - impact wrench.
Not in picture, something a foot tall and will support 20lb, like a toolbox. And about 3 beers per side.
Step 1:
This image has been resized. Click this bar to view the full image. The original image is 539x378 pixels and 46KB in size.
Jack side of truck up, and put a jackstand under it. Use frame rail.
Turn ignition to ON position and put in 4wd Hi, and set parking brake.
Remove Wheel.
Step 2:
This image has been resized. Click this bar to view the full image. The original image is 578x422 pixels and 47KB in size.
Unplug the wheel sensor wire near the top of the shock. There are 4 push in wire retainers, you will not save them, so rip them out with pliers. You can cut off the wire if you think it will get in your way.
Step 3:
This image has been resized. Click this bar to view the full image. The original image is 595x439 pixels and 64KB in size.
Use C-Clamp to compress the brake pistons so it will be easy to reinstall.
Step 4:
This image has been resized. Click this bar to view the full image. The original image is 550x438 pixels and 56KB in size.
There are 2 loctited 21mm head bolts that hold the brake caliper frame to the axle support. THESE ARE TIGHT!!! Rotate the steering to get to them easier. Remove the bottom, then loosen the top one so you can remove it with your fingers. You will need to have something ready to support it when you remove the brake assy.
Step 5:
This image has been resized. Click this bar to view the full image. The original image is 556x405 pixels and 55KB in size.
Pull the top bolt and set the brake assy on something that will not stress the brake line. You can destroy a brake line by hanging that much weight on it.
Step 6:
This image has been resized. Click this bar to view the full image. The original image is 528x433 pixels and 57KB in size.
In this picture, the lug at 11 o'clock and 5 o'clock have a retaining washer that holds the disc on the hub for assembly purposes. Remove these by rotating them with a screwdriver, then pry them off. You do not need these, I suggest you throw them away. Once they are removed, you can pull the disc off the hub. If it does NOT come off easy? Torch and a mallet. Do not hit the rotor with a steel hammer or you can burr it up.
Step 7:
This image has been resized. Click this bar to view the full image. The original image is 527x425 pixels and 56KB in size.
This image has been resized. Click this bar to view the full image. The original image is 492x400 pixels and 55KB in size.
Pry the center dust cover off with a sharp flat blade screwdriver. Be fairly gentle as you will reuse this. It's not REALLY necessary, and serves no function whatsoever, but it looks prettier than the axle nut.
Step 8:
This image has been resized. Click this bar to view the full image. The original image is 515x390 pixels and 52KB in size.
That nut in the center keeps the axle from wandering too deep into the differential. Other than that, it does nothing. It is not a load component. It measures 35.5mm, you can remove it with a 36mm socket and breaker bar or tap a 1 3/8" socket onto it. If the truck is in 4WD with the truck in park, it will not spin the hub. The nut is a locking nut, so it will be tight most the way off.
Step 9:
This image has been resized. Click this bar to view the full image. The original image is 532x440 pixels and 57KB in size.
Once the nut is off, spray some WD40 into the center spline, then tap the axle into the hub gently until it stops. It will move about 1". This will make it easy to pull the hub off when it's time.
Step 10:
This image has been resized. Click this bar to view the full image. The original image is 550x404 pixels and 57KB in size.
This image has been resized. Click this bar to view the full image. The original image is 555x427 pixels and 63KB in size.
There are four 15mm bolts that hold the hub on. These are also pretty tight. If you turn the steering, it makes them easier to remove.
Step 11:
The hub should slip right out. You might have to tap the axle a bit more while holding the hub out from the base. Clean all mating surfaces, grease the axle spline and o-ring in base. Dust shield faces forward.
INSTALLATION
This image has been resized. Click this bar to view the full image. The original image is 530x424 pixels and 57KB in size.
IMPORTANT TORQUE SPECS
Hub and Bearing Assembly to Steering Knuckle Bolts - 180 N·m / 133 lb ft
Axle Shaft Nut - 210 N·m / 155 lb ft
Caliper Mounting Bracket to Knuckle, Front - 300 N·m / 221 lb ft
Here's the new hub/bearing assy. There is some electrical tape on the wire holding them together, tear it off.
Line up the spline to the holes with the wire at TDC. If the bolt holes do not line up, you can either take the truck out of 4WD, or pull it off the spline and try to align it better. I suggest align it better. There is a lot of slop in the axle rotation, so you don't have to precisely get the right tooth on the spline for it line up. Screw the axle nut on by hand to hold it in place.
Use a few drops of Blue Loctite (yes I know it comes in a red bottle ) on the 15mm bolts, and bolt the hub back down. Don't forget the dust shield. The wire goes UNDER the tab on the dust shield.
Tighten down the axle nut and washer on the axle. Tap the dust cover back on with the handle of the hammer.
Replace the rotor.
Hold the brake pads apart with your fingers and slide the brake assy onto the rotor. Use loctite and reinstall the two 21mm bolts. Do I know the torques? Uh... REAL tight?
Snap the 4 wire holders into the same holes the old one came out of, and reconnect the connector near the shock.
Put wheel back on, lower truck..
IMPORTANT
Start engine and pump the brakes slowly several times. When you pushed the pistons back into the calipers, they are still sitting far away from the rotors and YOU WILL HAVE NO BRAKES.
Old 11-01-2009, 07:34 PM   eBay Motors   #6 (permalink)
Bama_Cwby
Bama_Cwby's Avatar
Thanks, where was this in DP? I joined and have been trying to find it since you sent me there.
Old 11-02-2009, 06:38 AM   eBay Motors   #7 (permalink)
tpb1976
Actually someone sent it to me when i needed to change my hub assembly !!!
Old 11-02-2009, 07:23 AM   eBay Motors   #8 (permalink)
Chevy*tough
Amsoil T-1 Certified
Chevy*tough's Avatar
yup its pretty simple to do as i have changed one of mine before...Make sure everything is torqued to spec. or you might experience premature wear.
Have a good day
My 01 duramax LB7 AMSOIL Equipped, 143,xxx miles, 4in stainless w/5in tip, EFI LIVE AND ISSPRO GAUGES
265 nittos on Helo maxx8 black. 3rd limp
Your performance PALACE>>HUSKER DIESEL
Donovan Turek
AMSOIL DEALER
ZO#1709749___#715-563-7136
chevy*tough for all your Amsoil needs!
ALL IN ONE Logistics LLC.
Chevy*tough is offline   Reply With Quote
Old 11-04-2009, 09:35 AM   eBay Motors   #9 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
Search "wheel bearing", it's in the DIY section.
Old 11-12-2009, 11:33 AM   eBay Motors   #10 (permalink)
GOGODURAMAX
GOGODURAMAX's Avatar
Have you done this yet? Just wandering how hard it was. I have to do one myself on my truck.
2003 Ext. Cab Gmc 2500HD LB7
PPE Hot+2
PPE Boost Valve
S&B Cold Air Intake
MBRP 4" Turbo Back No Kitty
Moto Metal 955s W/33x13.50x16
Leveled With Keys
Cleared Headlights By ME!
Superdiesel Ported Turbo Mouthpiece In The Mail!
8000K HIDS In The Mail!
Soon To Come Bilstein 5100s
GOGODURAMAX is offline   Reply With Quote
