How To: Thermostat R&R - Chevy and GMC Duramax Diesel Forum
post #1 of 23 (permalink) Old 02-15-2011, 08:29 PM Thread Starter
BoostJunky's Avatar
How to remove and replace your thermostats. This was done on my '02 LB7 after my Attitude monitor never would get above 145* under normal driving conditions. I soon found out why. Now she runs at 180*-187* with some play time thrown in and my mpg's has actually improved as well. This was my first time on a diesel so bear with me haha.
What you will need:
Ratchett
3" extension (I used a 6. It was easier)
12mm socket
1gal of coolant
About 25 minutes.
Step 1: Remove resonator (big black plastic thing that says duramax 6.6 on it)
Step 2: Locate thermostat housing. It's towards the front of the motor in the middle. Real easy to get to.
Step 3: Remove these bolts.
I ended up taking the back one and front bleeder off which in the end wasnt necessary.
Step 4: Remove 2 bolts holding radiator hose in place. The green circle is a hidden bolt on the other side under the plug-in wires.
Step 5: Lift the top of the housing out of the way so that you can change the thermostats out. PLEASE DONT GET THESE MIXED UP. As you can see, I just set mine up on the closest bolt.
Swap the stats out and do everything in the reverse order to put it back together. DO NOT OVERTIGHTEN BOLTS. Not sure what the torque specs are
but if its not leaking, its tight enough.
Fill to the proper level with coolant and let the motor idle to operating temp. Run it down the road and back if you want. Let it cool. If you have air in the system, unscrew the bleeder screw a little bit til fluid comes out and squeeze on the hose. Check the fluid again, add if necessary.
Sorry this is so shitty, but I've had the flu the past week and was running a temp when I was doing this. If you have any questions, feel free to ask someone else who can better answer them for you. Good day...Heyyaa
-CW
07.5 6.7 Cummins MC/SB
EFI, ARP, SC Comp 68, FASS, HTT Stainless, Borg Warner, Diamond Eye, and a lot more...
-2002 cc/sb SOLD
|4.5" on 34's|18" Moto Metal 961's|PPE 160 Tune|S&B CAI|5" Straight Pipe w/ 7" Tip|Ported/Polished Intake Horn|PPE BIV|PPE CP3 Fitting|Autometer Cobalt Boost/Pyro|Sleeves|Bushwackers|Kenwood 2xDin|Headrest DVDs|Boston Components|10's, JL 500/1 & 300/4|Black Halo Projectors w/ 6k/8k HIDs|Billet Grille|5% Tint|'03+ LED Tail Lights|Clifford Security System|Valentine One
BoostJunky is offline
post #2 of 23 (permalink) Old 02-22-2011, 07:48 PM
Chevy*tough's Avatar
Send a message via Skype™ to Chevy*tough
nice write up!
My 01 duramax LB7 AMSOIL Equipped, 200,xxx miles, 4in stainless w/7in tip, ISSPRO GAUGES, HIDS high and low, tow mirrors, ported mouthpiece, AFE stage2
265 nittos on Helo maxx8 black. 4th limp
EFI LIVE THANKS TO: Kory at PPEI
Donovan
Gamertag: dirtymax01
SYNTHETIC MOTORSPORTS
Chevy*tough is offline
post #3 of 23 (permalink) Old 02-23-2011, 07:51 AM Thread Starter
BoostJunky's Avatar
Originally Posted by Chevy*tough View Post
nice write up!
Yeah I forgot the part about checking the dump tank and adding more fluid a day or 2 later if it needs it. Everything worked fine though. No leaks or problems and fuel mileage is showing it's running more efficiently.
-2002 cc/sb SOLD
post #4 of 23 (permalink) Old 02-23-2011, 10:51 AM
1953drtelco's Avatar
Thanks for the info....
2005 HD2500 Silverado 2WD EC LB (FE9 - Federal Emissions) 115K miles Goodyear Wranglers 265/70R/17,
LBZ mouthpiece upgrade, BD Exhaust, MBRP DP, Banks Ram-Air with SuperScoop ,4" SS Corsa Exhaust System w/gutted kitty, Amsoil Dual Oil Bypass Filtration, Aux Radiator (Engineer 837) installed, Firestone Air Bags, Allison extra capacity Tranny pan, MagHytec Rear Diff Cover, Synthetic Fluids ...Mike L tranny cooler) 2008 Towing Mirrors with Leveling MOD, PCV reroute, Fumoto Valve, Mad Jacks fuel fiter access door. Running 2% BioDiesel with Optilube XPD,TTS dual lift pumps with Nictane Aux Fuel Filtration. EFI (Tuned ECM from Duramaxtuner) Edge Insight CTS to control the tunes
And the best part of all, no payments and title in hand
1953drtelco is offline
post #5 of 23 (permalink) Old 12-10-2011, 10:51 AM
Originally Posted by BoostJunky View Post
DO NOT OVERTIGHTEN BOLTS. Not sure what the torque specs are but if its not leaking, its tight enough.
Good writeup for sure. I just had to change out mine (temp stayed around 160 degrees on the highway).
It definitely made a difference in my MPG after too so if your engine isn't getting up to temp, replace them both.
The torque on the Thermostat Cover Bolts is 18 ft-lbs
MTL_Dmax is offline
post #6 of 23 (permalink) Old 02-04-2013, 06:50 PM
Thanks, a few questions though,
1) how long did it take you? and
2) are the 2 thermostats the same PN or are they different?
I think that have to do mine this spring, as the coolant temp sometimes climbs up to 115 on a hill ( hot summer day) , then drops back to 100 ( when still climbing). Seems like one may be sticky?
Don
2005 Sierra 2500 HD LLY Duramax
EGR Blocked - EGR Cooler bypassed
Merchant Auto LBZ mouthpiece Mod
S&B Cold Air intake
Diesel Don is offline
post #7 of 23 (permalink) Old 02-04-2013, 07:14 PM
DirtyPower04.5's Avatar
sub'd
04.5 LLY Chevy CC/SB LT 4x4 Olympic White | candy purple suspension and other things, colormatched, lift kit, American forces, exhaust, engine mods, interior mods, exterior mods |
04.5 LLY Chevy CC/SB LT 4x4 Silver Birch Metallic (~210K) RIP Dec 2013
DirtyPower04.5 is offline
post #8 of 23 (permalink) Old 02-04-2013, 11:13 PM
ieetgluu's Avatar
Don
Theyre definitely two different stats. I believe one is a 180*F and the other is 185*F
Chad
04.5 4x4 ~160k miles
DE 4", 5100s, LBZ MP, S&B LBZ air, KoryWillis Go-go Juice, Insight CTS, ADII, 8' Fisher, Highroller Ultimate Idler Arm, Profab delete, XD RareParts tie rods
Dirtymax this, Dirtymax that... :taunt
ieetgluu is offline
post #9 of 23 (permalink) Old 02-05-2013, 05:29 AM
Don
Don, just a few things that might help.
1) Longest part is refilling and bleeding the cooling system (make sure to use the bolt on the thermostat housing to bleed any air out)
2) Definitely 2 different thermostats, one is 80C and the other is 85C (they are metric temps)
Make sure you look into a better tranny cooler (PPE or Mike L work very well) as it helps remove load from the cooling system too.
This video should help too.
MTL_Dmax is offline
post #10 of 23 (permalink) Old 02-08-2013, 04:26 AM
Great write ups and video too guys....thanks this is a help.
Is there a specific replacement cycle for these thermostats or is it a preventative measure for the most part. It sounds as though when they fail they remain open from one of the posts above?
2006 LBZ Silverado Crew Cab Long Bed 4x4 Duramax
Stock for now but looking for ideas
ppaintguy is offline
