| How To's, DIY and Write ups DuramaxForum How To's, Do it Yourself Guides, and other write ups. Only How TO post belong in this forum!!! If your NOT showing/telling us HOW TO then DO NOT post it here. |
| | eBay Motors #31 (permalink) |
| Senior Member Join Date: Jun 2010 Location: Margate, Fl
| will be looking into doing this in an 03.
__________________ [James - 22] 2003 Chevrolet Silverado-2500hd Duramax 6.6l lb7 allison transmission | 7-9 inch Cognito Lift | EFI live tuned | 5 inch MBRP Turbo Back | 4.5 inch Bills Custom Intake S&B Filter | Pro Fab 3 inch Downpipe | 3.5 inch Profab Turbo Horn | 38/13.5/R20 Toyo Open Country MTs | 20x14 American Force Independence SS | |
| | eBay Motors #32 (permalink) |
| Duramax Lifetime Supporter Join Date: May 2009 Location: Riverside, CA
| It is a great idea, but with free updates from google maps, the free app for my droid makes factory nav units obsolete...
__________________ 2005 HD2500 Silverado 2WD EC LB (FE9 - Federal Emissions) 91K miles Goodyear Wranglers 265/70R/17, LBZ mouthpiece upgrade, BD Exhaust, MBRP DP, Banks Ram-Air with SuperScoop ,4" SS Corsa Exhaust System w/gutted kitty, Amsoil Dual Oil Bypass Filtration, Aux Radiator (Engineer 837) installed, Firestone Air Bags, Allison extra capacity Tranny pan, MagHytec Rear Diff Cover, Synthetic Fluids ...Mike L tranny cooler) 2008 Towing Mirrors with Leveling MOD, PCV reroute, Fumoto Valve, Mad Jacks fuel fiter access door. Running 2% BioDiesel with Optilube XPD,TTS dual lift pumps with Nictane Aux Fuel Filtration. EFI (Tuned ECM from Duramaxtuner) Edge Insight CTS to control the tunes And the best part of all, no payments and title in hand |
| | eBay Motors #33 (permalink) |
| saw what you did there Join Date: Jan 2009 Location: Seattle
| It's a gigantic help in resale value however...
__________________ Kevin: SOLD!!!!!!!!! MY07.5 3500HD SRW. LMM. LT. CCLB. 4x4. 8" Cognito, 20" SOTA'S, PPE Stage 5, SDP S475 Twin Turbo Over Stock, EFI Live by DuramaxTuner, ADII. MY11 Volkswagen Golf TDI 6MT. 6K Lows, 3K Fogs, Tint. CLICK BEFORE YOU POST! |
| | eBay Motors #34 (permalink) |
| Evergreen Oil Burners Join Date: Feb 2009 Location: Lake Forest Park, Washington
| might have to look at if its possible for my truck the full screen display is much nicer
__________________ 03 Chev CCLB 500HP on STOCK trans/fuel/turbo ![]() built trans and lift pump coming soon! special thanks to ADP, ATP, HDP, UDP, BDDP, MJS |
| | eBay Motors #35 (permalink) |
| DuramaxForum n00b Join Date: Feb 2011 Location: santa paula,ca
| programing In many cases, gm dealers are struggling to program these units after they are installed. Here is a source for all the help you will need. These guys can program them, and they can get or make you anything you need to get it right. They are the go to guys for gm factory NAV/DVD CPS Audio/Video, in Rohnert Park, Ca. Service is quick, painless, and affordable. 1 707 588 9300. There is a lot of good info on the net about this stuff, and if you sort through it all, you can figure most of it out. Cps can save you a ton of time, money, and frustration!! I'm very happy I found them!! I switched my factory touch screen nav to one that will also play DVDs, and added the factory rear entertainment with wireless headphones. After the dealer said they couldn't program the head unit, CPS programmed it in a day, made me a harness for the rear screen, and added an ir deal to run the headphones. Painless!!
__________________ 2008, GMC Sierra, SLT. Edge Evo Race, AFE cat/doc delete, AFE dpf delete, magnaflow 5" dpf back. 6" suspention lift, with 285-75-17. Last edited by nelson#109; 03-16-2011 at 08:27 PM. |
| | eBay Motors #36 (permalink) |
| Junior Member Join Date: Feb 2011 Location: winnipeg , canada
| So my question is can you retro fit a sat nav into an 04 with onstar because all the rights up's I've seen are for units without onstar. Last edited by roadless110; 03-25-2011 at 03:45 PM. |
| | eBay Motors #37 (permalink) |
| Cps Call CPS audio visual. They will tell you if you can.
__________________ 2008, GMC Sierra, SLT. Edge Evo Race, AFE cat/doc delete, AFE dpf delete, magnaflow 5" dpf back. 6" suspention lift, with 285-75-17. |
| | eBay Motors #38 (permalink) |
| Will this fit backwards? Chevy Tahoe CD MP3 Player Radio It says for an 07, but hoping it will go backwards to fit an 06 Silverado.
__________________ 2006 Silverado, 6.6 LLY, CC/LB dually. Stock except for EGR Block plate and PCV Reroute |
| | eBay Motors #39 (permalink) |
| Junior Member Join Date: Dec 2010
| OK, so factory navs will work, but whats a good aftermarket that fits perfectly in factory nav spot ? I have heard of lots of problems with factory navs in relatively short time periods, so lets upgrade to nav, but make it better than the factory stuff ? ? ? ? |
| | eBay Motors #40 (permalink) |
| how about for a 2011 silverado? |
