| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | How To's, DIY and Write ups DuramaxForum How To's, Do it Yourself Guides, and other write ups. |  | |
06-02-2008, 05:07 PM
eBay Motors
#11 (permalink)
| | Member
| You can read these threads and see a lot of talk about how to drill a hole. This is all very useful information, keeping the chips out of the turbo, but the question I have posed in the past, is, ... where is the best location to put it? The tech at BullyDog just says "pre-turbo is best, but it can be post-turbo". I had already planned on pre-turbo, but all of the manifold locations I can see all seem to be so close to at least one cylinder that I am not sure how accurate they could be, being blasted all the time. Longevity is another question. On my 02' there is a nice sweep coming off the drivers side manifold, running up to the "Y" just before the turbo. There is a heat shield and I would have to trim back, but not sure how thick the pipe is. I wanted to avoid welding in an adapter.
If any of you have pictures that would clear up a lot of my questions.
__________________ 02' Chevy Crew Cab
Short box 4X4
BullyDog PowerPup
Fifth Wheel |
| Advertisement
06-02-2008, 07:06 PM
eBay Motors
#12 (permalink)
| | Duramax Forum Moderator
__________________ KYLE
05 Chevy LLY Crew Cab LT Dually 4x4, Crank it up Diesel Tie rod sleeves and centerlink, BD Diesel Remote Fuel Filter, EGR Blocked, TTS Dual Lift Pumps, FPRV Shim, Bullydog Outlook Monitor, AFE Stage 2 CAI, BD Diesel Manifold, Diamond Eye Turbo Direct Pipe, Diamond Eye 5" exhaust straight piped, Level Kit, Suncoast Stage IV w/ 1056 Torque Converter and Allison Deep pan EFI Live Tuned by IdahoRob!!!!
06-03-2008, 04:13 PM
eBay Motors
#13 (permalink)
| | Member
| Thanks for the links to the pictures. I will have to add that site to my favorites. Lots of good information out there. They make it look easy. Hope it turns out that way.
Short box 4X4
BullyDog PowerPup
Fifth Wheel |
06-23-2008, 09:46 PM
eBay Motors
#14 (permalink)
| | DF Sponsors
| It actually is very easy. No need for grease or a running engine. Just take your time and tap a little and then try the fitting. If it's not tapped enough, tap some more and try it again.
__________________ David Murphy www.DieselManor.com info@DieselManor.com
Hours: Mon-Fri 8am-5pm EST
Telephone: 603-497-2281 ------- Taking the Mystery out of Diesel Performance™
PRODUCT LINE: MBRP Exhaust, AFE, Volant, S&B, ISSPRO, DiPricol OPTIX, Autometer Performance Gauges, Superchips, Edge Products, Painless, Vulcan Performance, Mag-Hytec, and more... - Please call us at 603-497-2281 for technical information or special pricing. - DieselManor Guaranteed Pricing Policy ---FREE SHIPPING---
24/7/365 Secure Shopping Cart |
| Advertisement
