How To: DIY - Injector cleaning - Chevy and GMC Duramax Diesel Forum
Old 01-25-2011, 07:27 PM   eBay Motors  #1 (permalink)
This is a great way to clean your injectors and improve your balance rates.
First go to your gm dealer and buy the GM upper engine fuel injector cleaner p/n 88861802, about 15 bucks. This CAN NOT be run through the fuel tank. To run this cleaner you have to use the quick disconnects at the rear of the engine.
1. Remove the quick disconnects at the rear of the engine, you will need a set of quick disconnect line tools. the return line is 3/8 and the suction line is 1/2.
2. Once lines are disconnected, install rubber fuel hose to the lines with hose clamps. You will need 3/8 hose and 1/2, about 5 ft of each.
3. use 1/2 gallon of clean diesel fuel and mix 13 oz. of the injector cleaner in a container (I used an old rotella 1 gal. bottle)
4. put both the return and suction lines into the container and place container out of the way of engine. (sat mine on a step ladder next to truck). you can set it on the floor but will need about 8-10 ft of hose.
5. start the engine, check for leaks. run all of the the diesel fuel in the container out, will take time. (mine sat at idle for 1.5 hours). if the truck dies, no big deal, just prime it once you reconnect the fuel lines.
6. once fuel is gone, reconnect the fuel lines, should hear a snap. and done. make sure to check for leaks when finished.
hope this helps some people. my balance rates are much better now, and the engine runs much smoother. maybe try this first if you think you have an injector going bad.
06LLY- EFILive DSP5 Duramaxtuner, EGR block, 5" exhaust, Banks Ram-Air, pitman/idler braces, Rare Parts tie rods, nicktane-CAT, leveled, Bilstein 5100s, rear airbags, traction bars, road armor bumper, 285/75-16 Dick Cepek F-C II
dmaxhd is offline   Reply With Quote
Old 01-25-2011, 07:42 PM   eBay Motors  #2 (permalink)
Anthony6.6's Avatar
Would it be too much to ask for a quick video?
Anthony6.6 is offline   Reply With Quote
Old 01-25-2011, 07:45 PM   eBay Motors  #3 (permalink)
luvin05dmax's Avatar
A video of this would be the goods . Hope ya can get one cause I think I'd do mine .
luvin05dmax is offline   Reply With Quote
Old 01-25-2011, 07:50 PM   eBay Motors  #4 (permalink)
JUST BUILD IT
John O's Avatar
what were the actual #s on the balance rates b4 and after
JOHN
06 GMC 3500 LLZ slt SRW cclb,DSP5 by KORY
www.TROLLPERFORMANCE.com
John O is offline   Reply With Quote
Old 01-25-2011, 08:00 PM   eBay Motors  #5 (permalink)
cannot do a video, dont have a video camera or fancy phone. it is a fairly simple process, even if you dont have that much mechanical experience. as far as balance rates, my #8 injector was averaging 3.6 to 5.0 and after the cleaning is a solid 1.9-2.0 and the rest of my injectors are within +/- 1.0. much better than they were. GM recommends this cleaning every 50,000 miles.
Old 01-25-2011, 08:03 PM   eBay Motors  #6 (permalink)
JUST BUILD IT
John O's Avatar
10-4. once my v2 gets here im goin to check mine an will more than likely do this to mine an see what happens. nothing is wrong with mine that i know of jus like nice clean properly workin parts
JOHN
Old 01-25-2011, 08:43 PM   eBay Motors  #7 (permalink)
Thumbs up
No problem bud thanks for the good info and i'll be doin this like to keep it clean and make it last.
Good info from good people makes this site the best.
2005 Silverado ECSB ,LLY, Allison, Redi lift leveling kit, Sprayed in rhino,Weston push bar and step bars(ss), Billet fuel door.:rockin Just Added : 4" MBRP Turbo Back Exhaust, AFE Mp, Edge Evo,w/EGT Probe.
Old 02-09-2011, 08:17 PM   eBay Motors  #8 (permalink)
usmc_black_85's Avatar
has any one seen any fuel milage benefit from this just courious
2005 SILVERADO 2500HD
6" RCD LIFT
2" COGNITO TORSION KEYS
6" DEARVER LEAF SPRINGS IN THE REAR
35" BFG ALL TERRAINS
37" PROCOMP X-TERRAINS DEPENDING ON THE DAY.
17" WELD WHEELS
HYPERTECH POWER PROGRAMMER III
LBZ MOUTH PIECE
DIY PVC REROUTE
usmc_black_85 is offline   Reply With Quote
Old 02-09-2011, 08:37 PM   eBay Motors  #9 (permalink)
flying_irish's Avatar
Should make a sticky?
2008 Stealth Metallic Grey GMC 2500 HD 4x4 CCSB.
17" XD Addict Rims (Flat Black Option)
285/70R17 Nitto Terra Grapplers (Load Range E Version)
Rancho Lift
Go Rhino Dominator II Nerf Bars (Black)
Roll Lock Bed Cover w/Spray in Liner
Engine and Exhaust Plan in Development
If you can't explain something simply, then you simply don't understand it!
flying_irish is offline   Reply With Quote
Old 02-09-2011, 09:26 PM   eBay Motors  #10 (permalink)
skyler.hager's Avatar
work on all Dmaxes? its worth a shot, my injectors in my LB7 were done prob 30k ago, but I don't have a FASS or Airdog, so a good cleaning won't hurt anything! Thanks for the DIY!
a little maintence now saves a lot of money in the long run! especially when it comes to injectors. anyone know how much it is to have an injector system clean/flush from the dealer?
2003 2500HD LT, CCSB, LB7, EFI tuned by IdahoRob and installed by GOS Performance, Edge CS Insight, AFE intake, 5" center dump exhaust, 8" MBRP tip, 6" Pro-Comp lift, Fox dual resevoirs shock hoops, 35" Toyo M/T's, 20" chrome Diamo 8's, AMP research electric running boards, 55w 8000K HID highs/lows/fogs, All-on mod, roll up tonneau cover, tinted, whited-out.
skyler.hager is offline   Reply With Quote
