| Premium Membership | |
| | | How To's, DIY and Write ups DuramaxForum How To's, Do it Yourself Guides, and other write ups. |  | |
03-15-2008, 01:58 PM
eBay Motors
#1 (permalink)
| | The Sheriff
| EGT probe install! Start the truck and let it idle when you drill the hole. it will keep the shavings out of the manifold. Make sure you are useing the correct size bit.. or you could damage the manifold win you go to tap it for the probe.
__________________ Craig2001 Chevy, 4 door, short bed,D-Max, 2 wd. Mods.. straight piped exhaust,  Custom dent and scratch in passenger side rear panel.. Special Thanks goes to the person in the WAL-MART parking lot for installing it for me,  NEW MEMBERS-PLEASE HELP US HELP YOU.. FILL OUT YOUR SIG. IN THE USER CP. Your Sig should have the Year, Make, Model and any Mods. |
| Advertisement
03-15-2008, 02:00 PM
eBay Motors
#2 (permalink)
| | Gear Jammer...
| First pull the Pass. side tire and inner fender.
Drill on the little flat spot buy the top/rear most bolt on the manifold.
Use about three or four different size drill bits starting small and working up to the size u need (this keeps the shaving small). Dip the drill bit in some grease each time u drill, this will hold most of the shavings.
Once you get the hole drilled to size, do the same thing with the tap, dip it in some grease and tap away.
Install the pyro and away u go!
I have never installed a banls prob but they are all pretty much the same!
__________________ 05 Chevy 2500HD dark blue reg cab ZF-6 speed/W South Bend Clutch ,Power by EFI Live W/Dsp2 , PPE GT4094R, ATS CP3x2, Modified Volant intake, MBRP front pipe, 4" side pipe, Holley Blue lift pump, Isspro gauges,Cognito Braces, SD Centerlink, Caltracs, ATS Tie Rod Sleeves Best ET 12.53@ 109 mph 04.5 Chevy 2500HD, silverbirch, D/A, CC/SB , EFI live, SCIV w/ATS 5Star converter,McRat shim mod, Wicked Diesels modded FPR, Kennedy dual lift pump, Modified Volant intake, Cognito Braces,CUD tie rod Sleeves, EGR BLocker,Diamond eye Down pipe, 4" dual exhaust, Elocker, MA Tcase Fix, B&W GN Hitch Best ET 13.53 @ 101mph |
03-15-2008, 03:41 PM
eBay Motors
#3 (permalink)
| | Junior Member
| There's a few things that you can do to optimize the chance that no metal shavings are circulated back into your intake system:
1. Have your truck running / idling to create positive air pressure (blowing the drill bits outward)
2. Cover the drill bits in a quality grease before drilling. Make sure to start with a small bit and step it upward 3-4 times before achieving the desired hole.
3. Drill slow.
4. Have another person hold a vacuum right next to where you are drilling, to create additional air vacuum (negative pressure) outward for the metal shavings.
5. Make sure to tap the hole also with the truck idling and vacuum turned on.
Wear eye protection to avoid having the metal shavings fly into your eyes. |
04-20-2008, 01:30 PM
eBay Motors
#4 (permalink)
| | DuramaxForum Fanatic
| ive heard its not a good idea to put grease on the drill bit because the metal fragments will stick to the excess grease from the drill bit on the inner side of the manifold...making nearly impossible to vaccum out....the grease doesnt make drilling much easier
__________________ 2006 Chevy Duramax LBZ 3500HD CC Dually LT 4X4
Allison 6-speed automatic. Leather Heated Seats, Bose XM Stereo w/6CD changer
4" MBRP turbo back exhaust, 5" pollished stainless steel tip, & Turbo Resonator plugged!
Edge Juice with Attitude.
Painted front bumper, bowtie emblem, tow mirrors, fender flares, and bodyside molding, Cadillac style handles, Recon Fire and Ice light bar, clear cab lights and 3rd brake light.
2008 emblems
B&W turnover ball
Michelin LTX A/S 265/75/R16, 2" spacers
Lost Kitty!! |
04-20-2008, 02:10 PM
eBay Motors
#5 (permalink)
| | The Sheriff
| Ive never heard that but it does make since to me...Thank you for bringing it up
04-20-2008, 04:03 PM
eBay Motors
#6 (permalink)
| | DuramaxForum Veteran
| When I drilled and taped my manfold I did not use grease. I just started the truck and let it idle. Then I drilled and taped it.
__________________ John
EFI LIVE with McRat tune, DPS5, PPE Lift Pump, 4inch Turbo Back Strait Piped MBRP Duals, EGR block off, AFE stage 2 intake, Turbo resonator blocked off, 6000k HID kit, 305/75/16Super Swampers on stock rims, Auto Meter boost and pyro gauges, Killer sound system, Limo tint all the way around, Suncoast Stage IV built by me. NO TALKING JUST LINE IT UP |
05-02-2008, 05:44 AM
eBay Motors
#7 (permalink)
| | Member
| I own a shop and a buddy of mine is a GM tech and were going to pull the manifold off and not take any chances when we install the pyro/boost gauges in my truck.
Randy
__________________ 08 Chevy 2500 HD Crewcab LMM/Allison, DPF delete, MBRP 4in turboback exh, PPE Race programmer, Autometer Ultralite EGT/Boost gauges, 285/65/18 BFG KO's on Gear Alloy Double Pump 18x9's, Westin chrome W2W step bars, Amsoil Dealer/User |
06-02-2008, 11:29 AM
eBay Motors
#8 (permalink)
| | Junior Member
| I used the "truck Idle" and grease...Did whole install in 10 mins...as opposed to hour and removing manifold. Side note...With the Engine Idle On, pressure is VERY strong so unless you manhandle drill in there won't be any shavings...Thanks guys...great install tip
__________________ If your not living on the Edge your taking up too much space.
2008 2500 HD LMM Duramax
Banks Power PDA/6 Gun/Intake/Exhaust
20" XD Series w/bead locks
RBP RX Grill
4" lift |
06-02-2008, 11:41 AM
eBay Motors
#9 (permalink)
| | D-Zule Vin-door
| Everyone has their own way of doing it but, as long as you get a good end result with no shavings in the turbo, it was a GOOD install!! |
06-02-2008, 03:12 PM
eBay Motors
#10 (permalink)
| | Duramax Forum Moderator
| i have installed probaly 10 or so and i always let the engine idle and drill away and i use a 5/16 Titanium bit with a the 1/8 NPT pipe thread and so far i have never had any problems but the one thing i will not do with out is a good drill bit and the titantium are some of the best..
__________________ James
My Truck now,1987 Chevy 2500 350 tweaked,6" SuperLift,350 V8 bored 60 over,Elderbrock headers Cam and Titanium Rockers,750 Twin Pumped Holley Carb and some other goodies.crank dynos over 400HP. |
| Advertisement
