Go Back   Chevy and GMC Duramax Diesel Forum > NEW HERE???? PLEASE READ!!!!
NEW HERE???? PLEASE READ!!!! New to the forum? Please take a moment to look over and read the post in this forum Before you get started. Thanks The DF Staff.
Old 09-04-2009, 01:33 PM   eBay Motors   #1 (permalink)
deeretracks
All Jacked UP on Mt. Dew!
deeretracks's Avatar
abbreviations and acronyms
BBIAB = Be back in a bit
BRB = Be right back
BTW = By the way
FWIW = For what it's worth
IIRC = If I Recall Correctly
IMHO = In my honest opinion OR In my Honest opinion
IMO = In my opinion
JMO = Just my opinion
LMAO = Laughing my A$$ Off
LOL = Laughing out loud
N/A = Not applicable, not available can also mean naturally aspirated
NFG = No F'n good
POS = Piece of S**t
ROFLMAO = Rolling on the Floor laughing my A$$ off.
TIA = Thanks in advance
TTYL = Talk to you later
TY = Thank you
YW = Your welcome
Truck Acronyms and abbreviations:
#1 = #1 Diesel Fuel (winter diesel fuel)
#2 = #2 Diesel Fuel
APP = Accelerator Pedal Position
BCM = Body control module. The module that controls various body related functions such as power windows, power locks, interior lights etc.
BOV = Blow off valve
CAC = Charge air cooler otherwise called Intercooler
CAT = catalytic converter
CC = Crew Cab
CEL = check engine light
CP3 = Duramax High pressure injection pump
CTD = Cummins Turbo Diesel
DA or D/A = Duramax and Allison combination
DHRA = Diesel Hot Rod association
DRL = Daytime running lights
DRW = Dual rear wheels
DTC = Diagnostic Trouble code
Dyno = Dynamometer
EC = Extended Cab
ECM = Engine control module
ECT = Engine Coolan Temperature
EGR = Exhaust Gas Recirculation
EGT = Exhaust Gas Temperature
G80 = Gm's RPO code for the rear locking differential in our truck
GN = Goose neck
HD = Heavy Duty
HP = Horsepower or High pressure
IAT = Intake Air Temperature
IC = Intercooler
IP = Injection pump
J/A = Edge Juice and Attitude
LB = Long Box
LP = Lift Pump or Low pressure
MAP = Manifold Absolute Pressure sensor
MAF= Mass Airflow sensor
MIL = Malfunction Indicator Lamp/Light
N20 = Nitrous Oxide
NA = Naturally Aspirated, can also mean not applicable or not available
NOS = Manufacturer of Nitrous Oxide systems (quite often mistaking used to describe Nitrous Oxide)
NSBU = Neutral safety backup sensor.
OBDII = Standard for diagnostic codes
Odo = Odometer
OEM = Original Equipment Manufacturer
PCV = Postive Crankcase Ventilation
PS = Power stroke or Power steering
PSD = Power stroke Diesel
PTO = Power take off
PYO = GM's RPO code for the aluminum wheels found on our trucks
QC = Quad Cab
RC = Regular Cab
RPO = Regular Production Options
RS = Remote start
RT = Reaction time
SB = Short Box
SES (light) = Service Engine Soon (light)
SRW = Single rear wheels
SS = Stainless steel
TC = Torque converter
TCM = Transmission control module
TIT = Turbine Inlet Temperature
Tech II = GM's tool used to test, diagnose and reprogram the various computers in our truck
VIN = Vehicle Identification Number or Serial number
VSS = Vehicle speed sensor
WG = Waste Gate
WIF = Water in Fuel
WOT = Wide open throttle
ZF = ZF Transmission - 6 speed manual transmission
RWHP = Rear wheel horsepower
ET = Elapsed time - total time it takes to run a 1/8 mile or 1/4 mile track. This doesn't not include the reaction time.
Thanks to gunmetalsi for putting this together for us.
Craig
01, CC, SB, 2WD All Stock For Now.
New Members Please Read
DF STAFF/FORUM RULES
VENDOR-PRICE-REQUEST
Your Sig should have year, make ,model and any mods.
deeretracks is offline
