For a limited time only. This is a deal of a lifetime. ONLY $599.00 Shipped!
Finally at a price we can all afford. One single PPE tuner for EVERY Duramax Diesel Pickup on the road LB7, LLY, LBZ AND FINALLY LMM WITH DPF DELETE!
THIS IS A RACE TUNER. THIS IS FOR OFF-ROAD USE ONLY ON 2007.5-2009 DPF EQUIPPED TRUCKS.
This tuner will eliminate/block all functions of the DPF.
WARNING: FOR OFF-ROAD USE ONLY. PLEASE CHACK LOCAL AND STATE LAWS BEFORE ORDERING.
Features:
- Five to six power levels each with additional horsepower and torque
- Speedometer corrections (for tire sizes 25" through 44.75" at 1/4" increments)
- Adjustable speed limiter (from 40 to 96 mph in 1 mph increments or directly to 200 mph)
- Adjustable gear ratio from 2.73 to 5.13
- Read and clear Diagnostic Trouble Codes (DTC)
- Read real-time data (for engine diagnostics)
- Transmission reset and quick learn feature
- DPF delete function on 2007.5+ Druramx Diesels - RACE/OFF-ROAD USE ONLY!
Application: 2001-2009 Duramax LB7, LLY, LBZ and LMM diesel engines
Product Description:
We knew that you were yearning for real horsepower and torque out of a hand-held programmer and we delivered with the Hot+Race Xcelerator series!
The Hot+Race Xcelerator series was specifically designed for 2001 through 2009 Duramax diesel engines and provides six to ten power levels of additional horsepower and torque, speedometer corrections (for tire sizes ranging from 25" to 44.75" at 1/4" increments), adjustable speed limiter (from 40 to 96 mph in 1 mph increments or directly to 200 mph), adjustable gear ratio (from 2.73 to 5.13), reads and clears Diagnostic Trouble Codes (DTC) through the vehicle's On-Board Diagnostic System (OBD-II), real-time data scanning for comprehensive engine diagnostics and transmission reset and quick learn feature for faster transmission relearn.
Click
HERE to order!
Thanks,
Jess
