How to: Replace rear axle seal. - Chevy and GMC Duramax Diesel Forum
Old 10-13-2010, 07:24 PM   eBay Motors  #1 (permalink)
ph1ngering's Avatar
Newbie here!! I didn't see this listed any where, so after doing some research on the site, I figured I would docuement the process as I did it tonight. Straight forward and pretty easy. But might help someone out like me that never did one before.
I found my driver side seal was leaking, when I rotated my tires. Had gear oil all over my rotors and lugs. So checked the oil level in the Diff and it wasn't very low, so it must have just started.
Get the parts: Brake cleaner, seal, Blue RTV, Blue thread locker, locknut socket and Diff oil. The oil I picked up already had the limited slip additive in it, one less thing for me to remember.
Jack the truck up and put on stands:
Remove the tire and take out the 8 bolts holding the axle in:
Slide the axle out:
Note the paper gasket on the axle, no auto store near me had it in stock, so thats why I picked up some RTV. This needs to be scraped off the hub and the axle and cleaned.
Next you can remove the Caliper (two 19mm bolts on the back) and then the rotor will just slide off. Unless you have never had it off then you'll need to beat it off..
The inside of the hub:
Grab a screw drive and pop out the snap ring:
Next slide out the square Key:
Then unscrew the Lock nut from the splin with the Lock nut socket:
Now the hub is ready to come off, mine took a little pry-ing, but once it loosened up it came right out.
ph1ngering is offline   Reply With Quote
Old 10-13-2010, 07:25 PM   eBay Motors  #2 (permalink)
ph1ngering's Avatar
The spindle... usually the seal is in the hub when you take it off, mine stuck to the spindle, so I slid the bearing off and placed back in the hub. Then pry-ed the seal off the spindle.
After getting off the seal, I saw that the auto part store gave me the wrong ones, they are for a 1500 or a non hd truck. So back to the parts store. Here are the correct Napa seal:
The hub with out the new seal in it, just started it and the put a piece of plywood over it and hit with a dead blow till it was in all the way. Sorry forgot to get a picture of it.
next steps:
Slide the hub back on
Hand tighten the lock nut on the spindle, then torq to 52 ft/lbs. This will seat the hub on the spindle properly
Next back off the lock nut till its just finger tight and line up the key slot so you can slide the key back in.
Once the key is, place the snap ring back on.
Next I RTV the hub before sliding the axle back in.
Make sure to line the hole back up when sliding the axle in and then torq the 8 bolts to 152 ft/lbs. Doing it like you would lug nuts altering side to side.
Then slip the rotor on, put the caliper back on, the wheel on.
Last step top off the diff fluid till its just coming out of the hole.
Old 10-13-2010, 07:50 PM   eBay Motors  #3 (permalink)
Duramaxpower29's Avatar
Nice write up just getting ready to do this myself
2006 GMC ECLB 2500HD LBZ Duramax w/ ZF-6 speed
Modded Intake
4" exhaust into 5" single miter cut stack
PCV re-route
EGR blocked
Turbo silencer plugged
Zone 2" leveling kit
Cognito tubular upper control arm kit
325/60/18 Nitto Terra Grapplers
Renegade Wheels
Trans-go Jr.
Firestone ride-right bags
Diamond Eye downpipe
EFI Live DSP5 Tuned by Jeff
:rockin
Future mods= airdog,built trans,cheetah turbo, freshen up engine with head studs and stronger rods and pistons,traction bars,and many more.....
Duramaxpower29 is offline   Reply With Quote
Old 10-13-2010, 07:53 PM   eBay Motors  #4 (permalink)
ph1ngering's Avatar
Thanks!
Missed a couple pictures, but got the seal to do the other side, so i'll try to fill in the blanks next week when i do the other side..
Old 10-13-2010, 07:54 PM   eBay Motors  #5 (permalink)
doops22's Avatar
great write up! :rockin
Adam 22
LMM. Spicy Tuna. 5" exhaust. 6" lift. 35's.
ROTM September 2010
Thanks to Alligator and TPT
doops22 is offline   Reply With Quote
Old 11-04-2010, 07:04 PM   eBay Motors  #6 (permalink)
jaguar3500's Avatar
rear axle seal replacement
Great info , I found it very helpfull. The one thing that I would make sure you have BEFORE you start is the right spindle socket- I spent 3hrs driving around to find one because no one had a listing for it. Finally found one at NAPA by matching a spindle nut which they did not know it fit because thier books did not list it .
Good luck Jaguar3500
2005 chevrolet 3500 dually 4x4 LT crewcab
MODS to truck
- 4" 409ss cool dual exhaust/ 4040 aero turbine muffler
- Diamond eye QUIET TONE front pipe and down pipe
- RDL Headers and 2" up pipes
- 2006 cold air intake with turbo mouth piece
- RDL full Y bridge - no emiission crap
- Banks 3" boost tubes, BD intercooler
- BD trans Valve Body and deep pan
- THE BEST - EFI LIVE by IDAHOROB
- cognito 2" leveling kit ,steering stabilizer ,keys, braces,pitman and idler arm support hd tie rod ends
jaguar3500 is offline   Reply With Quote
Old 11-04-2010, 07:24 PM   eBay Motors  #7 (permalink)
Evergreen Oil Burners
SteepyBS's Avatar
good write up!
agreed about the spindle nut, we ended up taking a picture to the specialty tool shop to find one, turned out to be the same as a 90s half ton dodge IIRC??
03 Chev CCLB
500HP on STOCK trans/fuel/turbo
built trans and lift pump coming soon!
special thanks to
ADP, ATP, HDP, UDP, BDDP, MJS
SteepyBS is offline   Reply With Quote
Old 11-04-2010, 07:35 PM   eBay Motors  #8 (permalink)
edigert's Avatar
Just did this. My first time--I could have used your write up, but I got through it.
2003 LB7 Arrival Blue Extended Cab-Short Bed
2 Wheel Drive
Straight Piped
Pace Arrow Bed Cover
92,000 miles as of 1/1/13
edigert is offline   Reply With Quote
Old 11-04-2010, 08:22 PM   eBay Motors  #9 (permalink)
KYdmax's Avatar
Great write up dude,
Landis: '08 LMM, Black, LTZ, CC, SB, 4x4, Edge Evo Race CTS, Black MBRP 4" Turbo back straight pipe, Debadged, No door moldings,RBP Grill(slightly modified) Black Bowties front and rear, all headlight on mod, Leveled, 18"Black Rockstars with 285/65s Nitto Terra Grapplers
'00 Cherokee, Ready for the trails
Lol, I get confused easily Josh. You can't just run up and take my fkn glue and scissors and tell me arts n crafts time is over without a reason.
KYdmax is offline   Reply With Quote
Old 11-04-2010, 08:25 PM   eBay Motors  #10 (permalink)
Im Superrrrr!
jmaz268's Avatar
Very Nice Write up man.....with good pics.
Goes by John
--2001 ECSB
SDP Big Single, Wehrli Dual Fuelers, 50% sticks, Front Coilover Conversion, Anorexic .....much much more
Sponsored by Creatures of the Night Performance and SDP
--2005 CCLB Dually
The tow pig
Tuned and Edge Insight CTS
jmaz268 is offline   Reply With Quote
