How To's, DIY and Write ups DuramaxForum How To's, Do it Yourself Guides, and other write ups.
Old 11-06-2009, 12:41 PM   eBay Motors   #1 (permalink)
majorpecs
Engine Cleaning
I couldn't find an appropriate forum for this question, so I'll ask it here.
What do you guys use to clean your motor? Is it safe to squirt it with water while it's running? Are there certain components that I need to cover up while doing this?
2004.5 LLY
PPE Standard
MBRP 4" downpipe back
Autometer Cobalt Gauges
PCV re-route - 2" test plug
LBZ Mouthpiece
CAI
EGR Blocker
Fully Synthetic bumper to bumper
majorpecs is offline   Reply With Quote
Old 11-06-2009, 01:09 PM   eBay Motors   #2 (permalink)
scottdomine
scottdomine's Avatar
I use Simple Green and hot water from the hose. Never had a problem. Then I go over everything w/ some tire shine on a rag to make it all look nice (but the dust sticks bad). Do it every other time I wash the truck.
2002 Silverado 2500HD LBZ FE9 Ext Cab 4x4 LT, 133k miles (08/12/09), American Racing Chrome Nitro's, Goodyear Wrangler MT/R 285/75R16, Resonator plugged, B&W Turnover ball, Amsoil Synthetics throughout truck, Bilstein 5100 shocks, Westin Chrome Bars, Adrian Double Lid Box, Line-X sprayed liner, PPE Economy Tuner Running Level 2(Thanks Husker Diesel)! 4" MBRP Turbo Back w/ chrome tip (Thanks again to Husker Diesel), Pillar Mounted Autometer Cobalt Boost and Pyro gauges
"Contact All in One Logistics or http://www.syntheticmotorsports.org for all your AMSOIL needs!"
scottdomine is offline   Reply With Quote
Old 11-06-2009, 01:11 PM   eBay Motors   #3 (permalink)
seth999
Duramax Forum Moderator
seth999's Avatar
dont do it while its running...just mean green or purple power it, let it soak a sec and use hot water or pressure washer for best results
DD
08" chevy 2500HD cc short bed LTZ
9" fabtech lift/AMP steps
burnt orange paint job
Transgo jr.--Ali is Burnt
5" MBRP Turbo Back--MBRP Downpipe
EFIlive by IdahoRob--DSP 5
Snow Stage 3 Water/Meth
Banks Intake
PPE Lift Pump--Rail Shim--Ported Rail Fitting
seth999 is offline   Reply With Quote
Old 11-06-2009, 01:13 PM   eBay Motors   #4 (permalink)
Seminole
Seminole's Avatar
I use superclean it works well
2008 GMC CrewCab Z71 4x4 LTZ black
1973 chevy 1/2 ton 4x4 shortbox
Seminole is offline   Reply With Quote
Old 11-06-2009, 01:27 PM   eBay Motors   #5 (permalink)
Johnp33
You want it warm not hot, soak it down with ,GUNK citrus cleaner, not the foam, then pressure wash, you want to check, it over and really look to be sure you get at every area with the cleaner, and the pressure washer, removing the inner fenders, skid plates. Pressure wash, from the bottom up, then from the top down, to finish. Spend a little time doing the preliminary checks and preparations and it will come out fine there is nothing that has to be covered it will not hurt your alternator. I have washed thousands and never had one fail. After you get the motor clean, pressure wash with soap into the rad then start it up and rinse threw the rad, straight threw not at an angle you can damage the rad and AC condenser. Rinse the motor and alt off with it running.
I have worked on engines all my life, spent 19 years at FreightlinnerI live in the Kootenay region of B.C. I have a 2007 NBS White 3500 GMC SLE Duramax Alison 17 inch aluminum SRW Crew-cab long-box White linex in the box and black in the wheel wells BW turn-over ball. all stock.
Johnp33 is offline   Reply With Quote
Old 11-07-2009, 01:23 PM   eBay Motors   #6 (permalink)
1HOTDURAMAX
So what's with the warning sticker on the passenger side of the engine that says do not jet clean??
2001 CHEVY DURAMAX LB7 285/75 BRIDGESTONE DUELER REVO'S ALL STOCK EXCEPT; EFI LIVE TUNED BY IDAHO ROB
1HOTDURAMAX is offline   Reply With Quote
Old 11-07-2009, 01:47 PM   eBay Motors   #7 (permalink)
Johnp33
You do not want to spray directly at sealed electrical connections, that is why you do the preliminary inspection and you can wash them just do not put full pressure directly at the connection or you will put water inside the seal and the connection will corrode.
Old 11-08-2009, 10:53 PM   eBay Motors   #8 (permalink)
Tow Master
ROTM Admin
Tow Master's Avatar
I use gunk degreaser.
While the motor is cool and not running spray with water, spray with cleaner let sit, then rinse. I wouldnt spray water on the fuse box or where the engine main wiring harness connects together. Also, use a shower or spray when doing the motor. Dont use "jet" or direct water stream and you should be fine!
Jason
Old 11-15-2009, 08:18 PM   eBay Motors   #9 (permalink)
DuraMac
I have not used anything but water yet, still clean after 4 years of pressure washing :-) Didn't see the warning label till last week installing my EGT. Opps, guess I've been lucky!
Mac
Vehicle 2005 LS Chevy Crew Cab Long Bed, BLACK. LLY, Allison 1000
Tires 285/75/R16 BFG A/T's on Stock Rims
Performance Banks Economind/IQ installed... Intake and Speed Brake on the way ... Banks exhaust next?
Bits & Pieces B&W Turn Over Ball, Firestone Ride-Rite Air Lift Bags, Ameriguard spray in bedliner, Nerf Bars, Bug Guard, Leer Cap, Bed Rack, VHF, Laptop command center
Hauling 36 ft' Damon Challenger, Kayaks, Rescue Gear
DuraMac is offline   Reply With Quote
Old 11-15-2009, 08:28 PM   eBay Motors   #10 (permalink)
Jaylaniuk
Jaylaniuk's Avatar
Yeah, i just crank up the heat and blow her down... Then i clean up with armorall......
2005 Chevy LLY :
3.5" stock straight pipe
Banks Six Gun w/PDA
S&B Cold Air intake
MAXX Cam Leaveling Kit w/ 2.5 blocking in the back
20" XD SPY wheels on 33x12.5 Cooper Discover
6000k HID LOW BEAMS
Jaylaniuk is offline   Reply With Quote
