How To: GM Transfer Case Pump Rub Kit - Page 9 - Chevy and GMC Duramax Diesel Forum
Old 12-01-2012, 05:47 AM   eBay Motors  #81 (permalink)
If this flange is already toast, like in my case, will that need a full transfer case replacement?
borrego is offline   Reply With Quote
Old 12-01-2012, 08:54 AM   eBay Motors  #82 (permalink)
tranzfr's Avatar
is there a hole in the case? does it leak oil? how badly worn is the case itself on the inside? if not and you didn't have any issues before.....put it back together. mine had some indentation on the case from wear but it wasn't leaking. i installed the kit and put back together. no issues
Project DualSport
Daily driving on 43s, LB7 with 4in turbo back, EFI live, home built straight axle conversion, Deaver long travel leafs, King coilovers, Fox bumps, ARB rear locker, M.A. motormounts
This truck is built for high speed through the dez and getting out on the rocks/trails and having fun!
tranzfr is offline   Reply With Quote
Old 12-01-2012, 10:18 AM   eBay Motors  #83 (permalink)
2006blackmax's Avatar
How did you guys get rid of stainless clips? Is it screws or rivets ? Have kit ,just have'nt done it.....Thanks
2006 2500HD Duramax LBZ with Allison 6 Speed Allison
PullRite SuperGlide 5th Wheel
Merchant Auto Pump Rub Fix
HD Stainless TieRod Sleeves
3600 PSI Tranny Lines
DeepPan / FilterLock
Transgo Jr.
MBRP 4''
2006blackmax is offline   Reply With Quote
Old 12-01-2012, 08:51 PM   eBay Motors  #84 (permalink)
tranzfr's Avatar
the little clip on the inside? that just pulls right off with some pliers
Project DualSport
Old 12-02-2012, 04:08 PM   eBay Motors  #85 (permalink)
So they pull out fairly easy . Thanks for the help !
Transgo Jr.
MBRP 4''
Old 01-12-2013, 08:14 AM   eBay Motors  #86 (permalink)
Turblow44's Avatar
I might add after hours of trying fig out why two halfs wouldnt seperate once snap ring was removed found out had remove the speed sensor for all of u attempting this other than that pretty easy
Sent from my Desire HD using AutoGuide.Com Free App
Zach Jines
04 lb7 Duramax
afe intake/ 8 inch silverline stack /air dog II/ efi live tunes by (Mark Broviak) /suncoast tranny/ tie rod sleeves.......
Turblow44 is offline   Reply With Quote
Old 01-12-2013, 02:25 PM   eBay Motors  #87 (permalink)
baddmann's Avatar
I just finished this and I wanted to say thanks for the excellent write up!
baddmann is offline   Reply With Quote
Old 03-25-2013, 07:28 AM   eBay Motors  #88 (permalink)
sayoda's Avatar
Subscribed.
Gotta do this soon...
sayoda is offline   Reply With Quote
Old 03-25-2013, 07:43 AM   eBay Motors  #89 (permalink)
DRTYMAX13's Avatar
Used this thread a couple of weeks ago to do mine... Great write-up! Whatever the u-shaped clip was had already been eaten through and pieces of it were stuck to the magnet so apparently I did it just in time before anything else got torn up.
MATT - 2006 GMC 2500HD 4X4 CC/SB SLT - LBZ "CMNSKLR"
ADII 165, MA PUMP RUB, PLUGGED, RE-ROUTED, BLOCKED, K&N, CUT BOX, PPE FITTINGS, RACE VALVE, & FEED LINE, 5" STRAIGHT EXHAUST, KRYPTONITE CENTERLINK & TIE-RODS, COGNITO BRACES, END LINKS & GUSSET, MOOG ARMS & JOINTS, LEVELED W/ KEYS, 20X10 AE 511's, 33X12.50 TOYO M/T's, FRONT BUMPER BUILT BY ME, RECON SMOKED CABS, TAILS & 3RD BRAKE LIGHT, BILSTEIN 5100'S, LINE-X, ETC.
DRTYMAX13 is offline   Reply With Quote
Old 03-26-2013, 03:04 PM   eBay Motors  #90 (permalink)
ChevGuy's Avatar
I haven't crawled under the truck to look at things lately, but is the removal and installation of the transfer case affected by the torsion bars going into the cross member? Or am I way off here?
2002 LS CCSB - Leveling Kit - 285/75/16 BFG's - Muffler Delete - Autometer Boost/EGT Pillar Gauges - PPE Boost Valve - Synthetic Fluids Front to Back - Hypertech Tuned
www.AlligatorPerformance.com
ChevGuy is offline   Reply With Quote
