Made a video on how to fix the brakes on the front of a Duramax truck. I did this on a 2006 GMC Sierra 2500hd.
If you hear a loud rattle in the front end that happens when you hit any kind of bump, or your brakes are wearing unevenly, excessively, or are sticking, this is how to fix them.
Replaces the pads, rattle clips, pins, bushings, and bellows.
Torque Specs on the caliper pin bolts is 80 ft lb of torque, use my tutorial as a guideline, I'm not held responsible for any damage or faults.
