How To: Install/Replace Centerlink/Sleeves/Tie Rods - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 02-13-2010, 03:13 PM Thread Starter
Durallymax's Avatar
How to Replace Your Centerlink and Tie Rods/Install Sleeves
One of the woes with GM’s IFS is the centerlink. Its factory design causes the front tires to “toe in” under heavy pull when in four wheel drive. The reason for this is the curved ends, as more pull is applied the tires naturally want to pull in as with anything, the centerlink rotates under this pressure and in doing so pulls the tires in due to the design of it. This makes the truck very unstable and breaks parts. To combat this issue, a straight centerlink can be installed. The straight centerlinks eliminate the curves on the ends which prevents the tires from “toeing in”. The other half of the equation is the weak factory tie rods, they measure in at a whopping 13.5mm thickness. The tie rods on my Jetta are enormous compared to the ones on these trucks. Since these products work best when paired together, and also since the tie rods get removed when doing the centerlink install, I’m writing this write-up to cover both. However if you are trying to decide which to do first, do the tie rod sleeves. The centerlink is more for the racers and pullers. It will hurt the trucks turning radius somewhat and cause odd tire wear if you make a lot of turns on pavement. However, the decision to purchase one is up to you I’m just here to show you how to do it. I will also state at this time that it is strongly suggested to get an alignment after installing a centerlink.
Who Makes Sleeves?
Upstate Diesel Performance
Pacific Performance Engineering
Super Diesel
Crank It Up Diesel
You can also make some yourself
Who Makes Centerlinks?
Super Diesel
Crank It Up Diesel
NOTE: The above list is just the manufacturers I know off the top of my head who make these products. If there are others let me know and I will add them.
The Install is pretty straightforward; the only special tool you will want is a tool to separate the steering linkage as it is a press fit. Otherwise you just need a 22mm socket (7/8”) to remove the wheel, a 21mm socket and wrench, and an 18mm wrench. You’ll also need a hammer and a floor jack. Scale of 1-10 I’d rate this at about a 3. It’s pretty easy, but it has some difficult parts.
Parts you will need:
Just Sleeves
Just Centerlink
Centerlink & Sleeves
Optional
New Inner Tie Rods
New Outer Tie Rod Ends
How to do it
1.Start by jacking the truck up and removing both front wheels. Now place jack stands under the truck and remove the jack. It’s best to be safe, I knew a few people who have been killed by falling vehicles, semis, lawnmowers etc.
2.Now loosen the jam nut that holds the tie rod end to the tie rod using a 21mm wrench. Do this on both sides. Only do this if installing sleeves or replacing tie rods.
3.Next remove the locknut that holds the tie rod end to the steering knuckle. Do this on both sides. Then give it a tap with a hammer to pop it out of the knuckle.
4.Now remove the outer tie rod end from the shaft by threading it off counting how many full turns it takes until it is off. Write the number down, it may be different from side to side. Again do this for both sides. Now thread off the jam nut of tie rod sleeve if present. Again only do this if replacing tie rods or adding sleeves. Skip 5 is you already have sleeves or are replacing the inner tie rods.
5.At this point if you are installing sleeves and not replacing the inner tie rods simply thread the sleeve onto the tie rod, then thread on the outer tie rod end using the same amount of revolutions as it took to remove it, then reinstall into the steering knuckle, install the locknut and torque to the spec below. Then tighten the sleeve to the outer tie rod end, the sleeve is your new jam nut. Do this on both sides and you’re done.
6.If you are proceeding to remove the centerlink, start by removing the steering stabilizer. To do this remove the nut that is on top of the centerlink using an 18mm I believe. It’s a locknut and it’s hard to get at so it will take awhile to get it off.
7.Next remove both of the nuts that hold the pitman and idler arms using a 21mm. Either using a steering linkage puller or a hammer separate the centerlink from the pitman and idler arms. You can use a tie rod fork put it may damage the seals.
8.Now your centerlink is free from the truck, slide it out either on the passenger side or driver’s side.
9.Now you need to remove the inner tie rods from the centerlink. Slide the boots back and then using a BIG crescent wrench, thread the tie rod ends off, then clean the threads and apply loctite to them, then reinstall into the new centerlink and slide the boots back.
10.Now reinstall the centerlink into the truck.
11.If you didn’t replace the inner tie rods, then you simply just need to reinstall the tie rod ends into the steering knuckles. If you did replace the inner tie rods then follow step 5 at this point.
12.Now just torque everything to spec and get an alignment if needed. It’s that simple.
Torque Specs
30lb-ft/40N-m: Nuts that secure the Idler and Pitman arms as well as steering stabilizer
48lb-ft/65N-m: Nuts that secure tie rod ends to steering knuckle as well as the jam nut
Durallymax is offline
post #2 of 7 (permalink) Old 02-13-2010, 03:49 PM
Medic949's Avatar
Send a message via Yahoo to Medic949
Thank you. I needed that.
RIDE: 2006 GMC LBZ/Allison
SUSPENSION: Stock and Leveled
AIRFLOW: Banks Ram Air with Super Scoop. Banks Cat back straight pipe.
TUNER: Banks Six-Gun with PDA
Mobil1 Synthetic oils
Things to do: EGR delete
Cat delete
Quad S2
Transgo Jr
Medic949 is offline
post #3 of 7 (permalink) Old 02-13-2010, 04:27 PM
CaseBlackKnight's Avatar
Send a message via MSN to CaseBlackKnight
very nice, thanks
Kyle
07 ccsb lbz
MPI Twins with stock motor
Built and tuned by Idaho Rob
New project: 04 Kodiak
Sold:
02 Chevy 2500 LB7 extended cab long box
94 12v cummins 5 speed manual RCLB 4x4
http://www.youtube.com/user/1370Blac...t?feature=mhee
www.atptrucks.com
CaseBlackKnight is offline
post #4 of 7 (permalink) Old 04-24-2010, 11:32 AM
BJJ-DURAMAX's Avatar
Thanks for the info..!
I have not done these mods...yet .
I was advised to at least do the tierod sleeves. What about doing idle arm braces...?
I am not going to be doing any sled pulls , or hard core strip racing , but of course will be doing some street play.
Now with my EFILIVE if I do even a modest 2wd boosted launch the tires break loose . I would like to be able to do a 4wd boosted launch...now and then , not all the time.
Will just the sleeves be enough or should I do the braces as well ? My tunes range from stock , 2 tow tunes at around 400rwhp , street 475rwhp , and race 530 rwhp.
Thanks .
carpe diem de momento mori
'06 LBZ CC LB DRW
ATS Stage II, Co-pilot, EFI DSP-5, Banks Ram Air,Fass-150, egr/rezo blocked, pcv reroute, PPE rail fitting, race valve, 4" T-back no kitty no muff, Angel eye fogs w/ H.I.D 8-k, Angel eye mains w/ H.I.D 8-k, L.E.D markers, B&W flip hitch, no stinkin' badges,coming soon Trents compounds s475 & tuning
TOYS:
'05 21' Chaparral SSI 350 HO
'06 Keystone Raptor Toy Hauler 40'
'04 SEA DOO 3D SKI
BJJ-DURAMAX is offline
post #5 of 7 (permalink) Old 05-01-2010, 10:18 AM Thread Starter
Durallymax's Avatar
braces are better for street use IMO
post #6 of 7 (permalink) Old 10-18-2010, 06:14 PM
blaineGMC's Avatar
Good info. How important is it to get an alignment after installing sleeves. I dont want to see any extra tire wear?
Blaine
04 LLY Suncoast/Precision ML by me. Tuned by Rob.
AFE, MBRP, Mag-Hytec, Merchant Automotive, SSBC, Bilstein
For EFI Live go to:
blaineGMC is offline
post #7 of 7 (permalink) Old 10-18-2010, 06:39 PM
oleblack03's Avatar
^^^^Very important, if not you will ruin your tires, and your mileage will go down
Owner-H&K Diesel Performance
Rig: 2003 Black ECSB Silverado LT
Performance: 40% Exergy Injectors, Straight exhaust, Profab downpipe and intake horn, EFI Live w/dsp5 tuned by IdahoRob, ADII 165, Cobalt boost and pyro guage w/ Aeroforce Interceptor Scanguage, FabTech tie rods, S&B Intake, PPE boost valve.
oleblack03 is offline
Closed Thread
