How To: Block Heater FAQ - Chevy and GMC Duramax Diesel Forum
post #1 of 147 (permalink) Old 11-24-2010, 11:51 AM Thread Starter
Oxcart's Avatar
Exclamation How To: Block Heater FAQ
I put this together, in hopes it will answer a few questions for some.
Block Heater FAQ
How much power does the heater draw?
About 7-10 amps.
What size extension cord do I need?
A 14 gauge extension cord will work for 25-30' run. If you are going to run 50' or so, its a good idea to step up to a 12 gauge extension cord.
Can I leave my truck plugged in all night?
Yes, many people do, but if it is not super cold in your area, 3-4 hours before start-up works very well.
Can I just use a timer?
Yes, I use a 15 amp timer (10amp should works just fine too) and I set it for 2 hours before I leave.
When do I need to use my block heater?
Anytime really. Here where I live it only gets down to maybe 40F at night. But I like having the truck warm up a lot faster when I start it. Also a warm start-up is better on the engine.
Do I have to use the block heater?
No. The Duramax is capable of starting up even in pretty cold climates without being plugged in. In cold climates, it will take quite some time to warm up however.
I cant hear my block heater, is it working?
The block heater is simply an element (kind of like a probe) in the coolant stream in the block. When plugged in, power flows thru it and causes the element to get hot. This heats (or warms) the coolant in the block. You wont hear anything really, the same as you dont hear power running thru the power cord itself
Does the block heater automatically turn on and off?
Some trucks have a thermo-plug. It only allows current to flow when it is below zero. Look at teh end of the plug on your block heater, does it look like a normal plug, then it probably is. Does it look squarish, and look like there is extra plastic, and bigger than say a normal extension cord plug? If so, it most likely is a thermo-plug. (You can actually cut it off an replace with a normal plug avail at a hardware store) .
Where is my block heater plug?
Its on the passenger side, tapped up or zip tied in some factory loom, running down from the passenger side battery to the frame rail. If you find it, and then cut back some of the tape and loom, you can gain an extra foot of length or so, and it will reach further. If you leave it taped up like factory, you will notice it doesnt reach very far.
Do I have a Block Heater?
Yes, All Duramaxs have one, I if you think you dont, you need to keep looking, its there...
Good Luck!
Mike
2008 LMM
2002 LB7
Running MMLMM "Grim Reaper" tunes
Oxcart is offline
post #2 of 147 (permalink) Old 11-24-2010, 11:54 AM
saw what you did there
theunderlord's Avatar
Pics! Nice write up Mike.
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
post #3 of 147 (permalink) Old 11-24-2010, 11:58 AM Thread Starter
Oxcart's Avatar
Thanks for the pic. That will help a bunch.
Mike
2008 LMM
2002 LB7
Oxcart is offline
post #4 of 147 (permalink) Old 11-24-2010, 12:02 PM
Thanks for the info I appreciate it.
2007 GMC crewcab classic long bed.7 Inch lift 315/75/17 on moto metal with BFGA/T ,after market tail lights,headlights, stainleess grill piece,bull bar,Viper alarm and remote start,topper, touch screen eclipse stereo with camera,running lights around the truck,topper,bed liner.traction bars. 5 inch Diamond eye turbo back straight piped . DE Down pipe.Autocal EFI,DSP5 SWITCH
HRLYGUY2 is offline
post #5 of 147 (permalink) Old 11-24-2010, 12:54 PM
JoshG's Avatar
Nice write up. question though. i had mine plugged in all night at 1*F overnight and started it this morning at 5*F and it still took a very long time to warm up and then turn over. also had a good amount of white smoke from being so cold. but it never went compleatly away. when i would get on it after the truck was up to temp it still blew white. is it just cause it is so cold. hasn't been over 10*F yet.
03 LB7 CC/SB 185k 6in fab tech 35.12.5 17 stts
5in custom build exhaust into 6in stack axle dump. Built front bumper with 2 light bars. Hids, ppe hot level 3, fass, biv, intake, 2-8" sub, infinitys, alpine deck, PAC exhaust break, air horns, brand new front end, leds in everything,
Sheet Metal workers local #55
90 xj on 40s and tons 4 linked with coilovers and half backed.
JoshG is offline
post #6 of 147 (permalink) Old 11-24-2010, 01:02 PM
gr8shot's Avatar
It's probably steam, just like from a gasser when it's cold only it seems to need to be colder before a diesel's exhaust will steam like that.
Nice write up Mike!! should help a lot of folks :rockin
Jesse
2004 LB7
Tastefully modded
Lots of miles
Built by Husker Diesel
gr8shot is offline
post #7 of 147 (permalink) Old 11-24-2010, 01:30 PM Thread Starter
Oxcart's Avatar
There was a service bulletin that some trucks got a code and the dealer replaced them with a thermostatically type cord. Perhaps you have one of these and it doesnt kick on until outside temp is below zero???
Could you post a picture of the end of your cord (the part you plug in)
Mike
2008 LMM
2002 LB7
Oxcart is offline
post #8 of 147 (permalink) Old 11-24-2010, 01:33 PM
DuramaxForum Guru
kman2468's Avatar
Send a message via AIM to kman2468
good post mike!
Kyle
13 lml stock
sold 04.5 lly
kman2468 is offline
post #9 of 147 (permalink) Old 11-24-2010, 01:36 PM
Diesel Blunt
AcidAnton's Avatar
Thank you for the FAQ! Helped answered my questions
-Dave-
GMC 2003 Sierra 2500HD SLT
4X4 CCSB , 6.6L Duramax LB7, Dark Leather
Mods: PPE Boost Valve, Boost Gauge
In Development: 6" Single Stack
On Its Way: Hypertech Power Programmer III
AcidAnton is offline
post #10 of 147 (permalink) Old 11-24-2010, 02:22 PM
last year i was running my block heater on a timer and not sure of the gauge of cord but it may have been a smaller one, fairly long aswell, like an electric lawnmower cord. anyways one morning it had melted the plug and the plastic around it. now i am scared to put a new plug on before i find the solution before i have fire. would a cord that is to small and very long cause to much draw and melt at the connection or is there something else going on? thanks for the help
2004 GMC 2500HD LB7 Extended cab long box 4wd
315/75-16 Goodyear Duratracs
6" BDS lift, Pitman/Idler Braces, Tie rod sleeves
DiabloSport Predator, PPE Boost Valve
Autometer Phantom - Boost, Pyro, Trans temp
Straight pipe stock exhaust, Port&polished intake horn
K&N Air Filter
Black projector halo headlights, All on headlight mod
Apexcone Raptor 5000K HID's Hi/Low
branman_2000 is offline
