| How To's, DIY and Write ups DuramaxForum How To's, Do it Yourself Guides, and other write ups. Only How TO post belong in this forum!!! If your NOT showing/telling us HOW TO then DO NOT post it here. |
| | eBay Motors #681 (permalink) |
| Senior Member Join Date: Oct 2012 Location: Celina, TX
| Juss for anybody that's concerned about doing this, I Juss did this and it actually helped. My #2 injector was out of spec in park at a -4.14 after doing this I was at a -1.14. I didn't think you could bring back a negative out of spec injector but it did. Granted it cleared up the white smoke a lot but still have some because I'm almost positive I have out of spec return rates. But for anybody wondering its defiantly worth a try. I had efi hooked to it the whole time and Juss watched the injector balance rates get better
__________________ 2004 lb7 ccsb 4x4. Efi live tuned by Rob at ATP, ARP head studs, tie rod sleeves, cognito traction bars, airdog 165, ppe boost valve, turbo horn, s&b cai, LML driver side manifold, cat fuel filter adapter 1r-0749, installed cab lights and tow mirrors. NBS back seats. 6 inch zone offroad lift lowered down and running 305/55/20, optima red tops, Mbrp 5 inch turbo back straight pipe exhaust. Soon to come: Built trans, Built motor, and twins http://www.trollperformance.com/ |
| | eBay Motors #682 (permalink) |
| Junior Member Join Date: Nov 2011 Location: Altona, Manitoba Canada
| Did this cleaning a few days ago also. My truck had a bit of a rough idle to it, and it cleared it right up. I never checked the balance rates before hand but it made a huge difference in the way the engine runs. This is the second time I've done this, first time was about a year ago. This is a mandatory maintenance item if you ask me.
__________________ Gerald '05 LLY Crew 4x4 "Don't ask me for the answers, I only have one: That a man leaves his darkness when he follows the Son". - Larry Norman |
| | eBay Motors #683 (permalink) |
| DuramaxForum Veteran Join Date: Mar 2008 Location: West Central Iowa
| Has anyone tried this yet as a secondary deal, or as a routine maint deal with a different cleaner (ie, a strong mix of seafoam and diesel or some other kind of cleaner)? I do like how seafoam will help out gas motors- I just haven't noticed any difference using some in the tank and running it per instructions in my Dmax. It is a pretty good cleaner, doesn't have the alcohol a lot of other cleaners have, and cheaper and more available to most people (most dealerships in my area don't carry it- they have to order it).
__________________ '05 CC/SB, AMSOIL 15w-40 (From Synthetic Motorsports), Cold Air Intake with a dry Nanofiber filter from AMSOIL, PPE Tuner level 1, EGR blocked, LBZ MP, lost KITTY, finished off the rest with 4" SS Magnaflow, Amsoil Torque Drive, 5K HID's, General Grabbers 265 :rockin Synthetic Motorsports |
| | eBay Motors #684 (permalink) | |
| DuramaxForum Enthusiast Join Date: Sep 2010 Location: Maritimes, Canada
| Quote:
Sorry to say but Seafoam is good for cleaning gas motor but not diesels (no matter what they advertise). You'd be better off just running a strong mix of DK while doing the DIY cleaning but I still wouldn't bother doing it unless you're going to get the proper GM top end cleaner.
__________________ 2005 Silverado EC/SB, LLY, 4WD, EFI DSP5 V2 (Idaho Rob at ATP), Edge CTS w/ EGT probe, LML Exhaust Manifold, PPE shimmed FPRV, Banks LBZ air cleaner, Profab intake, LBZ Turbo Mouthpiece, Kennedy twin lift pumps w/ megafilter, Corsa 304 SS Exhaust, Mike L tranny cooler, EXAXT Steering System, Redhead Power Steering Box w/ Amsoil PS fluid, Green Torsion Keys, Allison Deep Pan w/ Suncoast Filterlock and Transynd ATF, Bilstein 5100's (Norcal), Cognito UCA's, 17" NBS alloy rims, 265/70R17 Michelin LTX M/S2's, Pioneer AVH-P3200BT, CubbyCam Backup Camera, Pop & Lock Power Tailgate Lock, Extang Solid Fold Tonneau Cover, Tekonsha P3 Brake controller, Alphatherm AT-38OD Washer Fluid Heater | |
| | eBay Motors #685 (permalink) |
| Senior Member Join Date: Aug 2009 Location: Wisconsin
| I wouldn't run any injector cleaner through the engine like this. There is one other product they mention in this thread but it is a lot more expensive I think. If you want to do this I think your best bet is going to be ordering through the dealer.
__________________ 2003 Chevy 2500 LB7, Crew Cab Bear Claw Front and Rear Bumpers EFI Live DSP5 from ATP/Rob, 4" straight pipe from the downpipe, intake horn mod, modded air box, custom overhead gauge console, pyro and boost gauges Cognito UCA, Kyrptonite Straight Centerlink and Tierods, BFG KM2 255-85 on stock wheels Pictures: http://s1133.photobucket.com/albums/m600/Bear9350/DMAX/ Bumper Build: http://s1133.photobucket.com/albums/...0/DMAX/Bumper/ |
| | eBay Motors #686 (permalink) |
| DuramaxForum Enthusiast Join Date: Nov 2010 Location: across the street
| why not?
__________________ CCSB LB7 4x4 |
| | eBay Motors #687 (permalink) |
| I meant seafoam or other types meant to be dumped in the fuel tank.
| | eBay Motors #688 (permalink) |
| DuramaxForum n00b Join Date: Jan 2011 Location: Edinburg, TX
| I just did this. Everything went well until i got ready to start her up again at the very end. When i pulled out the fuel lines to reconnect the actual lines, some diesel spilled. Well as im trying to start it up there was a small fire. I had to grab a water hose quick! Some wires burned but it doesnt look like they completely fried up. I have to check on it in the morning. Its too dark now :/
__________________ 04 Silverado 2500HD CC LB7 4WD - Banks Exhaust, Banks Wastegate... 2012 Chevy Traverse 1999 Jeep Grand Cherokee 4x4 4.7V8 |
| | eBay Motors #689 (permalink) | |
| Quote:
__________________ CCSB LB7 4x4 | |
| | eBay Motors #690 (permalink) | |
| Quote:
well i checked out the wires, they seem to be ok. not too much damage. primed her up and turned her on. no problem! I feel better, but i still need to look into it.
__________________ 04 Silverado 2500HD CC LB7 4WD - Banks Exhaust, Banks Wastegate... 2012 Chevy Traverse 1999 Jeep Grand Cherokee 4x4 4.7V8 | |
