How To: Transgo JR Shift Kit Install Allison 6 Speed - Page 7 - Chevy and GMC Duramax Diesel Forum
Old 12-06-2012, 07:50 PM   eBay Motors  #61 (permalink)
jaredk's Avatar
Just got enough courage today to tackle this transgo kit. Not really as hard as I was thinking. Granted, I just finished removing the stock downpipe and installing a diamond eye which is as bad as they say it is All in all it took around 3-4 hours and if I had to do it again maybe like 1.5 hrs. I do have a big question for you guys though. While I was removing bolts from the valve body I noticed that two bolts were missing near the pink plug in all by itself. Is that normal or something I need to worry about? As far as I can tell it has never been worked on. I bought it from the original owner with 25k miles on it. Also... I know I should have been paying more attention, but I'm not sure I put in the accumulators and springs in correctly. I filled her back up and went through the relearn process. Everything feels smooth and no issues, but I could use a little reassurance by the experts here.
08 Silverado LT 6.6 Duramax Crewcab
EFI Live by Rob
4" Diamond eye w/ muffler and quiet tone front pipe
Diamond eye down pipe
EGR blocker plate
Edge CTS with exhaust probe
Transgo Jr
SS tie rod sleeves
jaredk is offline   Reply With Quote
Old 12-06-2012, 08:08 PM   eBay Motors  #62 (permalink)
I'll be back
09 Chevy 3500 HD CCLB SRW White w/ black MB Chaos wheels, Pro Comp Leveling Kit, Bushwacker OE's, 16k Reese 5th wheel, Ranch Hand Grill Guard.
Billly is offline   Reply With Quote
Old 12-07-2012, 06:37 AM   eBay Motors  #63 (permalink)
jaredk's Avatar
here is a pic with missing bolts in yellow
File Type: jpg 3rd%20step%20valve%20body%20removal%201[1].jpg (79.5 KB, 294 views)
EFI Live by Rob
EGR blocker plate
Transgo Jr
SS tie rod sleeves
Old 12-08-2012, 12:09 PM   eBay Motors  #64 (permalink)
jaredk's Avatar
Anyone?
EFI Live by Rob
EGR blocker plate
Transgo Jr
SS tie rod sleeves
Old 12-30-2012, 12:55 PM   eBay Motors  #65 (permalink)
Originally Posted by jaredk View Post
Anyone?
I know this is off topic, but I saw in your signature that you have the DE 4" quiet tone system with muffler and a DE downpipe. What was the sound level difference before and after, daily driving and towing? That's the combo I'm looking at because I want some more exhaust flow, but not much more noise. Thanks!
2007 GMC SLT Classic, 2500HD CCSB
Edge Insight CTS w/EGT Probe
EFI Live w/DSP5 switch by Duramaxtuner.com (Nick)
Pullrite Superglide 5th Wheel Hitch
DMI Quic 'n Easy Receiver Hitch
Transgo Jr./Allison Filter Lock
HD SynTran Tranny Fluid (John Deere's Syndtran)
Mike L. Transmission Cooler
Diesel Race Parts replacement Tranny Cooler Lines
Leveled Tow Mirrors
Jd4230 is offline   Reply With Quote
Old 12-30-2012, 04:07 PM   eBay Motors  #66 (permalink)
Shov's Avatar
Interested in the same question? Thanks ahead of time.
2006 GMC Sierra CC SB LBZ, 64,000 and climbing
EFI Live, EGR Blocker Blocked...
Next is exhaust...!
2008 Chevrolet Suburban
1991 Chevrolet 1500 Step Side
www.TrollPerformance.com
Shov is offline   Reply With Quote
Old 12-30-2012, 07:08 PM   eBay Motors  #67 (permalink)
bamadiesel..WFO!!'s Avatar
after the shift kit install it doesnt seem to shift any harder than it used to??? sometimes it even take to long imo in between shifts when im getting on it. How do you guys do? should it be alot harder shift? when getting into it should it be like a 350 turbo with firm and quick shifts?
maybe i should trans relearn again because i didnt go all the way through the process before i shut the truck off, or does that matter? instructions said to do 3-4 shifts at each stage from soft through full throttle and the do it all over again with tow haul on...
any input??
2007.5 CCSB
2003 CCSB SOLD
EFI LIVE with Max Effort from ATP TRUCKS, 5" MBRP with DPF delete, SDP EGR delete tube, PCV reroute, Airdog II 165, Edge Insite CTS, Transgo Jr. Ready Lift leveling kit
bamadiesel..WFO!! is offline   Reply With Quote
Old 12-30-2012, 08:50 PM   eBay Motors  #68 (permalink)
jaredk's Avatar
bamadiesel..WFO!! - To tell you the truth, I don't really feel a diference in shifts either. If anything, it feels smoother and easier to move out of park into drive. I think this might just be from using transsynd fluid though. I also installed Robs efi live tuning at the same time as the exhaust, downpipe, egr plate and transgo jr kit so I wouldn't be able to single out a smooth shift being robs tuning or the transgo kit itself.
Jd4230 and Shov - I really like the 4" exhust w/ quiet tone and muffler. I had rob tune a rumble at idle and it sounds so much better. In the cab it is very quiet and no noticable drone in town or at freeway speeds (I haven't towed with it yet though). I got the exhaust and downpipe mostly for the decreased egt's while towing and better fuel economy (DPF delete).
P.S. Even with those mising bolts in the valve body things seem to be fine... just makes me nervous ya know.
EFI Live by Rob
EGR blocker plate
Transgo Jr
SS tie rod sleeves
Old 12-31-2012, 07:41 PM   eBay Motors  #69 (permalink)
Would a trans relearn be done on highest hp setting?
2007.5 CCSB
2003 CCSB SOLD
Old 01-09-2013, 10:01 PM   eBay Motors  #70 (permalink)
Kblaylock9244's Avatar
Subd for future reference. Does anyone know if this would be a bad idea to do to a high mileage trans? Ive heard horror stories about higher pressures on a high mileage trans.
Kblaylock9244 is offline   Reply With Quote
