Egr lb7 - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 08-22-2011, 07:53 PM Thread Starter
Egr lb7
i just found out today at the dealership i have a california truck an have a egr cooler an valve and all that good bs on my truck and i live in Ga. i want to get rid of it so i had a few questions. who sells a delet kit and could i just put on a egr block plate and it do the same thing?
03 Chevy Duramax fully loaded, 4" MBRP steaight pipe with 5" tip, PPE Boost Vlave, EFI Live by Duramaxtuner, 20% tinit all around an 35% on the front windshield
b.hunter is offline
post #2 of 9 (permalink) Old 08-22-2011, 07:56 PM
lly blockers fit..... to delete you need a non egr pass up pipe and a y bridge
Zac
2003 LB7 White EC/SB
EFI by Rob w/DSP 5 / Danville stage 2 68mm turbo/ BigDipper trans with ML converter(built by Todd=Stroke 250) / Raptor 150 / Big Dipper 45% over injectors / Wicked Stage 3 Stroker pump / 4in MBRP dp back to a 6" black Mitre cut stack / 8000K HID Hi/Low / Recon smoked LED tails, cabs, and 3rd brake / Rancho 9000's / DHD Steering brace
Originally Posted by blacksmokelb7 View Post
Rather see mama in a whore house then a brother in a dodge
zacwht20 is offline
post #3 of 9 (permalink) Old 08-22-2011, 08:11 PM Thread Starter
whats a pass up pipe and a y bridge..i know nothing about the egr bc i was fooled into beliving i didnt have it so i never looked into any of it. and could i get the same results with a block plate as i could doing the y bridge and pipe?
b.hunter is offline
post #4 of 9 (permalink) Old 08-22-2011, 08:49 PM
you could essentially but still have all the egr shit sitting on top of the motor... a lb7 non egr passenger up pipe and a lb7 non egr y bridge will get rid of all the extra crap and clean it up a little
Zac
zacwht20 is offline
post #5 of 9 (permalink) Old 08-22-2011, 09:01 PM
Banned
Also need a federal emisisons belt since they dont use a vaccuum pump.
Hondarider552 is offline
post #6 of 9 (permalink) Old 08-22-2011, 09:12 PM
skyler.hager's Avatar
Just put a blocker plate out of an LLY in it, then get EFI live to get a tune and keep it out of limp mode!
2003 2500HD LT, CCSB, LB7, EFI tuned by IdahoRob and installed by GOS Performance, Edge CS Insight, AFE intake, 5" center dump exhaust, 8" MBRP tip, 6" Pro-Comp lift, Fox dual resevoirs shock hoops, 35" Toyo M/T's, 20" chrome Diamo 8's, AMP research electric running boards, 55w 8000K HID highs/lows/fogs, All-on mod, roll up tonneau cover, tinted, whited-out.
skyler.hager is offline
post #7 of 9 (permalink) Old 08-23-2011, 06:58 AM Thread Starter
thats how i found out i had an egr was bc my vaccum pump went bad and had to replace it yesterday. so i could put a block plate over the valve and take off the vacum pump and ill be good to go?
b.hunter is offline
post #8 of 9 (permalink) Old 08-24-2011, 02:16 PM Thread Starter
this may be a stupid question about the EGR but could i get an EGR block plate and a hose clamp to close off the hose running from the vacuum pump so i can return the vacuum pump i just bought for it and get a federal emissions belt?? any suggestions would help!! or would i need to get those other y bridge pipes and what not??
b.hunter is offline
post #9 of 9 (permalink) Old 10-24-2011, 11:16 AM
I have a egr also on my 03 and I put a lly blocker plate in and pulled the vacumn pump off and put a federal emission belt on
wthomas is offline
